11-12-2012, 11:31 AM
#61 |
Woolf Barnato
Oddometer: 29,146
I like the way it drives. It feels like some attention has been paid to the driving dynamics. Firm but not harsh. The tires a sort of loud but they are low rolling resistance and at 38 psi. Sport mode is fun, quick throttle response and strong acceleration.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
11-12-2012, 12:27 PM
#62 | |
Holding up Michoagán
Oddometer: 1,393
Totally agree +eleventymillion with Anorak. It drives nothing like a crapwagon. I have a feeling that a lot has to do with all the weight in the middle and down low. Also, the battery belly plate should add a lot of rigidity to the chassis. Maybe I'm off my nut, but my first thought was, "This drives nothing like any other front wheel drive car I've ever driven." I traded in a BMW X3, and was impressed. Anorak- bump your tires up to 40, and you may just gain another mile or two off the battery. |
11-12-2012, 05:30 PM
#63 |
I know better
Oddometer: 6,646
My last ride was a 335d with sport suspension. So the Volt won't handle the twisties like the BMW, but it's extremely comfortable in all road conditions. I agree, I think the weight of the batteries down low helps everywhere, but high speed rapid turns. The low friction tires might play a part. But at less than 9/10ths, it's very nice.
I rent cars like Impala and Malibu on business. The Volt is much, much, nicer.
Everybody is ignorant, only on different subjects - Will Rogers Do not do to others what you would not have them do to you - Hillel If you can't be knowledgeable, be certain |
11-13-2012, 08:50 PM
#64 |
Woolf Barnato
Oddometer: 29,146
Something I've noticed while commuting. The range seems to increase by a few miles after about five miles. When I left San Francisco with a full charge this evening. the range indicated was 37 miles. By the time I was in Oakland in the Grand Lake neighborhood, I had traveled about 12 miles and the remaining range indicated was 28 miles. My drive starts on a mild incline to the Bay Bridge and then at the Oakland anchorage it is downhill. Perhaps that affects the estimation.
11-14-2012, 04:44 AM
#65 |
Oddometer: 1,393
If you're on a long downhill cruise, put the shifter in L and use your cruise control. (if possible) This essentially will charge the battery a bit on the way down, instead of using the brake. There are guys on the Volt board (gm-volt.com) that have started at the peak of the Rockies, and gained a full charge by the bottom, and used no fuel in the process. The Volt lets you take advantage of that old physics lesson of an object at the top of a hill having stored energy.
L isn't really a low gear- its just a higher regen (more 'engine braking') when you lift the pedal. Of course the brake pedal provides regen, but L and cruise can do a more perfect job, if circumstances permit. Also, the charge remaining algorithm gets increasingly accurate- it learns your driving style. Getting 40 miles out of the battery in your climate isn't bad. I'll bet you'll do better as time goes on. Smooth driving pays off. gm-volt.com is a great place to learn some things from others. Just beware of the apple-grade fanboyizm. |
11-14-2012, 06:32 AM
#66 | |
Woolf Barnato
Oddometer: 29,146
I'd like to find an application that would show me the drivetrain operating conditions real time. I would guess that the obd port would be the source. A wireless connection to an ipad with a nice graphic would be cool. I want to see engine rpm, temperature, throttle position etc. Then the electric drive train numbers would be cool, also.
11-14-2012, 07:52 AM
#67 | |
Oddometer: 1,393
I got to see the battery out of my car (reinforcement plate non-recall upgrade program). I think GM did a heck of a job on the Volt. |
11-14-2012, 08:17 AM
#68 |
De Oppresso Liber
Oddometer: 30,419
Interesting thread. I would have thought the Volt was a boring thing to drive. I always loved the concept, but same about the Tesla and such and they have proven to be short lived in the real world as far as shorter than advertised miles per charge. Oh, and I so want a KTM Duke...
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
11-14-2012, 08:28 AM
#69 |
more north, more wet
Oddometer: 3,675
Let's say you had a hitch mounted rack and carried a small gas or diesel generator -- could you run the generator and plug the car in?
2006 KTM 950 Adventure "The pen & sword, in accord." "It's never over in a Rover." |
11-14-2012, 08:35 AM
#70 | |
Woolf Barnato
Oddometer: 29,146
As an aside, there is a public charging station near me that is $2.00 hr. my calculation makes that about double the price of a gallon of 91 octane gas here.
11-14-2012, 08:41 AM
#71 | |
Oddometer: 3,675
11-14-2012, 09:13 AM
#72 |
Oddometer: 1,393
The most efficient generator is under the hood.
At relatively constant highway speeds, it will couple the engine torque to the front wheels, while driving the gen, for optimum efficiency. Wasting rotational motion just to suffer charging & discharge losses is not the most efficient. However, it is always electric, because the design of the transaxle demands some input from an electric motor, to couple the torque from the engine to the drive axles. Its all about gears and clutchpacks. However, the ECU can run the engine at the optimum load and RPM, regardless of vehicle speed, and store the excess energy not used in propelling the car to the battery. In fact, it makes enough extra juice, that when cruising along, there are times when the engine will turn off, and drive the car solely on battery, long after the battery has been initially depleted. This is most noticeable when driving along at 50-70mph. GM did a lot of asking, 'what if', 'why not' and 'how about', when designing this thing. |
11-14-2012, 02:43 PM
#73 |
I know better
Oddometer: 6,646
The least costly way to charge you Volt is at night from a house equipped with a tax credit subsidized installation of solar panels, hooked up to the grid.
11-14-2012, 04:59 PM
#74 | |
Air cooled runnin' mon
Oddometer: 6,112
Car of the year. And yes, I would hit her.
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
11-14-2012, 09:06 PM
#75 |
Careening forward
Oddometer: 5,663
By a unanimous vote I'm told.
KLX 400 dual sport Tune in, turn on, drop out. |
| Thread Tools | |
