Old 11-08-2012, 04:24 PM   #1
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
Warm and Safe Remote Heat Troller ??
Getting my heated gear out and ready for a ride. I have Warm n Safe gear with a heated jacket liner.
I'm using the remote heat troller. No LED light and no heat. Check the power from the battery. But the instruction say
to replace the little watch battery. And they say to remove the screw and remove the lid.
Well, so far I'm not sure which part they're talking about. I have'nt found anything with a lid.
Where's the little CR2032 battery at??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 11-08-2012, 04:51 PM   #2
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,430
It's in the remote that you mount on your bike or wherever. The receiver (which is actually connected to your jacket) gets its power from the bike battery, so it doesn't need a watch battery.
If you have the latest and greatest, then the remote has 4 tiny screws to remove and then you take off the whole bottom plate. But, it takes 2 AAA batteries, I think. I have not personally seen the older model that uses a CR2032, but I would expect it to be similar. Whatever screws you can see on the remote - take them out, then remove whatever part comes off. You'll probably see the battery you need to change.
All that said, unless the older stuff is different, when you plug the receiver into the bike's battery (and have it connected to the jacket), it should turn on to 1/3 power, even if the remote is totally dead. If that's not happening, then your problem might not be the remote at all. But, as I said, if the remote is the kind that takes a watch battery, it MIGHT not work like that. I only know that the new ones (what I have) DO work that way.
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 11-08-2012, 05:24 PM   #3
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
Thanks, guess I'm gonna have to put my glasses on to see the little screws.
Yes the instructions said a CR battery or 2 AA's, depending on how old it is.
And I do have 1/3 power, I can tell that much, just enuff heat to tell you have it.
Old 11-08-2012, 06:00 PM   #4
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,393
Really? I got mine when they first came out. Mine has the little battery, and yep. twice I was caught out. It's an awesome set up, but AA batteries would make it better.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-08-2012, 06:44 PM   #5
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
Well, I must be a real dummy. I bought this from W N S late last year. And I don't have the battery remote.
I've got the newer kind that is hard wired to the bike, so it doesnt even have a battery.
So, I've test lighted the plug and its hot, but the individual on/off (have the dual controler) controls don't seam to be working. I can turn them on, but no LED light and no coat warmie.
Any ideas??
Old 11-09-2012, 01:09 PM   #6
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,430
Any ideas??
Doh! You had me confused. So, you don't have the wireless remote. You just have the dual remote.
The only thing I can think of is to make sure you have the battery harness attached with the correct polarity. I.e. make sure the red wire is to the + terminal on the battery and the black wire is to the - terminal.
If that's not it, then send a PM to heat-troller_mike on here.
- Stu
Old 11-09-2012, 01:10 PM   #7
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,430
Originally Posted by John Smallberries View Post
Did you do the sync procedure to get the remote to talk to the controller in the jacket?
http://www.youtube.com/watch?v=Fv5fzjqVkjY
He said he does not have the wireless remote. So, no sync procedure for him.
- Stu
Old 11-09-2012, 01:11 PM   #8
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,430
Unfortunately, you still need a jeweler's sized phillips head screwdriver to get the cover off to change the batteries...
- Stu
Old 11-09-2012, 04:02 PM   #9
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,430
Ah. Right. If he has that then, yes, indeed, he does need to sync them.
I also just saw that WnS now has a new version of the wireless remote that has a coax power plug and a separate battery harness. So you never have to worry about your CR2032 or AAA batteries dying on you. I just got my wireless setup. Now I kinda wish I had gotten that, instead. I don't know. I guess there's advantages to both... I do like the ease of which I can go from bike to bike and still use my heated gear - even on a borrowed or rented bike, as long as it has a coax or SAE or Widder or Powerlet connection somewhere that I can plug into.
- Stu
Old 11-18-2012, 05:54 AM   #10
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,915
uhh, didja check the fuse....... on both the remote power cable as well as the cable going to your jacket.
If that's good then resync it.
HaChayalBoded is offline   Reply With Quote
Times are GMT -7.   It's 02:36 AM.
