Old 01-16-2013, 09:17 AM   #61
VFR
VFR's Avatar
Oddometer: 760
Originally Posted by MacG View Post
I see several mention the Exped Synmat 9. Has anyone compared it to the Synmat 7? It packs smaller,I was wondering if the difference in performance/comfort was worth the extra size on a longer trip on the bike.
I believe the R-value is the same for both. The 9 is both wider & longer so you're not as likely to roll off it if you thrash around a bit at night like I do. I use the 7 because it packs smaller. I found after changing from the Big Agnes--which slipped & slid all over--that I didn't roll off of the Exped.
If you are a bigger guy, you might want to go for the 9 just to make sure you are fully on the mattress. Pack size isn't that much different but I have a space problem (sportbike) so I go with the 7.
Larry
If it ain't fun, I don't do it!!!
Stuff - I need more Stuff....
VFR is offline   Reply With Quote
Old 01-16-2013, 12:46 PM   #62
MacG
MacG's Avatar
Oddometer: 254
Thanks VFR, I'm 5'11", 195 lbs so average size I guess. I have the short BA(non insulated) now and it's ok except for colder nights. I usually sleep in a hammock but occasionally I'm on the ground. Packed size is an issue.
09 KLR
97 DR650
MacG is offline   Reply With Quote
Old 01-16-2013, 01:23 PM   #63
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Had em both, ex used the 7 and I had the 9. Side by side the packing dimensions weren't much different. Maybe a half inch taller and wider for the 9. But the extra 6" width and extra inch of thickness was nice for me.
It depends on how large you are. Also, I was using the 9 in a Summit Park sleeping bag.
HaChayalBoded is offline   Reply With Quote
Old 01-16-2013, 01:29 PM   #64
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
Originally Posted by Dan Alexander View Post
The trouble with BA is if you want a wide pad you have to buy the Park series bags and they don't pack down very small.
I use the Exped Downmat now and use a Thermarest sheet which has attachment points for the Thermarest quit so no wasted sleeping bag on the bottom that you don't need to carry around. Packs small and it's nice to have the sheet that is seaily removeable for washing.
Here's the sheet
http://cascadedesigns.com/therm-a-re...-sheet/product
and the Alpine blanket
http://cascadedesigns.com/therm-a-re...ket-35/product
And if I want real comfort I slide in my BA memory foam topper between the matterss and the sheet
I sold my neoair because it was too much trouble to inflate and for some reason I sweat a lot on that fabric
I see they have new pumps this year, about time.
Been thinking of getting that setup, any problem with drafts?
Old 01-16-2013, 03:16 PM   #65
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,574
One thing to keep in mind is if you are a side sleeper, as I am, you'll want that extra 1" of thickness. My first mattress was a Thermorest, and I ditched it after my first week of camping off the bike. My goal now is to find a smaller pack size pillow...I have a very nice memory foam pillow I have been taking with me, but I would like something that packs a wee bit smaller. I was at REI looking today, but with no luck. The search continues..........
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is offline   Reply With Quote
Old 01-16-2013, 04:58 PM   #66
Twohondas
Twohondas's Avatar
Oddometer: 1,205
Larry knows what he is talking about. MC Camps a lot!
I have been thru most of this stuff too. Started with Thermarest when I was younger then REI brand but bigger, then back to Thermarest but bigger (a trend maybe), then BA (thicker and insulated) and recently added a "high tech" Colemen twin air mattress for my Wing tours. May even figure out how to pack with the VFR/KLR. I use my BA on top of that for cold stuff.
There is a theme here......I may have to use some statistical algorithm to figure it out. Something like this perhaps...the size of pad is directly proportional to ones age. Larry is tougher than I am! I have had the same issue with tents
I always read threads like this to find the next answer. Looks like I am back to what I started with when I took up car camping again back in the sixties.
