Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-06-2013, 07:12 AM   #931
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Originally Posted by Dirtmonkey8 View Post
I have been wondering the same thing in regard to where the swing arm ends up at full compression. I have the Wolfman setup with the Rotopax to the out side but I have been wondering if I can move it to the inside. I am now realizing i should be able to look up the amount of suspension travel she has and measure while it is up on the center stand and find out myself. You may want to do the same before you possibly find out the hard way.
Visually the distance from the tire to the rear well is just a tad larger than the distance from the swingarm to the tank lower edge. I dont belive the tire can even come close to touching the actual plastic well.
I took a ride yesterday evening over some large speed bumps and watched the action, doesnt even come close.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 05-08-2013, 08:04 AM   #932
muddyrabbit
Lost Boy
muddyrabbit's Avatar
Oddometer: 3,844
I've seen very little mention of tail racks in this thread. In fact I don't think I have seen anyone say anything about a tail rack? Pretty basic piece of kit, but I'd like to know if anyone has any specific rants or raves about the one they have.
muddyrabbit is online now   Reply With Quote
Old 05-08-2013, 08:14 AM   #933
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I have the SW Motech rear rack...works great for it's intended use. It also has threaded holes for a top box
Here's the pic, I have a net over it
Dubl-A screwed with this post 05-08-2013 at 08:39 AM
Old 05-08-2013, 09:04 AM   #934
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,663
Strange, as I also have an SW-Motech rear rack, but it is quite different from yours.
Here is a link to the one I have:
http://advdepot.com/sw-motech-alu-ra...er-800-xc.html
It accepts the multiple adapters using cam-lock quarter turn fasteners. I use that feature to attach a Givi adapter plate - http://www.twistedthrottle.com/sw-mo...-kappa-monokey and a Givi tail bag, or to attach the SW-Motech rack extender - http://www.twistedthrottle.com/sw-mo...g-soft-luggage
Old 05-08-2013, 11:37 AM   #935
Cabriolet
Oddometer: 52
SW Motech Alu Rack all the way, its a brilliant peice of kit.
The alu rack requires no holes to be drilled in the stock tail cover (unlike the triumph sliding carriage kit)
I have 3 different adaptor plates that each fit with 3 quarter-turn fastners.
One to suit my Givi top box.
One for the SW Motech Trax top box.
One is a flat plate to suit a soft roll bag/tent.
They even do (yes I did buy one) a cover that plugs the T-shaped hole so everything looks neat when there is no adaptor plate fitted.
edit: The good thing about the Alu rack is that the Triumph 10 litre city tailpack and the Triumph 50 litre adventure tailpack can both (independantly of course) still be fitted to the rear rack. They just sit about an inch higer that being clipped to the standard plastic rear cover. ;)
Cabriolet screwed with this post 05-08-2013 at 11:43 AM
Cabriolet is offline   Reply With Quote
Old 05-08-2013, 01:35 PM   #936
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
caribou luggage and rack on mine. it works gooder.
fbj913 is offline   Reply With Quote
Old 05-08-2013, 02:26 PM   #937
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,793
Altrider or CJ Designs. Either bolt to the existing mounts, both work for whatever else you wanna bolt on there, top box, mount, pax, etc. Or just strap on a soft bag. I have the latter, got a raw one for $100 from them. I think the PC ones are about $135.
I never see mine because the seahorse 720 is bolted on. I would probly take it off now and then, but it's wifey's backrest too and just never know when she's gonna want to tag along. Besides, I've become addicted to the top box...so freakin' handy.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 05-08-2013, 03:28 PM   #938
McKay
McKay's Avatar
Oddometer: 919
Just received my alt rider rack today, very very nice! I've been waiting to order a sump guard until I was able to see the Alt rider tail rack, Ill be buying their sump guard now as well.
I'm an aviation technician and consider myself a pretty good judge on sheet metal type things, this rack is near perfect.
Jeff
McKay is offline   Reply With Quote
Old 05-08-2013, 03:30 PM   #939
McKay
McKay's Avatar
Oddometer: 919
Chris, where did that back rest come from? That looks very cool.
Jeff
Old 05-08-2013, 04:12 PM   #940
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,793
Just handi-work. Piece of 3/8" cabinet-grade plywood, 1" foam, upholster over it, mount with a couple of SS screws at the bottom and 2" aluminum angle. I used the same vinyl as the new seat cover for the pillion came from.
It looks to be an odd angle, but had wifey sit there and adjusted it to where it sits flat to her back. Fastened down there.
Seat mod was to dish out the existing foam which reduced the slope a lot - left the front of it full height. Then glued a 1" layer of foam and shaped it to the seat-edge profile, made new cover. I'm not a pro at sewing, so you can tell by the stitches it's a DIY job.
We're good for a couple of hundred miles a day now.
Old 05-08-2013, 08:13 PM   #941
Poweranger
Oddometer: 760
I searched all over and couldn't find any place that still carries these. How recently did you order yours? I have had no luck even finding one listed on the Twisted Throttle site. I really wanted one of these as I already have the adapter plate that I used on my Sprint. I like how minimal these racks are with the adapter plate removed.
Since I couldn't find the Alu-rack for the Tiger I purchased the Alt Rider rack with the Givi monokey hardware. It's a nice product but looks like you have a dinner table mounted on the back of the bike when you do not have a case on it.
I wonder if SW-Motech even makes the Alu-rack for the Tiger any longer?
Poweranger is offline   Reply With Quote
Old 05-08-2013, 08:32 PM   #942
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,663
It was 1.5 years ago, just after I got the Tiger. Having an Alu-Rack on my ZZR, I knew how much I liked it and how versatile it would be. Being able to exchange items between the bikes due to the racks having the same configuration was just icing on the cake. I'm not sure why TT no longer carries these; they are an awesome accessory.
Old 05-08-2013, 09:26 PM   #943
McKay
McKay's Avatar
Oddometer: 919
I like it and may steal it
Jeff
Old 05-08-2013, 09:30 PM   #944
BryanCO
CO Rider
Oddometer: 500
I have the Alt Rider tail rack, sump guard, crash bars and side stand footer. Very happy with all of them.
BryanCO is offline   Reply With Quote
Old 05-09-2013, 09:08 AM   #945
984gasm
Oddometer: 41
Dubl-A, What seat do you have there? It looks solid!
984gasm is offline   Reply With Quote
Times are GMT -7.   It's 06:51 AM.
