01-05-2013, 04:41 AM
#166 | |
Air cooled runnin' mon
Oddometer: 6,112
Are LED headlamps in use yet? Wouldn't they be even more efficient?
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
01-05-2013, 05:27 AM
#167 |
Yeah! I want Cheesy Poofs
Oddometer: 17,772
01-05-2013, 06:41 AM
#168 |
Just the Facts Ma'am
Oddometer: 31,900
I'll bet they cost more than that. You're talking price.
I'm just lookin' for clues at the scene of the crime. "The urge to save humanity is almost always only a false-face for the urge to rule it" H.L. Mencken |
01-05-2013, 10:24 AM
#169 | |
Woolf Barnato
Oddometer: 29,130
A gasoline heater like the old VW option would be nice.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
01-07-2013, 07:55 AM
#170 |
Woolf Barnato
Oddometer: 29,130
I drove from Oakland through San Francisco to Marin and back to Oakland yesterday. It's a good mix of highway and city driving with plenty of hills. 40 miles on the battery. When the battery was discharged I set it to "Mountain Mode" which charges the battery enough to allow a reserve for driving in, well, mountainous areas. Even when the battery indicator shows zero miles range, the battery is not fully discharged. There is a small amount of reserve to assist acceleration. If you are driving under high load using the range extender, gasoline engine, you could run out of that reserve. This will reduce speed and acceleration so, "Mountain Mode" is designed to increase that reserve.
Anyhow, in about 15 miles of "Mountain Mode" on level ground at freeway speed, the battery was almost 1/2 charged. I filled the gas tank because I felt like it. The dash gauge indicated 4.2 gallons used in 1400 miles. The pump indicated 4.25 gallons. Pretty accurate.
01-07-2013, 08:47 AM
#171 |
Oddometer: 31,096
The last thing the Volt needs is another fire source.
VW has been equipping its cold weather Jetta TdI's with aux electric heaters. They put out 500-600 watts or so and give instant heat. A couple folks have added them to gas cars. |
01-07-2013, 09:03 AM
#172 | |
Remastered Classic
Oddometer: 4,536
The Air Force has already purchased some Volts, as well.
There. Their. They're not the same. (By reading this, you have briefly given me control of your thoughts) When life gives you melons, you might be dyslexic. |
01-07-2013, 09:20 AM
#173 |
Oddometer: 745
Awesome enough with just the drive description, but then icing too.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
01-07-2013, 09:21 AM
#174 |
Oddometer: 4,260
#175 | |
Oddometer: 745
01-07-2013, 09:28 AM
#176 |
Holding up Michoagán
Oddometer: 1,390
The new 2013s have a HOLD feature for the battery- you can run on the engine with a full battery. This is good if you know you have city driving at the end of your trip, where electric motivation is most efficient.
However, this can also be known as the 'instant heat' button, running the engine immediately, and producing lots of 'waste' heat. I have a 2012, so I don't even have a HOLD button. ![]() If you have a partially empty battery, you can use mountain mode as a hold feature (but only past the battery level as designed by GM - about 67% used) You need heat in the SF area of California??? ![]() (I bout froze my ass off once in July looking at that orange bridge. That felt colder than Ohio in December) |
01-07-2013, 09:31 AM
#177 |
Remastered Classic
Oddometer: 4,536
The military in general is looking at and embracing the use of hybrid and electric vehicles on a very large scale. The military uses far more fuel than the other federal branches.
01-07-2013, 11:01 AM
#178 |
Oddometer: 745
I thought the military liked diesel for its simplicity and stuff ?
01-07-2013, 11:05 AM
#179 | |
Remastered Classic
Oddometer: 4,536
Plus, in combat areas, running on electric only can be an advantage in regards to low acoustic signatures. I think the Volts will primarily be staff cars for the higher ups, although I think there was something about the recuiters using them too. They put down some serious mileage in their job.
01-07-2013, 11:07 AM
#180 |
Oddometer: 31,096
| Thread Tools | |
