Old 05-15-2014, 09:21 AM   #976
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 683
The light cut off line is crazy good.
I wonder, I have a square set of LRs, will my beak support more weight on top of the new LRs with filters
(JK Daryl, I do indeed have enough)
www.pssor.com
SOP Dirt-Rider is offline   Reply With Quote
Old 05-15-2014, 12:19 PM   #977
MaxThePanda
Psycho Panda
MaxThePanda's Avatar
Oddometer: 89
What are the dimensions and weight of the Long Range and Long Range Extreme lights?
I'm thinking of putting a pair on a KTM500 rallye-lite conversion I'm doing as main lights, mounted in a Highway Dirtbikes fairing.
Would the Long Range 10deg lights with the new covers - one wide, one spot be a good combo? Is the cutoff sufficient for street use?
thanks
MaxThePanda is offline   Reply With Quote
Old 05-15-2014, 09:01 PM   #978
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,540
thanks
Can You send me an email to info@cyclopsadventuresports.com
Then I can send you over a manufacturing drawing.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is online now   Reply With Quote
Old 05-15-2014, 09:02 PM   #979
Off Road Ryder OP
Oddometer: 2,540
Yes you do, Ive been telling you, sometimes more is too much, But Thanks for the business!!
Bike looks Fantastic!!
1-800-624-0278
Old 05-17-2014, 01:23 PM   #980
Off Road Ryder OP
Oddometer: 2,540
Filters added
We have added the filters to the long range round lights with temp photos, We will get pro photos up asap
I know you riders are wanting these
Thank You
http://www.cyclopsadventuresports.com/Lens-filters-for-round-Long-Range-lights_p_87.html
1-800-624-0278
Old 05-17-2014, 03:20 PM   #981
Imlime
Imlime's Avatar
Oddometer: 97
Probably been asked 50 times, but I can't find the answer.
Is the new H7 plug-n-play compatible with a R1200GS? If not, what is involved with installation?
Imlime is offline   Reply With Quote
Old 05-17-2014, 10:31 PM   #982
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,485
Thank You
Fantastic!
Old 05-17-2014, 10:36 PM   #983
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,485
So if one were to get a single round long range LED light to use as a low beam w/ cut off, would it be better to get the 20 degree light + the filter or the special order 60 degree light plus the filter?
Also could you post the diameter and depth of both the Long Range & the Extreme lights.
Thanks, Dan
Yellow Pig screwed with this post 05-18-2014 at 06:49 PM
Old 05-18-2014, 11:25 AM   #984
Goofy Footer
Oddometer: 511
That sounds like a cool project! I'd be very interested to see how they fit & how you mount them up. Both Paul and Darryl's products are top notch, it'd be a great combo to see the LEDs in a rally lite fairing.
Darryl, on your website I saw a review for one of the round Long Range lights where a guy said he installed one into a Trail Tech X2 light. Do you have any pictures of this by chance? It seems like an interesting option to mount them onto dirtbikes.
Goofy Footer is offline   Reply With Quote
Old 05-19-2014, 08:11 AM   #985
Off Road Ryder OP
Oddometer: 2,540
We will be doing a gs1200 install very soon, I don't suspect any issues with install or canbus.
1-800-624-0278
Old 05-19-2014, 08:14 AM   #986
Off Road Ryder OP
Oddometer: 2,540
Thanks, Dan
The filters where designed to be used with the 10 degree, or at least that makes the most dramatic change
They also work with very well with the 20, Ill get some photos up asap showing the beam differences.
The 60 most likely would not be the ticket.
1-800-624-0278
Old 05-19-2014, 08:15 AM   #987
Off Road Ryder OP
Oddometer: 2,540
Im sorry I don't have a photo of the X2 conversion.
1-800-624-0278
Old 05-20-2014, 08:59 AM   #988
Off Road Ryder OP
Oddometer: 2,540
Filter photos
I have to eat a bit of crow here and say I was very surprised in the performance of the Long Range 20 degree and the filters, since they where designed for the 10 degree I dint think they would work to well with the 20.
Boy was I wrong
The photos are extremely amateur and taken by yours truly.(definitely over exposed) Professional photos are coming once Angela can fit it in her schedule.
A truly Tunable light, these are by far the best value in LED Aux lights today. Bar None. Ill put them up against ANY light on the market.
All photos are a single light
Here is the 10 degree with the Amber wide angle filter
10 degree with no filter for comparison
20 degree with Clear Wide Beam filter
20 Degree with no filter for comparison
1-800-624-0278
Off Road Ryder screwed with this post 05-20-2014 at 04:15 PM
Old 05-20-2014, 09:03 AM   #989
Off Road Ryder OP
Oddometer: 2,540
Thanks, Dan
Sorry I missed the part about dimensions. We have been asked that quite a bit. I will post the build drawings once I can convert the files to jpeg.
1-800-624-0278
Old 05-20-2014, 08:52 PM   #990
Trickie Dick
Oddometer: 30
Filters for the Square Long Range LEDs
Did I miss this somewhere but are you planning on offering the filters for the square long range leds?
Trickie Dick is offline   Reply With Quote
Times are GMT -7.   It's 10:34 AM.
