11-09-2012, 08:30 AM
#1 |
Really, Really Cool
Oddometer: 3,315
Yet another LC4 electrical/starting thread
My 2000 640 E is making the loud buzz from the relay back by the battery, starboard cover.
I rebuilt the starter even though when I opened it up it looked real good. No change. I mistakenly thought it was the starter cable because when I unhooked it from the relay and powered it from jumper cables it would work intermittently. I replaced the cable and no change. The battery is an Odyssey and has been ruled out (no change when jumping from my truck). I looked at the relay behind the headlight and tried to do a temporary bypass but I don't think I did it right. I did notice last night when it was dark out, when I hit the button I can see a spark inside the relay that coincides with the buzz sound from the other relay. Also, when I hit the button in neutral with no clutch pulled it buzzes and the neutral light strobes but when I pull in the clutch and hit the button the neutral light goes out and the rear relay just clicks once. Would you say it is probably the front relay? (the small white one behind headlight) . |
11-10-2012, 11:20 AM
#2 |
Oddometer: 188
hope this helps
sounds like the starter motor or rear relay to me, I would try shorting the terminals on the rear relay if it starts no problem then it rules the motor out, if it does not then try powering the starter motor from another battery say with jump leads taking great care, if it then starts it rules the starter motor out. This would be my initial plan of attack to narrow down possible causes, if it starts when shorting the rear relay that points heavily towards the rear relay, but i would check for voltage on the signal cable before replacing it.
11-10-2012, 11:47 AM
#3 |
Oddometer: 136
Post up the issue here. These guys DO know it all when it comes to the LC-4 platform.
http://advrider.com/forums/showthrea...nduro&page=213
"Our lives can be spent carrying out actions that we hope will lead us to a greater sense of purpose, accomplishment and meaning, but all these are secondary to the need to feel alive." - AntiHero ADV Rider |
11-11-2012, 08:54 PM
#4 |
Traveler
Oddometer: 4,006
John,
Do you have the wiring diagram? Is the ground wire tight at the battery? Relays are confusing, also the clutch switch and kill buttom and kickstand switch(if present) all add to the problem. I think there should be numbers on the relay terminals so we can figure out how to hot wire it. bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
11-11-2012, 09:21 PM
#5 |
De Jo Momma
Oddometer: 8,705
It's the battery. Odyssey batteries suck ass. Don't care if the jumper cables didn't help. It's the battery. Everything you described, along with the lights dimming, etc. It's the battery.
11-11-2012, 11:03 PM
#6 | ||
Tyre critic
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
11-12-2012, 04:49 PM
#7 | |
Really, Really Cool
Oddometer: 3,315
It does not turn when jumping the rear relay, it only sparks. I was doing this by simply shorting between terminals with a pair of needle-nose. . |
11-12-2012, 04:51 PM
#8 | |
Really, Really Cool
Oddometer: 3,315
11-12-2012, 04:55 PM
#9 | |
Really, Really Cool
Oddometer: 3,315
We put a meter on the battery and there was no significant drop when hitting the button. I will swap out the battery from my other bike to make sure. . |
11-13-2012, 04:56 AM
#10 |
Oddometer: 188
second shot
I would also say it is the battery if poor connections are definatley ruled out particularly earth connections.
11-13-2012, 09:20 AM
#11 |
Really, Really Cool
Oddometer: 3,315
Is it normal to see a spark inside the relay? (the small white one behind headlight mask)
11-13-2012, 09:59 AM
#12 |
De Jo Momma
Oddometer: 8,705
Yes, relays and switches make small, visible sparks.
Don't waste another minute of your time until you hook up a known-good battery (that actually starts another bike), and make sure it's properly connected with the screws, not just jumper cables. I could get into the long-winded discussion of HOW it does this but, everything you've described, I've seen before: normal voltage, no voltage change when you press the button, strong headlight...and it was still the battery. I'm telling you: Odyssey batteries are lumps of shit. I will never buy another one. You're chasing ghosts. It's 99% the battery. Go read through the Airhead forum and see how many guys do exactly what you're doing because they're so sure it's not the battery. It was the battery. |
11-17-2012, 08:41 AM
#13 |
Really, Really Cool
Oddometer: 3,315
It is NOT the battery.
![]() I guess I'm a one percenter. I swapped the batteries and get the same buzz from the relay, and the Odyssey fires up my F800 no problem. I also made sure the ground was good and looked for any other problem with wires. I'm going to order both relays. . |
11-17-2012, 01:32 PM
#14 |
De Jo Momma
Oddometer: 8,705
Yes indeed, you ARE the 1% but you HAVE to eliminate the battery first.
Next step is to short across the starter relay terminals with a screwdriver. If the engine cranks, it's either the starter relay or something upstream. If not, it's the motor or the cables. Did you notice any corrosion on either of the cables? What often happens on cars is that acid will get onto the terminals from a leaky battery. The acid will wick down the wires and corrode them down inside the insulation. People clean up the visible part but, corrosion down inside the insulation turns the wire to crap. The same COULD happen on a bike, though batteries rarely last long enough to weep acid.
Greg |
11-17-2012, 04:52 PM
#15 | |
Really, Really Cool
Oddometer: 3,315
Positive cable from relay to starter has been replaced. Cables did not have any corrosion at battery. . |
