Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-16-2012, 07:41 PM   #16
Riot
Tiger Rider
Oddometer: 105
Mine is a 3/4 drive with a 1/2 --> 3/4 adaptor inserted.
I got mine from a garage/yard sale years ago.
It is a Kinchrome brand.
Pretty much identical to this
Riot is offline   Reply With Quote
Old 11-16-2012, 07:52 PM   #17
Xcountry-Rider OP
Oddometer: 912
So this should work then?
Xcountry-Rider is offline   Reply With Quote
Old 11-17-2012, 02:43 PM   #18
Riot
Tiger Rider
Oddometer: 105
Originally Posted by Dr. Doofenshmirtz View Post
Yep
Old 12-03-2012, 09:13 PM   #19
bsupak
Oddometer: 4
dropped a tooth
Hey,
I was changing my front sprocket with xcountryrider and afry this weekend and he suggested I post up here (he still loves you guys :)) .
So I downsized to a 15t on the front and it rides like a whole new bike. The throttle is more sensitive and I can fully unload (and lift a bit) the front-end on throttle only. I do have to shift a bit more, but it feels more like other bikes I've had.
One bit of advice, in looking for the part (15t front sprocket for a 525 chain) I found it's the same part as for the GSXR 600/750/1000, SV650/1000, Triumph 675, DL650/1000, & ZX10R. Cyclegear had one on the shelf.
I see what the converts mean when they say this is the gearing Triumph should have installed :)
Bryan
bsupak screwed with this post 12-03-2012 at 09:23 PM
bsupak is offline   Reply With Quote
Old 12-05-2012, 12:12 PM   #20
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Originally Posted by bsupak View Post
Hey,
Bryan
Have you noticed any significant impact on MPG?
some call me...tim is offline   Reply With Quote
Old 12-05-2012, 04:27 PM   #21
bsupak
Oddometer: 4
yes, but it's my "fun time playing" with the throttle. I was getting about 37-39 mpg before. I reset the computer and the latest stat was 31 mpg and climbing. Once the new acceleration and power band thrills wear off I'm sure I'll get back up to 36+, but I'll let you know. It also keeps me from drifting up into the 90s on the highway. I'm tending to cruise at ~78 at 5k rpm.
Bryan
Old 12-08-2012, 01:56 PM   #22
Flyboy52219
Flyboy52219's Avatar
Oddometer: 66
I just unbolted the top of the rod from the spline - bolt needs to come out not just loose.
See post # 4 from me.
Riot - thank you. Worked on it today and these instructions were spot on. Notice they even put in an alignment dot to make it idiot proof when putting it back on. Thanks!
Flyboy52219 is offline   Reply With Quote
Old 12-23-2014, 01:59 PM   #23
bbtech
Computer Guru
Oddometer: 62
Originally Posted by motosickle2000 View Post
If you have 30K, you should definitely change both sprockets and the chain. I recommend a DID 525VM2. It is very high quality and not too expensive. It is also an Xring.
You will need a large socket to loosen the nut on the front sprocket. I can't remember the size. Loosen the front sprocket before removing the chain, an air impact wrench makes it a cinch to remove. The rear is self explanatory.
You will need a chain breaker and rivetting tool. Motion Pro makes a good one. I bought one made by RK.
If you look at the Spec for the DID 525VM2, it is rated for just over 8,000lb of tensile strength with a maximum of 750cc recommended ( no doubt for off road use and likely 900cc for on road). I also don't think the chain represents the best value for your money considering the cost. Perhaps consider the GB525XSO-124 by RK with 8,850 lbs for just over a buck or JT JTC525X1R124L with 8,930 lbs of tensile strength for right around 65 sheckles shipped. Just my two cents :o))
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! ~Hunter S. Thompson
bbtech is offline   Reply With Quote
Old 12-23-2014, 02:05 PM   #24
bbtech
Computer Guru
Oddometer: 62
Originally Posted by Rob Dirt View Post
Just be sure you have the bike in neutral & use the back brake to loosen the front sprocket nut (36mm). If you try to loosen it with the bike in gear, then it will put strain on the transmission. With the bike in neutral, torq it back on while holding the back brake.
On the rear sprocket, make sure you buy a new bolt kit. To remove the old bolts always turn the nut, NOT the bolts. Always use loctite & a torq wrench.
Your new chain will have a master link. Make sure it faces forward. Like a fish swimming up stream. If you've never put on a master link, then you may want help from somebody with experience. If you put it on wrong, then it will come off.
Why do you need to order/use a new bolt kit for the rear sprocket and what is your source for this?
Old 12-23-2014, 11:04 PM   #25
BryanCO
CO Rider
Oddometer: 496
You do realize that you are replying to thread that over two years old.
2013 Multistrada 1200S Pikes Peak
BryanCO is offline   Reply With Quote
Old 12-24-2014, 04:44 PM   #26
bbtech
Computer Guru
Oddometer: 62
I realize that threads often get revived and that people still read older threads and may want more "current" input. Thank you for your concern though.
Old 12-31-2014, 07:08 AM   #27
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
The rear sprocket bolts tend to get messed up when you remove them. Not all of them but one or two is enough that you need new ones. On all my dirtbikes, I replace the bolts. I haven't done my rear on the Tiger but I'm sure they sell a sprocket bolt kit.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
