Old 12-26-2012, 08:57 AM   #61
Cyclops Motorsports OP
Cyclops Motorsports's Avatar
Oddometer: 906
Mount Photo
Here is a photo of the light Mount for the Premium Quality Long Range LED's. This mount is very robust, swivels left? right as well as up and down
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 12-26-2012, 10:52 PM   #62
Ol'NumNuts
Oddometer: 102
Hi,
I noticed on the shop Mule you have a LED light bar mounted as well as the spots.
Care to comment how this might work as a short distance flood 'fill light' to complement the spots. I'm a little surprised this hasn't been mentioned through the thread?
I know pics of lights at night are problematic, but the pics in the field with the 100 ft markers do offer a reasonable comparison???
In heavy bush, at night, I want a bright wide light so I can see a little around corners, up above and indeed down below. It can be pretty daunting coming to a steep drop-off at night. I want to see right in front and below- not just what's way down the road...
Bright long spots are pretty useless on tight trails, but you sure look for them as soon as it opens up a little. Really, there is need for both...
Care to comment?
Ol'NumNuts screwed with this post 12-27-2012 at 02:48 PM
Ol'NumNuts is offline   Reply With Quote
Old 12-27-2012, 09:16 AM   #63
Oddometer: 906
Originally Posted by Ol'NumNuts View Post
Hi,
Care to comment?
Your absolutely correct. I personally do a lot of night riding/racing. 24 hr racing has been our specialty.
There is a need for long range and a flood like pattern. One main reason we offer many different beam patterns. On my personal bike I run all 10 deg beams, If I'm riding trail at night I use a helmet mounted light like our Solstice HID, This gives me a light that I can use for low speed tight trails as well as fast fire road riding. Very few big bike ADV riders will buy into a helmet mounted light.
Nothing beats that setup. It is also a 10 deg beam, however do to the fact that it is helmet mounted you can see where you look and no flood is necessary.
For the guy who mistakenly thinks helmet mounted lights are not needed then a flood pattern will help in tighter conditions.
The light beams of the light bars or other lights we have include 10, 25, 40, and 60 deg beam patterns.
One light will not work for all conditions. Aiming the lights you do have properly will help quite a bit for any given situation.
Old 12-27-2012, 12:35 PM   #64
murphyKTM
Oddometer: 35
Just got my 10degree light.
I found it well made, seems robust, mount good and light patten very even with no dark spots.
Im a happy camper.
murphyKTM is offline   Reply With Quote
Old 12-27-2012, 02:56 PM   #65
Ol'NumNuts
Oddometer: 102
Hi,
Sorry, I added the following EDIT to my post above only to discover we had 'crossed' messages...
So, I have moved it here...
EDIT:
BTW... I'm down in Australia... We definitely need the long spots- wouldn't do long night rides without them. Sometimes a kangaroo will just plant itself on the road... But mostly they forage at the roadside and hop out at the last moment. Most drivers don't see them and say, "it just appeared from nowhere" after a strike...
So, you have my attention re: the spots but I'm looking for a 'total light solution' which would include 3 equally important aspects:
1) Long range spots (tick)
2) Wide Angle low height Flood (?) (hint: like the Ol' 'fog lamps'- but wider)
3) Short range "wall" of light- like 120 degrees 'in all directions' light (?)
Now we're talking serious lighting solutions....
Hmmm, that helmet light is definitely something I hadn't considered (or even seen before) but I will consider it...
Still have a need for a low wide flood to spot the suicide roo's before they ruin my day...
You got me thinking about the helmet light...
I'm a builder and in winter we start work before sunup so for the first hour or so I actually wear a headlamp. Same with pack-up after dark. I've been doin this for a few years now and was definitely one of the first, locally anyway. I used to cop a ribbing- but now I see even websites and tv shows wearing them...
So, there you go. You're speaking to the converted- just have to get my head round wearing one on the bike. Yes, I appreciate your HID is probably a gazillions times the output- just have to adjust to the concept- but I like it!
If you read my comments re: suicide roo's you will begin to appreciate that in my neck of the woods a 'low wide flood' is a MUST HAVE and there is no way any helmet light will satisfy this requirement... I would be sending myself stupid and dizzy constantly swinging side to side...
The helmet light may well satisfy point 3) above, but point 2) remains unanswered...
Ol'NumNuts screwed with this post 12-27-2012 at 04:01 PM
Old 12-28-2012, 04:20 AM   #66
kimokk
kimokk's Avatar
Oddometer: 108
Anybody know how these lights compare to the Kristas? Thanks!
'09 BMW R1200GSA Adventure!
IBA #49426
kimokk is offline   Reply With Quote
Old 12-29-2012, 10:19 AM   #67
Oddometer: 906
Hi,
EDIT:
Funny to hear your experiences with head mounted lights.
I can remember distinctly being laughed at durring trade shows etc when we introduced the first Motorsports specific Helmet mounted light. Now 10 years later, we have been copied by others and a helmet mounted light is now the norm for off road night racing.
I wear mine anytime I'm off road at night, In fact I turn my bike mounted lights off while on a trail, they are far too distracting with them bouncing everywhere. When using a helmet mounted light your on the gas while the rider without one is still trying to find the corner. They do work best in a trail type environment. On more open roads I enjoy not feeling like I'm in a dark tunnel and I do see wildlife on the sides of the road that would have never be seen without it.
We offer several beam angles on bike mounted lights from 10 up to 60 deg. beyond that the forward light is very diminished.
But some may desire wider focal points.
We do offer very wide angle work type LEDs that are becoming very popular with Commercial Fisherman and other places where you need high powered Low draw Area lighting. Toyhaulers and trailers,Farming and Off grid living are just a few of the applications.
Cyclops Motorsports screwed with this post 12-31-2012 at 10:17 AM
Old 12-31-2012, 10:18 AM   #68
Oddometer: 906
Im a happy camper.
Thanks Murphy.. I hope your healing fast!!!
Old 01-01-2013, 06:50 PM   #69
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,539
Originally Posted by Cyclops Motorsports View Post
The Premium Quality Long Range lights will be on the site by Jan 1
1 800 624 0278
Still waiting... Bump.
twinrider is offline   Reply With Quote
Old 01-02-2013, 08:50 PM   #70
Oddometer: 906
Thanks for the bump! Heres the singles
http://www.cyclopsadventuresports.co...tegories&id=17
Cyclops Motorsports screwed with this post 01-04-2013 at 10:03 AM
Old 01-02-2013, 09:15 PM   #71
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
I must have missed it, but what is the light's housing made of?
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 01-02-2013, 09:19 PM   #72
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,539
http://www.cyclopsadventuresports.co...roducts&id=182
Great. Saw the Turkey Day sale, are you doing a New Year's sale?
Old 01-03-2013, 08:46 AM   #73
Oddometer: 906
6061 diecast Alu. Tough as nails.
Old 01-03-2013, 08:48 AM   #74
Oddometer: 906
Sorry.. We always do offer an ADV rider discount on any of our products.
Old 01-03-2013, 04:50 PM   #75
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,539
Just saw your generous 12% discount.
Times are GMT -7.   It's 11:52 AM.
