Old 08-29-2013, 12:53 PM   #1
wonderings OP
Oddometer: 950
stream iphone through zumo to helmet?
I have an iPhone 5 all updated. I have a Zumo 660 all updated, and finally I have a Schuberth C3 Pro with the SRC system. Right now I stream music from the zumo, all of it on a 32 gig mini sd card. Sometimes though I like to listen to online radio, this is something I cannot do with the Zumo and not interested in paying for satellite radio. Is there a way to stream audio from my iPhone through my zumo to my helmet?
“If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse
and you say that you are neutral, the mouse will not appreciate your
neutrality.” Bishop Desmond Tutu
2010 GSA
wonderings is offline   Reply With Quote
Old 08-29-2013, 03:28 PM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,874
No.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 08-29-2013, 10:42 PM   #3
paulhdick
Wannabe Adventurer
paulhdick's Avatar
Oddometer: 328
Not with Bluetooth
No is correct, but you can use the MP3 adapter that came with the SRC and play music wired to your helmet.
Paul
09 R1200GS
Been riding pretty much all my life. Raced SoCal desert in the 60's early 70's.
paulhdick is offline   Reply With Quote
Old 08-30-2013, 01:02 PM   #4
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,378
Why not just BT pair the iPhone to the headset without going through the Zumo? Stereo music.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 08-30-2013, 01:36 PM   #5
DRTBYK
DRTBYK's Avatar
Oddometer: 5,874
Because the zumo 660 can only pair using the A2DP profile and if the OP still wants to hear Navigation prompts then the iPhone can not stream music because it would also be trying to use the A2DP profile. The SRC-S will only allow a one-to-one pairing of A2DP. Hence, you can have one or the other but not both connected for MP3 music.
Cheers,
Dan
All Things GPS
Old 08-30-2013, 07:28 PM   #6
paulhdick
Wannabe Adventurer
paulhdick's Avatar
Oddometer: 328
Cool2 I should have been more specific ....
I think I should have been more specific about my original reply ...
With the Schuberth SRC system you can pair your iPhone to the Zumo (or in my case NAV IV) and also have it hard wired in to the USB/MP3 wired port on the helmet. Sound is actually great on the SRC with the iPhone hardwired in. I keep my iPhone in my jacket pocket anyway so not an issue.
When the phone rings it mutes iTunes and you can take calls through the Zumo. If navigating it also mutes iTunes briefly for the voice prompts. SRC priority is phone, voice prompts, then iTunes.
Works quite well. The only annoying part is it does not pause iTunes, only mutes it, so you miss some of the tunes when navigating with a lot of prompts ....
Paul
09 R1200GS
Old 09-01-2013, 07:11 PM   #7
Nick 187
Oddometer: 204
might be worth a try...
http://www.i-bmw.com/showthread.php?t=44191
Nick 187 is offline   Reply With Quote
Times are GMT -7.   It's 09:23 AM.
