11-20-2012, 06:29 AM
#91 | |
Oddometer: 745
oh, or a scooter. neither requires this "work on" thing you've mentioned.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
11-20-2012, 07:22 AM
#92 |
Desert Rat
Oddometer: 975
I do all my own maintenance. This is one my main considerations when looking at bikes. For example Silverwing 15miutes to change air filter and spark plugs. Vstrom two hours requires removing fuel tank, fairing and moving radiator. Klr 15 minutes to do the job.
If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got. http://advrider.com/forums/showthread.php?t=851060 ... A desert rat explores the south. |
11-20-2012, 08:07 AM
#93 |
Oddometer: 4,096
From my experience, scooter tend to require maintenance more often than motorcycles and getting to things are complicated due to all the plastic. However, this varies from scooter to scooter as well as motorcycle to motorcycle.
Valve adjustments in particular can be very complicated on a scooter due to all the body work. Adjusting the valves on my KLR is easier than on my Sport City 250. This, despite the fact that the Sport City has Screw & Locknut adjusters and the KLR uses shims. Luckily, neither requires valve adjustments that often. On my Kymco on the other hand, Valve adjustments are very easy, but are required every 2500 miles. I have read that the valve adjustment on the Burgman 400 is very time consuming so you may want to look into that. |
11-20-2012, 08:19 AM
#94 | |
Oddometer: 745
4 bolts and the entire rear of my cheap chinese scooter comes off, engine is -right-there-. the drz takes longer to change throttle cables than I think the entire scooters assembly time.
11-20-2012, 01:24 PM
#95 |
Oddometer: 47
Interesting thread. My everyday ride is a Vespa GTS 250 and I also have a Triumph Tiger 800. I've had 2 or 3 other scooters and a selection of Honda and Ducati motorcycles over the years and I can say with confidence that the Vespa is my all time favorite daily ride. With a Givi topbox I can fit a week's worth of groceries or use the bike for riding into downtown Denver and parking just about anywhere.
While I love the Vespa, I have not been able to find a real maxi scooter that I prefer over a motorcycle. The T-Max comes close as do the Piaggio and Aprilia 500's, but I'm not sure the latter 2 are really maxis. I'm hoping the new BMW's do the the trick but right now I'm still very happy with the Triumph. I think most of the positives and negatives have been covered already. The only thing I'd emphasize again is that the standard scooter riding posture isn't always comfortable for long stints in the saddle. You need to make sure you're actually comfy on whatever scoot you decide on. It helps if there's room on the floorboards to move your feet fore and aft. It also helps to take a long test ride. Good luck! |
11-20-2012, 01:53 PM
#96 |
UR12
Oddometer: 899
Heck, I rode motorcycles for years. I have been riding a scooter for a while now because of a bad back
I saw a motorcycle in the local shop I sure would like to have. Its a 2007 Honda Shadow Spirit with 3500 miles. The seat height is only 25 inches high. Surely I could get my leg over it.. http://www.castlepowersports.com/new...11&pov=2828017
Kymco People S 250 2011 Suzuki Blvd S40 650 hexnuts...a curse put on your balls by a mean gypsy 3/5 Cav, C Troop, BlackKnights, Vietnam 1969 hexnut screwed with this post 11-20-2012 at 02:09 PM |
11-21-2012, 06:47 PM
#97 | |
Oddometer: 24
Yes, you can ride at interstate speeds for hours on end. I completed a SS1000 last June on mine and felt it was extremely comfortable. Much like a barcalounger. :) While I've put 70,000 miles on a Burgman 400 in the past few years commuting north and south on I-5 in Seattle, I also take it for day long trips in the state. Those are 300-400 mile days. It does camping well, because you have 62 liters of storage space under the seat...and then you can load up a top box and the pillion. If you're interested in cruising at "high" interstate speeds...like 15-20+ mph over the speed limit, you probably should look elsewhere. It'll do it, but you'd be better off with an ST1300...till you lose your license. ;) The oil burning you've heard about is primarily with the 2006 and earlier model 400. Some did it, others didn't. But at sustained high speeds, they would suck oil back up through the air cleaner and burn a lot. The engine (as well as the rest of the bike) was totally redesigned for 2007, so that problem is pretty much been eliminated. My "drop" from a bike to a scooter had about 20 year in between, so I can't really speak to that. But like everyone else, I like to look at bikes and think of what would it be like. I haven't found any bike better yet. Each bike will do something perhaps better, but the total package is a compromise with what I already have.
Chris |
11-22-2012, 08:34 AM
#98 |
Oddometer: 1,741
@ Daboo, well said.
11-22-2012, 05:01 PM
#99 |
Cheese, Gromit?
Oddometer: 3,277
That's some excellent evidence. If you need to ride mixed roads, keep the KLR. If your riding is mostly on pavement, the Burg will treat you well. We all need to adapt the ride to the road. In this case, the Burg may be a good match.
I never felt like a sissy on a scooter. I still have great admiration for the SYM HD200. If I rode that machine correctly, I could leave most of the pack in the dust. It had 175 cc's. It returned 72 mpg. If a scooter is something you're comfortable with, be comfortable on a scooter. They are outstanding machines.
We have no resources. We produce nothing. But...we have plenty of MEAN. Fearless Leader Motorcycle Racks Handmade in the US! Support a fellow Rider! Dual Sport Luggage Racks for: DRZ-S, SM and E, DR 650 and KLR650: http://www.moto-racks.com |
11-28-2012, 03:21 AM
#100 |
Outside the Pod-bay
Oddometer: 1,431
If the cut-out between your knees is not so important and YOU want more in the way of a motorcycle, then this may suit you better:
![]() Honda NC700D Honda NC700 OC Forums
'77 BMW R100RS with Ural chair '08 Suzuki AN650A Burgman (and trailer) |
11-28-2012, 03:15 PM
#101 | |
“Until one has loved an animal, a part of one's soul remains unawakened.” -- Anatole France 2010 Gold Wing/ABS 2000 Kawasaki W650 |
11-28-2012, 03:25 PM
#102 | |
Oddometer: 2,072
That certainly blurs the line between scooter and motorcycle. Too bad it's chain drive and not even an enclosed chain.
11-29-2012, 12:54 AM
#103 | |
Outside the Pod-bay
Oddometer: 1,431
BMW are just introducing a sporty and a tourer types in the 650cc engine size maxi-scooter category. Just SIX years ago, Honda showed their concept that has never materialized- ![]() 1600 x 1200 pixel picture of left side E4-01 rear hub --- its a shaftie! 1600 x 1200 pixel picture of E4-01 dash - it has an Airbab & integrated GPS! ![]() Under seat space for two jet-style helmets 17" wheels and a 903cc inline triple liquid-cooled engine. Instead of THIS they marketed the DN-01, to be followed by that chain-driven Integra with 51HP (or 47HP) 670 cc a 270˚ crankshaft V-Twin engine and its 15 litres (0.53 cu ft) of under-seat storage.
11-29-2012, 06:22 AM
#104 | |
11-29-2012, 06:49 AM
#105 |
Oddometer: 2,072
When I compare the Burgman or the Integra or any other maxi scooter to my old Silverwing Interstate (motorcycle) I just don't see a big advantage to the new designs that would justify the cost of an upgrade. Weather protection to the legs and feet are better on the maxi scoots but that difference could be minimized with fairing lowers on the old SWing. Weight, horsepower, storage capacity, fuel capacity are all similar. The SWing has shaft drive, large wheels with tubeless tires, air adjustable shocks, and easy (and low) maintenance since the engine is out in the open. EFI is nice but IMO they haven't made any huge advancements in technology in the last 30 years.
