Old 11-06-2012, 09:37 AM   #1
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Cracked Luggage
This appeared after my last trip.
The pannier is made of some sort of plastic and the crack is located at a stress point, obviously.
How to repair this? Currently, I'm thinking of using JB Weld on both sides of the crack reinforced with some kind of rigid material. Is there some way to weld the crack?
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 11-06-2012, 09:41 AM   #2
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,644
Stitch it with stainless wire, seal the crack and wire holes with JB weld.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 11-06-2012, 09:42 AM   #3
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,001
It may be weldable depending on what kind of plastic it is. Look for a mark that tells you. A fair number of motorcycle shops can weld plastic.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 11-06-2012, 02:47 PM   #4
74C5
74C5's Avatar
Oddometer: 948
+1
i.e. safety wire.
Works friggin' awesome on seat tabs for dual seat bikes where only the rear is locked down and the tongue on the front one keeps it from falling off.
Other than that, rivet on some doublers on at least one side.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 11-06-2012, 05:30 PM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Is that from your Connie? It doesn't look familiar to me. I punted one off when I pulled out around a car in a traffic jam, forgot how wide Connie's ass was. Broke the aluminum bracket off, bag went airborne, my nephew behind me cought it with one arm while riding his Suzuk with the other, lol
Anywho, I'd vote for doublers as well, riveted and sealed.
Old 11-06-2012, 05:34 PM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,768
Safety wire and hot glue, painted black and it has held for 10K miles and three years.
Jim
Old 11-06-2012, 06:16 PM   #7
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,737
If the plastic is ABS (which most bike parts are) the best glue type is a Methyl Methacrylate based adhesive. Permatex Permapoxy 5 min plastic weld, item 84115. It comes in a handy two part applicator and is reasonable.
This welds/melts to the ABS and does not sit on top as JB Weld and other general epoxies and plastic adhesives do. It bonds to and forms part of the methacrylate in the ABS. Your neighborhood stores will not carry it as it is specialized. Buy it on-line. Follow the instructions - you only have 4 minutes set-up time. The Loctite equivalant is H3000 which is an industrial only packaging that needs special applicators. That together with some 'stitching' will make a very good bond. Its color is near opaque and will go yellowish in time. After full cure it is paintable with plastic type spray.
Tsotsie is offline   Reply With Quote
Old 11-06-2012, 06:40 PM   #8
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
I see the Permatex on Amazon for less than 8.00.
I watched a video of a repair made using this product and was impressed, though not by the price.
http://www.urethanesupply.com/PlastiFix/
I don't need to be in a hurry to fix this so it's turning into another learning experience for me. There are some very interesting methods used.
Also, it's looking like the Connie will be for sale before too long so the repair needs to look spiffy.
bwanacswan's dad
Old 11-07-2012, 01:54 AM   #9
squish
Out of the office.
Oddometer: 6,164
I've not done it but I have heard of folks taking abs grinding into a dust, mixing the dust with abs glue from the plumbing section. Using that as a glue past to both fill the crash and hold the parts together. Using abs sheet to back up the crack.
On vacation for a spell
squish is offline   Reply With Quote
Old 11-07-2012, 11:27 AM   #10
Tsotsie
Oddometer: 1,737
There are supposedly 2600+ types of plastics. Unless you get the specific adhesive for the plastic 'family' they dont really work - sit on top. General epoxies etc claim to adhere plastic, but they do not.
If you dont want to 'stitch' it together as well, cut a V trough on the inside along the split line. Sand the area along V where you will apply the adhesive with 60 grit paper and apply the adhesive as a filler and 1/4" on either side. An $8.00 or less tube of spealized adhesive is a lot cheaper than new plastics.
Old 11-07-2012, 07:20 PM   #11
ibafran
villagidiot
Oddometer: 1,287
I cracked the plastic fairing on my 05 Tri Sprint. Super glue made a good bond. I used the super glue and plastic beads that the nail techs use for manicures. Spent about $30 at Sally's Beauty Supply with plenty of left over for the next crash.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 11-07-2012, 09:14 PM   #12
usgser
Oddometer: 2,138
Before you repair it I suggest you stop drill the ends of the crack.
usgser is offline   Reply With Quote
Old 11-08-2012, 12:31 AM   #13
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Originally Posted by JimVonBaden View Post
Jim
If Tim Burton owned a body shop.
bwanacswan's dad
Old 11-08-2012, 01:10 AM   #14
KtmPedro220
KtmPedro220's Avatar
Oddometer: 69
Quite a good job by JimVonBaden.
KtmPedro220 is offline   Reply With Quote
Old 11-08-2012, 08:16 AM   #15
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
The stuff I bought to fix ABS doesn't work, so I guess it isn't ABS. There are no symbols on either bag indicating the type of plastic. It seems that plastic can be identified by testing it for buoyancy and burning it to detect certain odors. Meh.
If the plastic is polypropylene, as I suspect, then welding is said to be the only reliable repair.
Plastic welding can be done using hot air, direct heat, or an ultrasonic welder.
There are direct heat welders that look a lot like soldering irons. Hot air is like a heat gun. Ultrasonic units look like big money investments.
It's possible to buy welding rods of like plastics though some Youtube videos show welding without this.
Drilling a stop at the end of the crack would be a good idea if it was to glued. It the weld is done correctly, there will no longer be a crack.
bwanacswan's dad
Times are GMT -7.   It's 02:47 AM.
