Old 05-24-2013, 01:13 PM   #346
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,743
Originally Posted by CHRIS_D View Post
Just to make sure we're on the same page.. if I was going to mount the leds to the side of the bike's forks using MY bracket it only needs to allow a minimum of 1/2 inch clearance between your slotted mounting bracket and the fork? I hope that make sense!
The back of the light hangs out a bit past the back of the mount.
from the edge of the mount bolt slot to the back of the light is approx 1.5 inches, the mount can be flipped around . by flipping the mount around the distance from the slot to the back side of the light is about 1 inch.
Any chance you can post a photo or link to the mount you would like to use?
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 05-25-2013, 02:19 PM   #347
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Here's some photos to hopefully help show what I'm trying to do.
First here's what the bracket looks like...
Next here's how I would like to install it on the bike (notice it's to outside of the fork)...
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D screwed with this post 05-26-2013 at 05:03 PM
CHRIS_D is offline   Reply With Quote
Old 05-25-2013, 05:25 PM   #348
doc dogg
Oddometer: 21
I just measured and it is about 1 1/2 inches from the bolt centre to the edge of the bracket. Your bracket may just be long enough, maybe. If you spin your bracket forward a bit (say 45 degrees) and turn the Lights mounting bracket around so the bit that sticks out is to the rear of the light (opposite to how it it is in the picture below. You should be able to fit it with enough clearance.
doc dogg is offline   Reply With Quote
Old 05-26-2013, 03:47 AM   #349
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Thanks Doc! It sounds/looks like it's going to be a close fit.
Old 05-26-2013, 07:52 AM   #350
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,258
Got a set of twins & installed them last week-- those are some stout lights.
I did accidentally push the Verboten Button in trying to shoehorn everything under the stock headlight, but I pulled it back out & reseated it and everything seems to work just fine.
I have not been able to test them because it gets dark later than I can stay up right now (I get up at 3:30 AM).
After reviewing the initial post in this thread a couple of times, I could not find a way to obtain an ADV discount. Thats the only complaint I have concerning these lights.
Good stuff-- keep it up!
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 05-27-2013, 09:44 AM   #351
Off Road Ryder OP
Oddometer: 2,743
Thanks for helping Doc
1-800-624-0278
Old 05-27-2013, 09:48 AM   #352
Off Road Ryder OP
Oddometer: 2,743
Thank You I'm sure you will be surprised by the distance that the doubles provide.
I apologize for the adv code. It is listed several times in this thread and also in the vendors sticky section.
For others the code is ADV
1 800 624 0278 for phone in orders, make sure to mention adv
1-800-624-0278
Old 05-28-2013, 11:00 AM   #353
Rick G
Ranger Rick
Rick G's Avatar
Oddometer: 2,063
Could you reccomend a set of driving lights for my 2009 Bonneville T100? Like everyone else, I am looking to improve my sight lines at night and my conspicuity during the day. I was thinking of mounting on the forks to create a triangle of light.
Any suggestions would be appreciated.
Rick G
Any Road Any Time!
2011 BMW R1200R - The Redhead with Big Jugs I have always wanted!
2009 Vespa GTS Super 250ie - Just for Kicks & Giggles
Rick G is offline   Reply With Quote
Old 05-28-2013, 02:30 PM   #354
Off Road Ryder OP
Oddometer: 2,743
Originally Posted by Rick G View Post
Could you recommend a set of driving lights for my 2009 Bonneville T100? Like everyone else, I am looking to improve my sight lines at night and my conspicuity during the day. I was thinking of mounting on the forks to create a triangle of light.
Rick G
In keeping with the Bonnies classic styling, I would recommend the NXG Prime Led lights. They are compact and offer a good punch as well.
http://www.cyclopsadventuresports.com/?page=products&id=136
They are dimmable if that is a requirement.
Built using the same quallity standards that the Long Range lights are.
IMO the single biggest thing you can do for conspicuity lighting is to create the safety triangle, I could not believe what a difference I noticed when I did that to my bike.
1-800-624-0278
Old 05-30-2013, 08:12 AM   #355
Off Road Ryder OP
Oddometer: 2,743
For anyone living in the great Northwest, We will be setup with a vendors booth and riding at this years BlackDog Dual sport event.
Held in Mt Hood Or. the black dog is a funfilled event for dual sports and ADV bikes
Come on out and get a first hand look at the long Range and several other options that we will have on hand.
http://www.blackdogdualsport.com/bd_events.htm
1-800-624-0278
Old 05-30-2013, 04:43 PM   #356
TrailDust&SaddleLthr
TrailDust&SaddleLthr's Avatar
Oddometer: 194
Hi!
Where did you get those brackets? They look awesome!
Pre-planning for my WR250R.... I was initially thinking of mounting a set of those on the little aluminum bracket where the round amber reflectors are (taking those out and mounting them on the plaztic faring instead)...
whether that would work or not IDK, but your brackets seem to be a much better idea, in which case I would want to mount them under those reflectors, also creating a triangle of lights for being seen much better by oncoming traffic.
Thoughts?
TrailDust&SaddleLthr is offline   Reply With Quote
Old 05-31-2013, 12:22 AM   #357
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,491
Could you post a picture of the harness with the standard on-off switch please?
tmotten is offline   Reply With Quote
Old 05-31-2013, 07:37 AM   #358
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,932
Morning.
2004 950 Adventure.
I've perused the thread and am impressed. The problem is mounting for me
It would appear my only option is to mount on the top bar, which is curved. If I put the tube clamp that you sell facing forward, is there enough room for the wire out the back of the light? As in, can the light swivel 180degrees on that bracket? Looks like it might.
The only other option would be to weld tabs coming straight forward and mount the light upside down.
I dislike driving at night and the headlight on the KTM is fairly pathetic. With an upcoming week+ trip to Colorado, night riding is a definite and I would like to see the edges of those roads
A major concern before I found the above pic was the fact that the crash bars have to be removed to do everything short of fill the gas tanks
Nice work on having the lights plug into the harness right near the light
Originally Posted by TrailDust&SaddleLthr View Post
Hi!
hold onto your shorts
http://www.cjdesignsllc.com/products...blank-version/
vwboomer is online now   Reply With Quote
Old 05-31-2013, 10:22 AM   #359
Off Road Ryder OP
Oddometer: 2,743
I will get on that and post asap
1-800-624-0278
Old 05-31-2013, 10:28 AM   #360
Off Road Ryder OP
Oddometer: 2,743
Originally Posted by vwboomer View Post
Morning.
2004 950 Adventure.
The tube mount brackets swivel all directions, I haven't seen an app where they would not work. The top bar looks perfect and is where mine are mounted on my 950 ADV. I have the other style bars, you may need to still mount the light underneath the crash bars for tank clearance, but no need to weld a tab.
One thing I like about the short wire connections is that to do service work, its easy to unplug the light and remove the crash bar, Before I installed the Long Rang on my bike I had the penetrator 310"s that have long cords, what a pain it was to remove my tanks, I made sure that didn't happen this time
1-800-624-0278
Times are GMT -7.   It's 11:54 PM.
