Old 01-04-2013, 09:45 AM   #76
Cyclops Motorsports OP
Cyclops Motorsports's Avatar
Oddometer: 906
Originally Posted by twinrider View Post
Just saw your generous 12% discount.
Thank You We do the best we can..
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 01-04-2013, 06:45 PM   #77
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
Originally Posted by Cyclops Motorsports View Post
6061 diecast Alu. Tough as nails.
Ooohh...
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 01-04-2013, 08:29 PM   #78
Rustykfd
IBA #44100
Rustykfd's Avatar
Oddometer: 80
Review
I received my pair of singles today.
2 days from phone call to on my doorstep, impressive.
These lights are substantial, I was really surprised when I opened the box. The beam is very tight and sure does punch out there. I have explored a lot of lights and have never seen a LED that has this kind of throw. It goes to show that the reflector is where throw comes from and this light has a reflector like none I have seen. I will report back once I have them wired up and go for a ride.
The wiring harness is much more stout than any other harness I have seen. It comes with nice watertight connectors, fuse, switch(not sealed) generally really well put together. I did find the wires from the relay (sealed by the way) to the light to be short for my installation, which is on the crash bars.
Rusty Kennewick Fire Department 2012 Super Tenere (1150GS RIP)
IBA # 44100.......3 Digit IBA # coming in 2013 if I can do my part
http://spotwalla.com/myLocation.php?...ap&traffic=off
Rustykfd is offline   Reply With Quote
Old 01-04-2013, 10:54 PM   #79
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,546
Good info Rusty. If I get these lights they will also be going on the engine guards so plug and play wire length would be good, as would a sealed switch. Looking forward to your ride review.
twinrider screwed with this post 01-05-2013 at 01:49 AM
twinrider is online now   Reply With Quote
Old 01-05-2013, 05:55 AM   #80
CHRIS_D
CHRIS_D's Avatar
Oddometer: 632
Nice LED driving lights.
Is the PWM dimmer available yet? Does the bracket (shown on your web site picture) that's mounted on the LED come with the kit? It looks to me like it will swivel. If this is the case will it swivel, so as to make the mounting point location on the back of the housing instead of the bottom as pictured?
2011 Victory Cross Country
2006 Suzuki DR 650
CHRIS_D is offline   Reply With Quote
Old 01-05-2013, 09:41 AM   #81
Oddometer: 906
Thanks Rusty.
I actually shortened the wires because I thought you where mounting them to the lower triple clamp.. Sorry
what length do you think they need to be?
I really like the location. what crash bars are those and did they have a mount location already on them?
Old 01-05-2013, 09:45 AM   #82
Oddometer: 906
Ill find a sealed cap for the switch. The dimming harness will have a completely different switch.
Customer feedback will help us provide better products.
Old 01-05-2013, 09:47 AM   #83
Oddometer: 906
Yes the bracket does come with the lights and swivels left to right as well as up and down.
The mold has been delayed a bit on the PWM dimmer circuit board but it is moving along and should be available very soon. This will be a handle bar mounted on/off and 50% dimmer function switch.
Old 01-06-2013, 03:10 PM   #84
Rustykfd
IBA #44100
Rustykfd's Avatar
Oddometer: 80
My bars are Altrider. I TIG'd on some mounting tabs, I know, that's cheating.
For the harness, I don't know if there is a right length. I need about 12" more on 1 side. It will be no problem to add some where I need it.
I'm not sure it's worth adding any cost to the switch, I'm planning to trigger the relay off my high beams, so the switch is extra. I would offer a good switch as an option.
I should have them wired up soon, I will report back soon.
Rusty B
Kennewick Fire Dept
2013 IBR Rider
Rustykfd screwed with this post 01-06-2013 at 03:26 PM
Old 01-07-2013, 08:21 AM   #85
Oddometer: 906
Rusty B
Kennewick Fire Dept
2013 IBR Rider
Thanks for the feedback. The swith cover is already in the works.
Cyclops Motorsports screwed with this post 01-07-2013 at 04:18 PM
Old 01-12-2013, 09:52 AM   #86
Oddometer: 906
Its about time.
Finally got the handle bar mounted dimmer setup. I'll get one installed on my personal bike and get some photos. Looks like we have clear skies here in Seattle for a few days so Beam shots and comparisons coming your way.
Old 01-12-2013, 05:49 PM   #87
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,546
The other lights I was considering are Dually D2s. How do these lights compare to them in terms of light output (distance/width/brightness)?
Old 01-13-2013, 04:41 PM   #88
bensgone
bensgone's Avatar
Oddometer: 194
Do you have a show room in Kent?
bensgone is offline   Reply With Quote
Old 01-14-2013, 09:46 AM   #89
Oddometer: 906
Hopefully someone else with D2's and Long Ranges will chime in.
The D2's will put out more light close to the bike than the single LR, But the long ranges will shoot out much farther (approximately twice as far).. With the dual Long range in a 20 deg there is no comp in light output or distance.
Old 01-14-2013, 09:48 AM   #90
Oddometer: 906
No Im sorry we do not have a showroom..
Times are GMT -7.   It's 05:48 PM.