Twohondas is offline   Reply With Quote
Old 01-17-2013, 05:45 AM   #67
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,794
My Big Agnes Summit Park has an integrated pocket that you can stuff a fleece into for a pillow, or use their pillow, fits right in the pocket so you don't "lose it" at night
https://www.bigagnes.com/index.php/P.../AirCorePillow
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 01-17-2013, 06:51 AM   #68
Okie Preacher
Okie Preacher's Avatar
Oddometer: 911
Love it! http://www.backcountry.com/nemo-equi....-fillo-pillow
Okie Preacher is offline   Reply With Quote
Old 01-17-2013, 06:56 AM   #69
Gezerbike
Gezerbike's Avatar
Oddometer: 3,574
Saw it, tried it out but it won't cut it. I'm currently using a memory foam pillow that is pretty firm and works like a charm.. I might not be able to find something smaller that works as well. Drawback is that it is pretty large, though it will compress down to pretty much nothing. I did see an inflatable pillow with a chunk of memory foam incorporated, but I have not seen it in person. As mentioned before, I'm a side sleeper and the pillow is important. Waking up with a stiff neck first night out of a 10 day trip is a bummer. And as you get older, the longer it takes to recover.........
Mike
Gezerbike screwed with this post 01-17-2013 at 07:53 AM
Old 01-18-2013, 09:21 PM   #70
VFR
VFR's Avatar
Oddometer: 760
Pillow!!! Did someone say pillow??? I have about sixteen of 'em--feather, foam, inflatable foam, combinations of the above--Finally found the solution. Exped!!! They make an inflatable pillow that folds as small as a Red Bull can--no kidding. Expensive? Yes, ~$35 but it inflates in about 3 or 4 puffs & is seriously comfortable. Sleeps warm too. After you buy as many as I have, trying to get a good one, $35 is nothing.... I usually fold my riding pants & put the pillow on them to make it thicker. Forgot that.
As to the thick mattress, I'm a side sleeper & have no trouble with either one. When inflated & you sit on it, it goes flat, but sleeping spreads your weight out so you don't even feel the rocks under your tent.
There are two other guys on this thread that might have as much gear as me. You know who you are....
Larry
Old 01-19-2013, 05:29 PM   #71
Gezerbike
Gezerbike's Avatar
Oddometer: 3,574
I looked at it at REI, nice and small, but inflated it still seemed small. Then I went in to the local LL Bean store and saw a pretty neat inflatable pillow. On sale from $ 25 to $20, I had a $ 10 buck coupon and I got a little more off and was out the door for $ 7.23. Bigger inflated than the Exped, has some foam involved and seems pretty comphy. I'm gonna try using it in combo with my Airhawk cushion and see what I get. If it doesn't work, it will be the cheapest pillow ever sold on this site
http://www.llbean.com/llb/shop/65550...comfort-pillow
Mike
Old 01-19-2013, 07:18 PM   #72
mwood7800
Oddometer: 611
I have the park down bag and its packs extremely small. My BA bag and pad are as comfy as my bed at the house. And the BA insulated pad is 1/2 the price of the exped
mwood7800 is offline   Reply With Quote
Old 01-19-2013, 07:50 PM   #73
ZZ4Blazer
Oddometer: 301
Which ba pad?
"homesick for a place Ive never been"
'13 Triumph Tiger Explorer 1200
08 Yamaha WR450F - woods/adventure monster in the making
ZZ4Blazer is offline   Reply With Quote
Old 01-19-2013, 08:08 PM   #74
mwood7800
Oddometer: 611
https://www.bigagnes.com/Products/De...sulatedAirCore
Old 01-19-2013, 09:06 PM   #75
VFR
VFR's Avatar
Oddometer: 760
Exped has a larger one. Not sure if it is thicker, but it is wider. I tried the inflatable foam one & didn't care for it. Probably just me, I don't like sleeping on foam. Also doesn't pack real small--very important for me.
Larry
Times are GMT -7.   It's 11:30 AM.
