Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 11-11-2012, 05:07 PM   #61
Xcountry-Rider OP
Oddometer: 912
I'de also like to recommend the Rox Risers you can get the bars in a better more comfortable position and make it easier to stand up.
Xcountry-Rider is offline   Reply With Quote
Old 11-11-2012, 05:13 PM   #62
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,651
After 150 miles, I'm probably gonna be looking for some of these...
sent from my Galaxy S3 using Tapatalk 2
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 11-11-2012, 05:22 PM   #63
Xcountry-Rider OP
Oddometer: 912
Are you going to mount that Galaxy 3 and use it as a GPS? I have my Atrix 4G in a Otter Box mounted in a Slip Grip and Ram mounts.I have fun using it with the Dualsportmaps app. The App is 20 bucks but worth it when compared to buying a GPS.
Old 11-11-2012, 05:37 PM   #64
backwoodsKLR
Oddometer: 9,651
I saved the Zumo cradles off my old bikes... just need a ram ball or the touratec mount over the dash... have not decided which.
2013 Tiger 800XC
Old 11-11-2012, 05:44 PM   #65
Xcountry-Rider OP
Oddometer: 912
Your going to want to check this out then.
Old 11-11-2012, 05:48 PM   #66
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Backwoods,
I travel to Jackson quite a bit and have two ram ball arms that are the same size. 2 " I believe. I have no use for one of them so let me know if you want it. It's a freebie.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 11-11-2012, 05:55 PM   #67
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Ha! I just installed this set up on my XC yesterday. Works really well. I had my Zumo mounted on the handle bar in the center before that. I will say this about the SW Motech set up, the Zumo gets considerably more vibration mounted this way. The bar mount showed zero vibration.
_______________
Old 11-11-2012, 06:29 PM   #68
Xcountry-Rider OP
Oddometer: 912
On the positive it keeps it out of the rain.
Old 11-11-2012, 06:37 PM   #69
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Going a different route.
I am having my machinist modify a set of pegs for me. I have to find a set of pegs with a larger base first. If the optional Triumph pegs are larger then that's what I will use. I will post the results with pics here when I'm done but it will be about a week or two. We basically use stock pegs with a heal platform welded behind them and at a lower position than the peg platform. This is really great for off road while standing. We have used this set up for motocross over the last several years.
_______________
Old 11-11-2012, 06:42 PM   #70
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Yes, this is true. I am looking for a sun shade for the Zumo 550 now as well. Being that far away from the Zumo now I can't adjust it as easily on the fly.
_______________
Old 11-11-2012, 07:31 PM   #71
Xcountry-Rider OP
Oddometer: 912
I use Touratech boxes because they are good quality and i found them used but what i don't like about Touratech is the extreme BMW bias. Look at the crash bars for the F800GS. They put lots of thought in the design. They completely match the design of the bike they look like they belong and they look good.
Now look at the skid plate same thing they really threw down for the F800GS.
Now look at the completely shoddy design of the Tiger skid plate. Who would even consider such a piece O sh!t.Its not even welded. All rivets and they want 278 bucks for it. You can get a Triumph skid plate that's much better quality for 195.
Its obvious TT puts all the thought and energy into BMW. Thats fine its there business but i'll pass if something is better than them on the market.'Which is usually the case when it comes to the Tiger.
Xcountry-Rider screwed with this post 11-11-2012 at 07:54 PM
Old 11-11-2012, 07:37 PM   #72
burmbuster
burmbuster's Avatar
Oddometer: 1,432
I use Touratech boxes because they are good quality and i found them used but what i don't like about Touratech is the extreme BMW bias. Look at the crash bars for the F800GS. They put looks of thought in the design. They completely match the design of the bike they look like they belong.
Well said. Don't forget to leave out "over priced".
_______________
Old 11-11-2012, 08:03 PM   #73
Xcountry-Rider OP
Oddometer: 912
Another recommendation from the Dr. is the Altrider rear rack. I have one and it good quality that matches the price point.
I lost one of the spacers when i was putting it on and called them and they sent me another for free. Plus the support was very good on the phone. Touratech support is good as well but like he said over priced for the actual quality you get.
Old 11-11-2012, 09:32 PM   #74
dwoodward
dwoodward's Avatar
Oddometer: 5,754
Originally Posted by jphish View Post
I like HT stuff. Have their SU rack for my side cases.
Do not fit well with the Arrow exhaust. I had to add spacers and source longer bolts for the footrest mount on that side to get it to clear.
Guys at HT were unconcerned, said they would look at it if I rode my bike to them (500 miles one way), but were non-committal about doing anything about it.
Good value option- better than OEM side cases- but having done the trip I wanted them for, I'll probably put them up for sale when I get a round tuit.
dwoodward is online now   Reply With Quote
Old 11-11-2012, 09:44 PM   #75
dwoodward
dwoodward's Avatar
Oddometer: 5,754
Originally Posted by Wandering Dane View Post
Yep, the dealer quoted me close to $500 installed and recommended against owner doing the install himself.
If you had any trust in that dealer, STOP.
THe OEM heated grips are plug and play, right down to a dedicated plug in the harness. The only potential fiddly bit is snaking the power wires through the bars.
Instructions for all Triumph OEM accessories are online at triumphinstructions.com- look up the part number, go there for the directions to decide if you can do it yourself.
Times are GMT -7.   It's 05:08 PM.
