Old 05-31-2013, 10:57 AM   #361
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,459
Originally Posted by Cyclops Motorsports View Post
The tube mount brackets swivel all directions, I haven't seen an app where they would not work. The top bar looks perfect and is where mine are mounted on my 950 ADV. I have the other style bars, you may need to still mount the light underneath the crash bars for tank clearance, but no need to weld a tab.
One thing I like about the short wire connections is that to do service work, its easy to unplug the light and remove the crash bar, Before I installed the Long Rang on my bike I had the penetrator 310"s that have long cords, what a pain it was to remove my tanks, I made sure that didn't happen this time
Looks like it's time to spend some money I will likely have to relocate the trip computer button pad to be able to reach the hi/lo/off switch reasonably, but I rarely use the thing anyway
vwboomer is offline   Reply With Quote
Old 05-31-2013, 12:52 PM   #362
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,598
Its easy to set the lights up to use the factory High/low switch on the KTM.
I like using my lights independent of the headlight so I'm running the multi function switch.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 06-01-2013, 06:38 AM   #363
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,328
Do you have a picture of what the PENTRATOR 610 will throw for light,,,i have an XR650L and lighting sucks
I`d like to mount it below the headlight with some kinda bracket
B
techforlife is offline   Reply With Quote
Old 06-02-2013, 08:26 AM   #364
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 689
B
I'd show some pics of the 630 but it is in Colorado at the moment. I will say this, they fill in the dark hole. Combined with the 10 degree Long Range lights it is the ultimate for high speed gravel road riding at night. The 630 will also be my primary light for the upcoming 24 hours of Starvation Ridge. I did a video, but the Contour Roam didn't capture just how good they are so I wont be sharing it. If you want high output, low draw, the best quality light and great customer service order up. You will not regret it.
I also have an idea for mounting for the XR, I'll share once I verify it will work.
Chet
SOP Dirt-Rider is offline   Reply With Quote
Old 06-04-2013, 06:35 AM   #365
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,459
Order placed. Hopefully they get here quick so I can fully test the setup before heading to Colorado in a month. Argh only a month to get so much done
Issues with the process: your paypal link didn't work.
The email confirmation was full of wonky stuff like this and about a zillion words long :
Thank you for shopping at Cyclops Motorsports.
\r\n
Your order should be processed and ready for ship-out. Below is your order confirmation. Please keep a copy for your records.
\r\n\r\n
Neither thing a big deal, just letting you know in case something is up with the site.
I'll be waiting by the front door!
Old 06-04-2013, 07:53 PM   #366
Off Road Ryder OP
Oddometer: 2,598
\r\n
\r\n\r\n
Thanks for the Order and feedback
We are in website hell. Hopefully the upcoming change in site management will take care of that.
1-800-624-0278
Old 06-04-2013, 08:04 PM   #367
Stovebolt
Team Ruptured Buzzard
Stovebolt's Avatar
Oddometer: 478
As has been noted by fellow inmates, Darryl's customer service and technical knowledge are TOP NOTCH! Glad to see people ordering the good stuff and getting what they need.
Me likey the setup I bought from Cyclops a couple seasons back with my Rally Light. It's the shizzle.
Rally on, Darryl.... contact me when you get in my AO this season, coolio?
All the best,
Stovey
Stovebolt
Team Ruptured Buzzard "Never Give Up"
http://bustedcompass.com
http://www.linkedin.com/pub/david-jankowsky/86/31/b04
Stovebolt is offline   Reply With Quote
Old 06-05-2013, 08:00 AM   #368
Off Road Ryder OP
Oddometer: 2,598
Originally Posted by tmotten View Post
Could you post a picture of the harness with the standard on-off switch please?
Sorry for the Delay.
The Standard Harness uses a toggle switch and Deutch connectors. Dimming can be added at a later date. A handle bar mounted switch can be added for an additional 14.95
1-800-624-0278
Old 06-05-2013, 10:55 AM   #369
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,459
I appreciate the call letting me know it would be a day before shipping.
Now all I have to do is remove a couple fuel tanks, crash bars, skid plate and fairings
Old 06-05-2013, 12:04 PM   #370
Off Road Ryder OP
Oddometer: 2,598
All the best,
Stovey
Thanks Stovey, I cant wait to make it out your way. BTW. Love my buzz Bomb GPS Cradle!
1-800-624-0278
Old 06-06-2013, 01:35 AM   #371
Adrian V
Oddometer: 497
Elliptical lens/cover option?
I realise that this has been raised before, but given that LED lights are increasingly being used as a replacement for OEM lights, an elliptical version (lens or cover) would be great for a low beam. I notice that the Solstice lights have this option, any chance it could be made available for the Optimus? Paired with a 10 or 20 degree spot, I reckon this would be a great option for a dual headlight cowl.
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 06-06-2013, 08:31 AM   #372
Off Road Ryder OP
Oddometer: 2,598
Cheers,
Adrian
I don't see that happening with the Opt. Long Range. There is a new 25 watt single emitter light that is about to come out that does offer diffusers of different beam patterns and colors. We will stock clear and Amber.
The lights are a bit bigger than the Opt. long range, but extremely potent.
1-800-624-0278
Old 06-06-2013, 01:27 PM   #373
Off Road Ryder OP
Oddometer: 2,598
B
Thanks for asking
Here is the 610 the flags are at 100 ft intervals. Tree line approx 350 ft
1-800-624-0278
Old 06-06-2013, 04:26 PM   #374
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,468
Cheers mate. I think I'm confused. The top and bottom right are plugs for the Led's with a ground to the frame in series....... hang on......
Nah, I'm confused.
Could I request a simpler harness with a DTM Deutsh connector and some wire lengths? Happy to send a diagram. DTM go to 7.5A.
tmotten is offline   Reply With Quote
Old 06-06-2013, 05:22 PM   #375
Adrian V
Oddometer: 497
Where did my post go?
Someone other than Cyclops responded to my first post asking if we'd seen the Light Canon and I replied I had but it was too big and that I was hoping something similar would come out with the Optimus rounds.
Where did these posts go? I certainly didn't delete mine?
Just to clarify, there was nothing contentious, rude or aggressive in these posts, were they deleted because they mentioned another light manufacturers product?
Cheers,
Adrian
Times are GMT -7.   It's 01:58 AM.
