Old 11-04-2012, 05:08 PM   #1
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Rebuilding a 1989 Yamaha YZ250
The real title of this thread should be rebuilding my youth. I got my first 89 YZ250 when I was about 15 years old after moving up from a couple of older YZ125s. I had this bike for around 4 years. During that period My dad, brother and I were riding a lot and I have a lot of great memories from those years. About a year ago I was looking through Craigslist and came across the listing for this bike After looking at the bike I couldn't help myself and it followed me home. While being in pretty good shape for a 23 year old bike I have decided to do a restoration on the bike and return it to its former glory. This will be a slow process between work and life getting in the way, but I wanted to document it here. This bike is actually in better shape than my original was when I got it in 1991. Below are some pictures of the bike and its tear down.
And Hopefully it will end up looking something like this.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 screwed with this post 11-05-2012 at 03:23 PM
offrdr1975 is offline   Reply With Quote
Old 11-04-2012, 06:11 PM   #2
agspecialties
agspecialties's Avatar
Oddometer: 1,159
That bike looks really good for being that old of a bike. Should be a great and easy project for you. Looks like the bike is all there. Did it run? Keep us posted.
agspecialties is offline   Reply With Quote
Old 11-04-2012, 06:17 PM   #3
THB
THB's Avatar
Oddometer: 153
Tugging at heartstrings. I have two boys and gave my son his first YZ250 at the age of 15 also. It's a 2003 and still putting many a mile and many a smile on both of our faces. I hope he feels the same way years down the road. Best of luck with the rebuild.
1989 Honda Hawk GT NT650
2007 Yamaha WR250F
2006 Yamaha WR450F
2003 Yamaha YZ250
THB is offline   Reply With Quote
Old 11-04-2012, 06:20 PM   #4
Gham
Gham's Avatar
Oddometer: 1,319
Looks waaaay better than my 87 CR250R (that needs a crank$$$$$)
Best of luck,looks fairly easy like was said above^^
Member 6204
Society Historicus Revisioniscus
Gham is offline   Reply With Quote
Old 11-04-2012, 06:50 PM   #5
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Thanks guys. Overall it is in pretty good shape. It needs a thorough cleaning, painting, and overall refreshing. Motor runs good and had new crank seals installed shortly before I purchased it so I am not sure how much I will do to it. All the suspension needs rebuilt and the wheels need some work. Overall though it is a good base to start with. I already have all new plastic and graphics for it. I am looking into powder coating the frame if it is not too cost prohibitive. Should be a fun winter project.
Old 11-04-2012, 08:30 PM   #6
third eye
back road loon
Oddometer: 158
Is that carb a mikuni VM? Just curious as my '93 WR250 had one
third eye is offline   Reply With Quote
Old 11-04-2012, 08:42 PM   #7
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
It is actually a Mikuni TM, but I would have to research further to tell you what size of TM.
Old 11-06-2012, 07:29 PM   #8
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Well after getting quotes for powder coating the frame I am getting it powder coated. Other than that just ordering parts while I am out of town this week.
Old 11-07-2012, 12:51 PM   #9
Gham
Gham's Avatar
Oddometer: 1,319
I've never had one powder coated but some of those who have remarked about too much paint build-up in the neck(makes the bearings difficult to re-fit) just a tip in case you have never had one done before.You probably already knew this though
Member 6204
Old 11-07-2012, 05:39 PM   #10
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Since my steering head bearings are bad I plan to leave the old bearing races in until after it is powder coated. Hopefully this will help prevent this issue.
Old 11-07-2012, 07:17 PM   #11
third eye
back road loon
Oddometer: 158
good decision on the old races in the steering head. I seen someone do that before and it worked out well. Need to paint the frame on my WR but too busy riding it.
Old 11-08-2012, 11:03 AM   #12
PTRadam
Oddometer: 503
Reminds me of Damon Bradshaw!
PTRadam is offline   Reply With Quote
Old 11-08-2012, 01:44 PM   #13
Gham
Gham's Avatar
Oddometer: 1,319
Smart move!
Member 6204
Old 11-09-2012, 10:10 PM   #14
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Finally back in town. I dropped the frame off at the powder coaters tonight. I cant wait to see it finished. I also took the opportunity to clean up and inspect a few parts getting them ready for reinstall.
First cleaned up and repainted the top triple clamp. I also installed the lower bearing on the steering stem.
Next I checked out the front rim. Several spokes were loose and some were corroded solid so I took the wheel apart and cleaned and painted the hub to get it ready to be relaced.
I also cleaned up the swing arm and linkages trying to get them ready to go back on. So far all of the linkage bearings appear to be in good shape. No signs of pitting or rust and had lots of grease in them. Unfortunately tonight will probably be the last time I get a chance to work on it until after Thanksgiving though.
Old 11-27-2012, 10:37 PM   #15
offrdr1975 OP
offrdr1975's Avatar
Oddometer: 113
Got the frame back from the powder coaters
Well after a week of vacation I was excited to get back to town so I could get my frame which was ready at the Powder Coaters. They did a great job with a lot of attention to detail. They protected all of the threads and mounting points. They also protected the VIN so that it can still be easily read. Overall I am very happy with the work and I thought the price was very reasonable. To media blast and powder coat the frame they only charged $175 which I was very happy with. I was not able to get a lot done tonight other than chasing the threads on the frame. Hopefully I will have some time this weekend to make some real progress on the bike.
Times are GMT -7.   It's 02:32 PM.
