Old 11-10-2012, 05:48 PM   #1
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
640 Pre 03 to 03+ cylinder swap
I picked up an older cylinder for my 03 spare engine build and had to do a small mod to make it work, so I figured I would share it:
The pre 03 is on the left and takes a much larger dowel
Made up a bunch of slugs to convert the hole size
The dowel slug in place:It can be used to fit the 03 + cylinder to the older cases or the older cylinder to the 03 + cases
The pre Hi- flo engines take a thicker base gasket so I need to establish if the 01 cylinder is a fuzz shorter or if the 03 just ran a slightly higher compression ratio... I will go with the thicker pre- 03 gasket regardless when I assemble the spare engine...
gunnerbuck screwed with this post 11-10-2012 at 05:59 PM
gunnerbuck is offline   Reply With Quote
Old 11-10-2012, 10:17 PM   #2
bmwktmbill
Traveler
Oddometer: 5,218
Thanks Gunner,
That was a black hole.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-10-2012, 10:22 PM   #3
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
Yep , it's good to have a machinist friend to help out on the odd project...
Old 11-11-2012, 03:08 AM   #4
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,638
Neat job. I like elegant solutions.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 11-11-2012, 08:38 PM   #5
bmwktmbill
Traveler
Oddometer: 5,218
Gunner,
Now you have me thinking and wondering, is it settled that a Hi-flow head/cam will fit on a low flow cylinder and vice versa.
I have forgotten if that is settled.
Your ideas?
bill
Bill Shockley
Old 11-12-2012, 03:33 PM   #6
Alik
viertaKTMotor *****
Oddometer: 266
Well guys there is a factory solution to that (as I believe):
part # 579.30.023.000 ZENTRIERSTIFT GESTUFT 4/9,8 CENTERING PIN GRADED 4/9,8
no need to grind and co. :)
One need 2 of them to make it work.
Alik is offline   Reply With Quote
Old 11-12-2012, 06:42 PM   #7
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
Originally Posted by bmwktmbill View Post
Gunner,
Your ideas?
bill
Hi Bill,
Yes, a high flo head will mount on a lo-flo cylinder, that is the combo I will be using on my spare engine build...
I have quite a mix of parts from both pre and post 03 going into this engine...
Old 11-12-2012, 06:58 PM   #8
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
Yep, looks like the exact part needed to do the swap... When the later model LC 4 -400 went to a juice clutch they used the Hi Flo engine cases... Instead of changing the 400 cylinder because of the different sized dowels KTM did the exact thing I did to make it work... The downside is that those parts will likely get backordered to the factory...
Old 11-19-2012, 04:16 PM   #9
Alik
viertaKTMotor *****
Oddometer: 266
Here in Eastern Europe we can get almost every part from the KTM factory in just 5 days - sometime even less, maybe 3 :)
Old 11-19-2012, 06:22 PM   #10
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,305
Most of the 640 parts I order are usually in the dealer in 3 days from the warehouse in Ohio, if it has to come from the factory then it's 2 weeks...
I ran a part # 579.30.023.000 search through some North American KTM dealers and no results came up... Even special order part #s usually still yield results when run through a search, I wonder if that part is even still available?
Times are GMT -7.   It's 06:49 AM.
