Old 08-04-2014, 09:18 AM   #1066
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,800
Originally Posted by DSM8 View Post
I have one of the first production run sets of these lights on my bike.
After over 50K miles on the front of a V-Strom and now a 1200GS one of the lights started to intermittently blink very randomly.
Called Cyclops and explained what was happening, first thing he said was this is the first he had heard of this (now I am thinking oh well have to buy myself a new light). Then he say send it back, we will replace it not problem.
That right there is first class warranty/customer service. Without missing a beat they will replace the light (only afterwards did I find out they come with a lifetime warranty on the LED internals).
So it is going out in the mail.
I have posted in this thread on more than one occasion how much I am impressed by these lights, combine that with how Daryle (sp???) run his business and he is my go to guy for all my lighting need. ALL of my bikes are running his lights in one flavor or another.
Thank you for your business and support!!
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 08-04-2014, 10:48 AM   #1067
bracky72
Oddometer: 973
When I'm out riding with friends they report that my long range extreme lights dance around. I think it's some sort of optical illusion because they are mounted solidly. Anyone else notice this?
They also noted they were extremely bright but not annoying to them. This was at 1/2 power.
bracky72 is online now   Reply With Quote
Old 08-08-2014, 05:21 PM   #1068
Zydon
Who are these people
Oddometer: 9
Another Satisfied Customer
Yes Lord.
Hats off to Daryl and his crew. I had a bracket fail on the Stelvio and he sent another one out within an hour of notification. That is customer service pronto.......
Zydon is online now   Reply With Quote
Old 08-11-2014, 08:54 AM   #1069
Off Road Ryder OP
Oddometer: 2,800
Originally Posted by Zydon View Post
Yes Lord.
Thank you
Customer service is what has set us apart for over 10 years, we will always do our best and then some to support the products that we offer.
1-800-624-0278
Old 08-13-2014, 05:46 PM   #1070
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
so, how do we setup for buying with an ADV discount?
1Bonehead is offline   Reply With Quote
Old 08-13-2014, 06:15 PM   #1071
Off Road Ryder OP
Oddometer: 2,800
Thanks for asking
We have a very creative discount code threw the website. ADV will save you 10%
1-800-624-0278
Old 08-20-2014, 07:38 PM   #1072
sswallace
Oddometer: 42
potentially serious head issue with H7 replacements...
Just sent the following to Cyclops
Hello,
I just installed in these (H7 LED headlamp module) in my 2011 1200GS. Took it for a ride, and my low beam started blinking (high beam wasnít on). The back cap was vented, and the LED/heat sink assembly was not hot to the touch, however the little puck (not sure what it is) was very hot. Took the unit home and connected it to a 12 volt supply while sitting on my tile floor. Again, LED/heatsink stayed cool, but in 10 mins the puck was over 190F (as measured by an inferred thermometer), and it started blinking.
I moved the other unit from the high-beam to the low-beam solution. Ran it for a while on the GS, then measured the puck, it was north of 170F, and I suspect rising. Again the headsink/LED module was not hot to the touch.
This doesnít work for me, and I suspect if the pucks are running that hot while shoved with the extra wiring with the headlight assembly, itís just generally not good.
Please let me know my options.
sswallace is online now   Reply With Quote
Old 08-20-2014, 07:45 PM   #1073
sswallace
Oddometer: 42
heat issue with H7 replacements...
Hello,
sswallace screwed with this post 08-21-2014 at 09:32 AM
Old 08-21-2014, 08:55 AM   #1074
Off Road Ryder OP
Oddometer: 2,800
Really??
Why would you post 3X in both our vender threads at the same time sending us emails?
All have been replied to within 12 hrs.
There is no overheating issue with your H7 you do potentially have a defective bulb. Please return both for a refund.
1-800-624-0278
Old 08-21-2014, 09:33 AM   #1075
sswallace
Oddometer: 42
Originally Posted by Off Road Ryder View Post
Really??
Cyclops was more than pleasant to deal with WRT my concern regarding the temperature of the LED components. I believe they think the blinking unit is just an early failure, and the other unit is functioning as intended. The "puck" is designed to dissipate heat, and they say it isn't causing problems with very many satisfied customers.
The temps I posted are as accurate as I'm able to measure with my $40 infer-red thermometer. I'm guessing that lamp housing and wiring are designed to tolerate those temps.
ssw
Old 08-21-2014, 02:23 PM   #1076
Off Road Ryder OP
Oddometer: 2,800
ssw
Thank You
We are happy to answer any questions about anything here, but would prefer to keep the Aux light and light bulb threads as separate as possible.
1-800-624-0278
Old 09-01-2014, 04:07 PM   #1077
NWBoon
Oddometer: 92
AUX LED's on a DR650
Here are some pictures of a pair of 2" 10 watt Round LED Light Next Generation Prime that I mounted on my DR650. These lights are unbelievable and they look and feel "high quality." Since I'm local, I met Darryl and we discussed lighting options for my motorcycle. He picked the perfect lighting solution for me and I'm a happy and very satisfied customer.
Stock headlight low beam:
LED Aux lights:
Thanks Darryl!
NWBoon is offline   Reply With Quote
Old 09-02-2014, 01:25 AM   #1078
ItuBaba
Oddometer: 2
BUYING MY OWN PAIR - Long Range Optimus LED Auxiliary light Square
was trying to read the entire thread but found it too windy. a few questions I have are:
1. how do I get the discount as an ADV member
2. does your Skene dimmer come with the Alert
3. any lens filters or protectors for your square lights
thanks,
ItuBaba is offline   Reply With Quote
Old 09-02-2014, 08:39 AM   #1079
Off Road Ryder OP
Oddometer: 2,800
LED Aux lights:
Thanks Darryl!
Thank You A perfect fit for the DR! Those look great!
1-800-624-0278
Old 09-02-2014, 08:42 AM   #1080
Off Road Ryder OP
Oddometer: 2,800
thanks,
Thanks for asking.
Our Adventure rider code is ADV extremely creative don't you think?
We do not offer the skene 175A only the regular skene dimmer IQ175
Im sorry the filters are only available for the round long Range versions
1-800-624-0278
Times are GMT -7.   It's 05:43 AM.
