01-22-2013, 12:27 PM
#106 | |
Oddometer: 152
Fuzeblock, etc...
01-22-2013, 04:22 PM
#107 |
Oddometer: 30
So if I order the kit I get: 2 lights, a wire harness, and the dimming switch? And the switch can be wired up to have the lights come on full bright with my high beams and dimmed with my low, or work independently with the ignition off?
Just checking to make sure I have everything sorted out in my head after reading so many threads and sites, sometimes the details blend together. Thanks for the reply. |
01-22-2013, 09:03 PM
#108 | |
Oddometer: 910
Thanks for the opportunity to tell you about our products. There are 3 basic Harness options for the Long Range light kits. 1 lights only. these include a hard wired Deutch connector and a mating connector with a 6 inch lead 2. Lights with non dimmable, fused, relayed harness with Toggle switch. It is possible to add the dimmer at a later date. All Deutch connectors. (If you want a handle bar switch we can also do that) Plug and Play 3. Lights with dim-able harness. This kit includes the above mentioned 3 position switch. Off/Low/High or a 2 way switch if you want to trigger your LED high beams with the stock High beam switch, relays,Fuses, dimmer and weather pack connectors. Plug and Play There are many ways you can wire this setup 1. You can wire the lights up straight to your battery and have total use of the lights whether the bikes key is on or off, This requires the 3 way switch 2, You can wire them in so that the lights operate in low when the key is (1) off or (2) on yet trigger high with the stock high beam switch, This requires the 2 way switch If Im missing something you riders want let me know...
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI Cyclops Motorsports screwed with this post 01-24-2013 at 05:51 PM Reason: reword. |
01-23-2013, 09:41 AM
#109 |
Oddometer: 2,012
I went out to the website and can find the lights, but not the kit. Can you advise on pricing and how to order?
Tim Bowman Burien, WA tk.bowman@comcast.net
Tim in Burien, WA '05 R1200GS (Sleeping in Germany) '03 F650GS '03 Wing '01 ST1100 |
01-23-2013, 12:21 PM
#110 | |
Oddometer: 910
The different harness and light configurations are in the drop down Option menu for the single Long Range light. We haven't added the dimming harness yet due to having a tough time just keeping up with orders. Right now the dimming harness is hand made one at a time. I"ll get that done here in the next few days. Your local. I'm more than willing to drop a set by for you. If anyone has thoughts,ideas or even special request, I am all ears. We make custom kits all the time. Pricing: Optimus Single - $139 Optimus Single Kit (2 qty. Optimus Single lights with basic Wiring Harness) - $259 Optimus Dual - $239 Optimus Dual Kit (2 qty. Optimus Dual lights with basic Wiring Harness,No dimming) Plug and Play- $459 Dimming harness with handle bar mounted switch is 69.95 This harness option takes the place of the basic harness. For now these are not on the site but available threw a pm or call.
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI Cyclops Motorsports screwed with this post 01-24-2013 at 05:55 PM Reason: clarity |
01-24-2013, 09:30 PM
#111 | |
Oddometer: 152
Optimus Dual... Any Pics? + Wiring
1)- You are mentioning Optimus Dual... I can't find any pics on the site... Could u post a pic or two here with dimensions? 2)- Also, could those lights (single or dual) be wired to the factory High/Low beam without the need of a separate switch? So, who else is having a tough time deciding on what to get and what have u all decided? Two 10s or One 10 and One 20? Hard to make up my mind. Thanks for your help. |
01-24-2013, 09:38 PM
#112 | |
pass the catnip
Oddometer: 7,569
01-25-2013, 08:49 AM
#113 | |
Oddometer: 910
Out of those 3 lights the only one that I would consider a high speed light is the Squadron. I have some in stock, so getting a photo is just a matter of having decent conditions to get a picture. The long range will shoot a beam considerably farther than the squadron, however will not put out as much light close to the bike. I know other Long Range customers have compared and relayed their thoughts on the Ds to me, hopefully they can post up here.
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI |
01-25-2013, 03:59 PM
#114 | |
pass the catnip
Oddometer: 7,569
twinrider screwed with this post 01-25-2013 at 04:10 PM |
01-28-2013, 09:00 AM
#115 | |
Oddometer: 910
You can tap into your high beams for the high portion, But most likely would want a switch to turn the LEds on and off. If you have a low beam or other power source that is switched and stays on when the high beam function is engaged then you could wire them in with no extra switches.
01-28-2013, 09:15 AM
#116 |
Westside Trash
Oddometer: 719
Light bar vs. Optimus 2
Could you give us an idea of how the optimus 2 compares to your next generation light bars, specifically distance of beam?
01-28-2013, 01:13 PM
#117 | |
Oddometer: 910
In total distance a set of dual optimus provide usable light at more than 900 ft. Flat out the most distance of any LED aux light. The 4 up NXG light bar in 10 deg has approx a 400 ft range. The light bar will provide more light up to the point of fall off.
01-28-2013, 05:06 PM
#118 |
Oddometer: 910
An advantage to having longer throw lights is that you can always aim them down for more brightness closer to the bike, then if you ever really need more distance its easy to pull them up a bit and enjoy much farther distances,
01-28-2013, 06:29 PM
#119 |
Oddometer: 910
Light Photo comp.
I did"t have time to throw up the markers, but took these photos at the same location as the other photos in this thread. I will be adding lights and better photos in the future.All photos taken within 5 minutes of each other with the same camera settings.
The trees in the distance are at 350 ft. The trees are at 350 ft. I really need a longer spot to really show the distance in the Long Range capability. The commentating is my personal professional view, take it for what value you feel its worth. Dual Long Range set 40 watt draw 2 lights shown ![]() Baja Designs Squadron. single. Nice light, we also sell this 43 watt draw 1 light shown ![]() Single Long Range Dual 20 watt draw 1 light shown ![]() ADV Monster Model 60 28 watt draw according to reseller This light puts out a Good amount of light, Quality is less than stellar, Distance is Ok for slower speeds 1 light shown ![]() MondoMotos MM 10 10 watt draw 20 deg beam,decent build quality 1 light shown ![]() Single Long Range 10 deg 10 watt draw 1 light shown
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI Cyclops Motorsports screwed with this post 02-11-2013 at 03:54 PM Reason: clarification and power draw change |
01-28-2013, 08:07 PM
#120 |
Westside Trash
Oddometer: 719
Nice!!!
Impressive pics! Were the pics of the optimus lights taken with a pair of lights, or an individual light?? Also, was the squadron light shown in the pics a 10 degree spot ?
