Old 11-13-2012, 05:04 PM   #16
Wattner
Wattner's Avatar
Oddometer: 5,348
CycleWizard to the red phone!
Cyclewizard@aol.com for anything and everything XR/L.... He can make one for you
Wattner is offline   Reply With Quote
Old 11-14-2012, 11:10 AM   #17
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Originally Posted by sh0rtlife View Post
589 lol...i was soooo close
ok soo in my hunt for the right slug....if i do have to go up in compression what piston do i need?....soo bloody confused its annoying me
im guessing as i dont have my book in front of me...stock is 97mm so i need a 97.5 or a 98...can the stock sleeve handle 98?
98mm in no big deal at all! I bore XR600s to 100mm (628cc) all the time. Some people will even go to 101-2mm but unless it's a total effort race engine 100mm is as big as I like to go (on the stock sleeve).
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 11-14-2012, 01:18 PM   #18
brucifer
brucifer's Avatar
Oddometer: 2,469
Stock XL600 bore is 100 mm. They have a short 75 mm stroke.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 11-14-2012, 05:18 PM   #19
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Oops, I think he's right.
Old 11-16-2012, 09:58 AM   #20
sh0rtlife OP
Oddometer: 796
ok that makes no sense ....no way the stock bore is 100mm..everything ive found says its 97mm...or is that part of the change from 83 to 85?
sh0rtlife is offline   Reply With Quote
Old 11-16-2012, 12:46 PM   #21
mcma111
mcma111's Avatar
Oddometer: 12,386
You either need to put the pipe down or put some glasses on. The XL600r uses a 100mm piston. The XR600r uses a 97mm piston. The XR650l uses a 100 piston. Have you even measured the cylinder??
http://www.wiseco.com/ProductSearch.aspx
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 11-16-2012 at 05:17 PM
Old 11-16-2012, 03:52 PM   #22
RubberSideUp
Oddometer: 32
Do you have an XR engine, possibly, or an XL bottom end with an XR (97mm) cylinder?
RubberSideUp is offline   Reply With Quote
Old 11-20-2012, 09:49 PM   #23
sh0rtlife OP
Oddometer: 796
ok..ive verifyed it is a 99.5mm piston that was in there..or was..the bore now is a 100mm
odd my manual states it should be a 97mm bore....ahh well this makes things simple now LOL
sh0rtlife screwed with this post 11-20-2012 at 10:18 PM
Old 11-21-2012, 02:56 AM   #24
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
Go with the big bore kit. I eat up XRLs all day. not sure of the size i got, the receipt the PO gave me is unclear on the size, just says "Wiseco hi-comp." All I know is it likes 91 octane and when I roll back on the throttle, it is pure exhilaration for a single lung bike.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 11-21-2012, 02:59 AM   #25
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
Go with the big bore kit. I eat up XRLs all day. not sure of the size i got, the receipt the PO gave me is unclear on the size, just says "Wiseco hi-comp." All I know is when I roll back on the throttle, it is pure exhilaration for a single lung bike. on the street the front end just rises right up and im running the stock gearing
Old 11-21-2012, 11:02 AM   #26
sh0rtlife OP
Oddometer: 796
i allready had a problem keeping the front down on the street and the rear under me off road....
anyone else find it weird that the slug i removed was 99.5mm...my brain just cant wrap around that if the stock xl bore is 100mm how did it have a 99.5 in it
Old 11-21-2012, 11:54 AM   #27
mcma111
mcma111's Avatar
Oddometer: 12,386
How old is the picton, Miles?? Most likely the piston is a 100mm but has shrunk from wear. They do that ya know. The wear out bit.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 01:56 PM   #28
sh0rtlife OP
Oddometer: 796
but that doesnt explain the bore cleaned and ready to roll for the next slug comming out at 100mm
Old 11-21-2012, 03:43 PM   #29
mcma111
mcma111's Avatar
Oddometer: 12,386
Sure it does. What's harder? The steel cylinder sleeve or the alloy piston? Who measured the piston and cylinder? You or a machinist?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-21-2012, 03:47 PM   #30
mcma111
mcma111's Avatar
Oddometer: 12,386
I have a mid 80's XR600 cylinder that has a 100mm Wiseco piston in it. This is used but in very good condition. Just give the cylinder a ball bone and order a new set of rings. I have the hone. You'll be set. Yours for $100.00 + shipping.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 01:10 PM.
