Old 11-12-2012, 08:36 AM   #1
Death Dealer OP
Death Dealer's Avatar
Oddometer: 364
Knife Sharpening
School me on knife sharpening. What is the best, easiest to use sharpener? Wickededge, Edgepro, Lansky, Sharpmaker, or just a good old set of paper, stones and leather?
2010 GasGas 300 EC Nambotin Replica
2006 XR 650R Supermoto
2006 CFL
1982 Yamaha Maxim - sold
Death Dealer is offline   Reply With Quote
Old 11-12-2012, 09:28 AM   #2
jonpcovington
Oddometer: 965
Lansky- reasonably easy and almost foolproof.
jonpcovington is offline   Reply With Quote
Old 11-12-2012, 11:04 AM   #3
fierostetz
Oddometer: 235
What's your level of sharpening experience, and how many/often?
When I only had 2-3 knives around, I used a set of DMT stones (continuous surface diamond plate). For sharpening smaller items, I used a lansky. For larger items (hunting knives, etc.) I often use a 1x30" belt grinder and a progression of belts for a convex edge. When I do more kitchen oriented knives, etc. I moved to paper wheels, because I can process knives MUCH faster and more consistently... though I still finish on leather/diamond, then leather/crOx, then leather only. A buffer from harbor freight is about 30 bucks, and a set of paper wheels from woodcraft runs about the same. Again, it really depends on how many knives/how often you want to sharpen. And don't use paper wheels without a firm understanding of how to sharpen a knife, as you can eff up a knife just as quickly as you can sharpen it. For the absolute keenest edges I use DMT coarse, fine, xtrafine, xtraxtrafine, then a 12k grit chinese water stone, then felt +5 micron diamond, then leather 3 micron diamond, 1 micron diamond on leather, then leather .5 micron chromium oxide, then just leather leather - that's how I do my straight razors (if I could do those on the paper wheels I could, but the edges are too thin and burn). I sharpen thousands of knives a year (side job, you could say. More like a hobby that I'm able to keep expense neutral!)
I buy all my stuff at motorcyclegear.com, formerly newenough.
fierostetz is offline   Reply With Quote
Old 11-12-2012, 11:41 AM   #4
AMCJEEP
Oddometer: 247
This
Originally Posted by Oliver Wendell Holmes
Men do not quit playing because they grow old; they grow old because they quit playing.
AMCJEEP is offline   Reply With Quote
Old 11-12-2012, 11:55 AM   #5
fierostetz
Oddometer: 235
Originally Posted by AMCJEEP View Post
This
can't really recommend a lansky until I know how many knives we're talking about :P if he's got a pile of 100 knives around the house, the lansky's going to have your fingers soooooooore
Old 11-12-2012, 11:56 AM   #6
VTvfr
VTvfr's Avatar
Oddometer: 364
What about the WorkSharp unit?
Chad
'07 990 Adv
'07 250 XC-W
(plated)
'03 600RR
(track duty only now)
'94 VFR750 (sold)
VTvfr is offline   Reply With Quote
Old 11-12-2012, 12:06 PM   #7
fierostetz
Oddometer: 235
at that point you're better off just buying a 1x30" belt grinder (like 40 bucks at harbor freight) since 1x30" is a standard belt size.. you can get anything in that size, including plain leather.
Old 11-12-2012, 03:55 PM   #8
Death Dealer OP
Oddometer: 364
I don't have any experience, but I have many knives. This is why I am looking at the Wickededge system. Seems completely repeatable but much quicker than a Lansky...
2006 CFL
Old 11-12-2012, 04:08 PM   #9
Smithy
Avoiding the Skid-Demon
Smithy's Avatar
Oddometer: 6,735
In my shop, it's a Craftsman 2x42" grinder up to 1000 grit, then buffed with green chrome oxide on a sewn cotton wheel.
