12-04-2012, 05:02 PM
#1 |
Oddometer: 206
Template for mounting Pelican Cases with Twisted Throttle Mounts & Givi Racks Vee?
Are there any kind of pics or patterns out there of a preferred mounting position for Pelican Cases with Twisted Throttle Mounts and Givi Racks?
They come undrilled and I would really like to learn from others success (or mistakes!) so i get it right the first time! Thanks, Vincent |
12-04-2012, 09:01 PM
#2 |
Butler Maps
Oddometer: 14,583
why not get carribou cases already mounted up for motech or givi?
they have integrated locks and lid straps http://cariboucases.com/store/?name=Home
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
12-04-2012, 10:12 PM
#3 |
Oddometer: 206
I already have all the seperate pieces purchased from Twisted Throttle...just prepping to start drilling.
12-05-2012, 11:56 AM
#4 |
Oddometer: 5
When I mounted mine, I just put the brackets on the bike and positioned the cased accordingly. Have someone hold them in place until you find the desired spot.
12-05-2012, 02:43 PM
#5 |
Are those Pelicans?
Oddometer: 2,137
Helps to have the top edge of your Pelicans reasonably level, so as it affords a level surface to set things, like beer
![]() Don't forgets to account for things like lid-swing of the Pelicans, clearing and seeing your turn signals and exhaust. Great, useful project. I have Pelican Hardigg Storm cases, IM2600's.
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
12-05-2012, 08:49 PM
#6 |
Oddometer: 486
There are some good suggestions there. One more recommendation would be to slip the horseshoe shaped bracket into the carriers and then moving the case around until you find the right spot. You will need an assistant for that. When you are comfortable with the placement mark the holes with a sharpie.
- Take the brackets off of the bike and tape the cases to the horseshoe brackets. This will insure that when you drill they are aligned properly. - Be certain to drill directly down and not on an angle. The more precise you go the better. Less slop, less chance of water passing through. The supplied combination rubber and stainless washers will keep the interior of the cases dry. If you run into trouble or want to run it by someone call our tech support line (toll-free) 855-255-5550 Best of luck - Kevin
TwistedThrottle.com Toll-free 855-255-5550 Follow us on YouTube, Facebook and Twitter! twistedthrottle screwed with this post 12-10-2012 at 08:36 PM |
12-06-2012, 12:46 PM
#7 |
Oddometer: 599
duct take the brackets to the cases and put them on the bike.
keep repositioning until you get it where you want it. then mark and drill. do small holes and use smaller hardware to make sure it is where you want then do the supplied hardware. or you can do what i did. center the bracket and drill...it ended working out just fine.
Joe 10 Bonneville SE 08 Vstrom 650 abs |
12-24-2012, 11:02 AM
#8 | |
Oddometer: 486
Kevin @ Twisted Throttle. ps/ Happy Holidays!
TwistedThrottle.com Toll-free 855-255-5550 Follow us on YouTube, Facebook and Twitter! |
12-24-2012, 11:16 AM
#9 |
beat up ex flat tracker
Oddometer: 6,929
Mount em as high up as you can,also further back from your legs is a good idea. I drug the boxes on my DR650 on the ground till I redrilled and raised em up. Its not rocket science.
Some bikes around at times |
12-24-2012, 09:34 PM
#10 | |
Oddometer: 206
It worked out really well...this system seems very well engineered and should last a good long time. Thanks for the follow up concern...I appreciate it! ![]() ![]()
12-24-2012, 09:39 PM
#11 | |
Oddometer: 206
I'm an aircraft mechanic by trade so I can be too much of a perfectionist at times (read: overthinking some projects)...just wanted to get it right the first time, Id hate to have extra holes to fill after the fact! |
12-28-2012, 11:14 AM
#12 | |
Oddometer: 486
Kev
