Old 11-12-2012, 07:36 AM   #1
Spikehead OP
Two-Bit Throttle Bum
Spikehead's Avatar
Oddometer: 4,948
2002 Silverado fan speed control resistor
Anyone replaced one? I'm down to 2 of 5 speeds and need to replace it before more snow flies.
-Spikehead
"I was tempted by the Invisible Man, I surely was." -Propforward
Spikehead is offline   Reply With Quote
Old 11-12-2012, 09:52 AM   #2
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,765
They are -usually- a 10 minute job. -usually- the glove compartment comes out and it is pretty obvious behind that. Most of the time you spend more time cleaning out the glove compartment so you don't spill everything than you do actually replacing the resistor block.
Having said that, I'll look to see if that is where yours is, sometimes you can reach around and not even have to do that but it depends 100% on the particular vehicle.
GreaseMonkey is offline   Reply With Quote
Old 11-12-2012, 09:56 AM   #3
GreaseMonkey
Oddometer: 4,765
Here's a link for a 1997, I suspect yours is similar if not identical:
http://www.justanswer.com/gm/1v3f6-1...-resistor.html
The image from that page:
Also there are a couple youtube videos, I didn't look at it though:
http://www.google.com/url?sa=t&rct=j...D29r-qddrO7Fiw
Hope that helps.
Old 11-12-2012, 03:25 PM   #4
Spikehead OP
Spikehead's Avatar
Oddometer: 4,948
Thumb
Thanks. My Dakota was firewall mounted under the hood and was maybe a two minute job, but I wasn't sure where the General had hidden the damn thing.
-Spikehead
Old 11-13-2012, 08:27 AM   #5
Multiplicity
Oddometer: 172
The power module for your 02 Silvo is located under the right side of the dash. You'll need to remove the HVAC close-out cover under the right side passengers dashboard. It's located just under the glove box. Look at the fan motor when you remove the close-out panel and you'll see it. The module has about 6 wires going in and two coming out. The two coming out go to the blower motor. You can't mistake it for anything else
Multiplicity is offline   Reply With Quote
Old 11-13-2012, 01:31 PM   #6
dirtrulz
Oddometer: 420
The connectors on the newer ones seemed to have melting problems, not sure about the older ones.
dirtrulz is offline   Reply With Quote
Old 11-13-2012, 05:49 PM   #7
Multiplicity
Oddometer: 172
They have a TSB for this issue. Check with your local dealer or repair shop for further info.
Old 11-15-2012, 11:12 AM   #8
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,619
I remember replacing it on my '99 GMC Sierra. Your new body style should be the same. The replacement part looked a little different from the original, but it worked. I had to buy a special deep socket (7 mm ?) to be able to disassemble the housing so I could access the part. It was nice to have all the fan speeds again though.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 11-15-2012, 11:27 AM   #9
phreakingeek
phreakingeek's Avatar
Oddometer: 70
my 2005 had the same problem
I ordered a replacement online and replaced the OEM one that was cooked.
It took me about 30 minutes since I'm pretty slow soldering and I didnt want to have to cut any wires and redo it. It required cutting and soldering of about 12 wires and I used heat shrink on all the joints.
Worst part about the repair is that it's a fairly inconvenient place to work. Had to find a bucket that was the right height to sit on so i could lean in and work in the space under the dash.
phreakingeek is offline   Reply With Quote
Times are GMT -7.   It's 02:55 AM.