By hand, it's synthetic EDM stones, maybe 1000 grit paper on a soft backing, and a strop. Diamond hones are also used, depends on how much needs taking off to true up a blade.
Whatever you do, learn the difference between removing metal, honing metal, and polishing metal.
Good luck!
Chris, Proprietor of The Tidewater Forge
Hot iron is my passion. Fire is my mistress. Let's dance.
Smithy is offline   Reply With Quote
Old 11-12-2012, 04:19 PM   #10
fierostetz
Oddometer: 235
here's a quick video of sharpening with the paper wheels
http://www.youtube.com/watch?v=yKIC2Q9_g5o
I took that the day that I got the paper wheels - I'm much faster now, about 90 seconds per knife. The knife I was sharpening was garbage steel (like chinese 420a or something soft like that) but at the end I was whittling a hair. I sharpened a gerber hatchet and then shaved with it, start to finish, to settle a dare with a friend. Just a thought - you want to make sure you understand edge geometry *very* well first.
Here's me sharpening a cold steel kukri machete (piece of junk as a knife, but invaluable as a yard/camping tool!) with a 1x30" grinder.
http://www.youtube.com/watch?v=jMIkUW_kjOA
Both setups are 50-70 bucks. Maintenance is almost nil for the wheels, add rouge when its out and regrit the wheel occasionally (after a few hundred sharpenings) vs. buying belts for the 1x30. I still use both; the belt grinder for convex edges, the paper wheels for otherwise. Still use stones too, for kitchen knives (like a slightly toothier edge, the DMT stones don't disappoint on that front).
You should probably check out bladeforums.com for a bit more info, there's a whole section there for maintenance tinkering and embellishment (Thats where the sharpning how-to's are).
As for the levels of sharpness attainable, all three of the above methods yield a hair whittling edge (can slice off pieces of a hair) but only the stones get to pass the hanging hair test (or either of the others, then finish by hand on leather with crox).
Old 11-12-2012, 04:21 PM   #11
fierostetz
Oddometer: 235
Good luck!
I love love love using sandpaper on a mousepad (like your second option) because its just SO danged fast! As for your cotton wheel.. have you tried a leather belt for your 2x42? *personally* i get sharper finishes that way, I felt that the cotton wheel was undoing some of my other work...
seriously though, check out a leather belt, I'd never go back! You gotta remember to take the belt off and not leave it under tension, as it will stretch.
Old 11-12-2012, 04:55 PM   #12
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,589
I use a whetstone and honing oil. Tired several sharpening tools but they don't hold an edge like a good hand sharpened knife will.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 11-12-2012, 05:47 PM   #13
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,385
If I was sharpening lots of knives, I'd get a Tormec & a nice big Forschner or F. Dick steel.
You want to do the initial grinding without overheating the blade, and NOTHING finishes an edge like a steel.
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 11-12-2012, 08:55 PM   #14
Chisenhallw
Kilted Terror
Chisenhallw's Avatar
Location: I've narrowed it down to 'earth'. Or 'Baltimore'.
Oddometer: 1,761
Buy this book.
ESCAAAAPE..FROMMMM...BALTIMOOOOORE
Dynamick & I are raising money for the Children's Foundation. Please give if you feel so inclined!
2001 Kawasaki Concours
Chisenhallw is offline   Reply With Quote
Old 11-12-2012, 09:34 PM   #15
SR1
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,799
Send a message via Skype™ to SR1
I worked at a knife shop for years for extra money, and learned a lot about sharpening. We sold the Lansky's and they sold well, but its a pretty slow system.
Belt sander, followed by ceramic sticks was the best sharpening system we found. Works great and leaves the working edge at a good angle for durability. '
Don't take the edge too thin or you'll seriously affect how long it will stay sharp.
BMW GS and Yamaha WR250X/R (split personality)
Save $5 on a Smugmug account, use this code:
hVs9vtN9NsQRQ
SR1 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:24 PM.
