Old 11-11-2012, 10:04 AM   #1
ramjet OP
ramjet's Avatar
Oddometer: 2,316
equipment to drain gas from bike tanks
Recommendations please for gear to drain gas from tanks. Something of a suitable commercial level not cheapo auto supply. Not sucking on hoses anymore or banging around with self primers in tanks with fuel pumps. Would be great also if it would work for car gas tank to get out emergency fuel.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is online now   Reply With Quote
Old 11-11-2012, 01:18 PM   #2
GH41
Oddometer: 822
What is wrong with sucking a hose? I guess I just got used to the taste of gas. GH
GH41 is offline   Reply With Quote
Old 11-11-2012, 01:50 PM   #3
sgmartz
Oddometer: 103
Take the hose, hold in one hand and with the other stretch the hose out
Now cover the end of the hose with your thumb, with the other hand fill the hose up with gas, the hose is now primed, keep your thumb on the lower end of the hose and with other put it in the gas tank, now use as a regular siphon, No sucking needed, I use this regularly never a drop spillith
2007 V-Strom
sgmartz is offline   Reply With Quote
Old 11-11-2012, 02:00 PM   #4
the_gr8t_waldo
Oddometer: 2,149
is there such a thing as a commercial grade siphon?
the_gr8t_waldo is offline   Reply With Quote
Old 11-11-2012, 02:11 PM   #5
roger123
roger123's Avatar
Oddometer: 1,623
Get a boat outboard motor squeeze bulb and some rubber hose. I found one at Walmart, but any good auto parts store should have them.
'14 Tenere ES
COG 5903
roger123 is offline   Reply With Quote
Old 11-11-2012, 02:39 PM   #6
Capt_phun
Capt_phun's Avatar
Oddometer: 117
That works easy & no gas in the mouth. I used this setup to drain the large gas tank on my old bass boat.
Capt_phun is offline   Reply With Quote
Old 11-11-2012, 03:01 PM   #7
bikerfish
flyfishandride
Oddometer: 1,655
it's a motorcycle! remove tank, take off cap, turn tank upside down. gas will be removed!
bikerfish is offline   Reply With Quote
Old 11-11-2012, 03:21 PM   #8
Paul_B
Paul_B's Avatar
Oddometer: 364
I remove the line from the petcock and slip another line about 12"-18" long to reach the fuel jug. Then just open the petcock to the reserve position. I find it hard to keep a siphon line in the lowest part of the tank if i do it from the top.
Paul_B is offline   Reply With Quote
Old 11-11-2012, 03:49 PM   #9
squish
Out of the office.
Oddometer: 6,359
Flipping the tank on modern tanks do not work
The petcock or fuel rail draining is way too slow.
There is a battery operated pump with the end on a long straight rigid pipe that easily stays in the gas.
You can use the pump to prime a siphon or if the tank you are draining into is higher the pump will empty the tank out.
I don't know the brand off hand.
On vacation for a spell
squish is offline   Reply With Quote
Old 11-11-2012, 03:54 PM   #10
num1husker
Oddometer: 100
removing fuel
I use this for my boat, motorcycles, jet ski, lawnmower, quads and it works great. Just remove the rubber hose coming from the fuel tank and pump it out. It also works if you want to just stick it in a tank to remove most of the fuel. Pretty inexpensive about $35.00 and I just put a couple of battery clamp ends on it to connect it to the power source. I found after trying other methods this one ended up being much safer in the long run. I think I've had it over 5 years now and it's paid for itself.
It does around 1 gallon in a little over a minute and with 50 gallons in the bass boat I just transfer right into my truck when I put it away for the winter.
num1husker is offline   Reply With Quote
Old 11-11-2012, 04:39 PM   #11
ramjet OP
ramjet's Avatar
Oddometer: 2,316
Ah. Something I hadn't heard of before. But electric connection-is that going to turn me into some kind of flambe'?
where do you get the pump?
Old 11-11-2012, 04:54 PM   #12
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,438
I just Googled what was on the pump
http://www.amazon.com/Mr-Gasket-42S-.../dp/B000BWE4RC
PineyMountainRacing is offline   Reply With Quote
Old 11-11-2012, 05:21 PM   #13
ramjet OP
ramjet's Avatar
Oddometer: 2,316
I just Googled electric gas siphon:
http://m.cbsnews.com/storysynopsis.r...nb_splitPage=0
Old 11-11-2012, 07:14 PM   #14
num1husker
Oddometer: 100
A wet dry electric vacuum, he deserves to be arrested, and maybe a trip to Bellevue would be in order as well.
"A volunteer Freeport firefighter illegally siphoned gasoline from his fire chief's truck using a wet/dry vacuum, igniting a blaze at the firehouse when the machine tipped over and caught fire, authorities said Tuesday in announcing the firefighter's arrest on an arson charge." Long Island Newsday.
http://www.newsday.com/long-island/n...1.4191701?qr=1
num1husker screwed with this post 11-11-2012 at 07:36 PM
Old 11-11-2012, 09:06 PM   #15
ramjet OP
ramjet's Avatar
Oddometer: 2,316
No shit. A fireman no less. This one's even better:
http://finance.yahoo.com/video/phoen...-31013842.html
I guess I'll check out the marine supply for the squeezy thing.
Times are GMT -7.   It's 09:06 PM.
