Old 11-12-2012, 02:00 PM   #1
Tiz OP
Tiz's Avatar
Oddometer: 623
Stumps from toppled trees
Anyone have any thoughts on what to do with stumps of toppled trees - HUGE trees and HUGE stumps. Like 10' diameter root ball ripped up from the ground.
I can cut the tree off the stump but not sure I can get at the thing with a stump grinder. How to get the dirt off?
Ideas?
I have 4 large trees down and need to get rid of the stumps and fill the holes.
--Kevin
FJR1300-2008
ex-2005R1200GS
ex-DL650K5
ex-2001 XR400
ex-2002KLR650
Tiz is offline   Reply With Quote
Old 11-12-2012, 02:12 PM   #2
troidus
Oddometer: 13,760
Do you have to get the dirt off? A pressure washer would take care of it, but you may be making extra work (and a lot of mud) for yourself.
troidus is online now   Reply With Quote
Old 11-12-2012, 02:36 PM   #3
Tiz OP
Tiz's Avatar
Oddometer: 623
I was considering a garden hose. I'd like to get most of the dirt off. I'm hoping they can go to the dump but I'll have to cut them up to get them in my truck. I'd need a payloader to move them as-is.
I'd don't need them clean, but there's probably a ton of dirt there on the two biggest and half ton on the smaller ones.
--Kevin
FJR1300-2008
ex-2005R1200GS
ex-DL650K5
ex-2001 XR400
ex-2002KLR650
Old 11-12-2012, 02:37 PM   #4
junglemototours
trailplug
Oddometer: 1,485
Fire.
junglemototours is offline   Reply With Quote
Old 11-12-2012, 02:42 PM   #5
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,346
What kind of trees? Could be worth some serious money.
I lived in Memphis when Hurricane Elvis came through. Massive old trees down everywhere. Tree crews were making a killing removing the trees & then selling the wood & stumps. Double dipping!
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 11-12-2012, 03:34 PM   #6
Speedo66
Transient
Oddometer: 6,696
I unfortunately was in the same position, 2' diameter tree down, with a huge root ball standing up.
I can cut trees, but couldn't (didn't want to) handle the roots. Figured no good would come to the chain saw cutting through all the roots and dirt you couldn't remove.
Called a tree service. Front loader picked it up and brought it to the driveway where an open box truck with an arm picked it up and took it away.
I figured it was money well spent.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-12-2012, 04:28 PM   #7
Spikehead
Two-Bit Throttle Bum
Spikehead's Avatar
Oddometer: 6,272
-Spikehead
"I was tempted by the Invisible Man, I surely was." -Propforward
Spikehead is offline   Reply With Quote
Old 11-12-2012, 04:35 PM   #8
DUNDERHEAD
Oddometer: 189
Be careful when you cut the trees. As you remove the weight of the limbs, the tree wants to stand up and bite you ! Watch out !!!!
DUNDERHEAD is offline   Reply With Quote
Old 11-12-2012, 05:11 PM   #9
machinebuilder
Oddometer: 1,090
Call someone to grind them. the machines they have are so much better than you can rent and they'll probably level things when they're done.
Of course it may take a while to get to your job with all the damage up there.
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Old 11-12-2012, 05:20 PM   #10
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 944
Not quite on subject, but long ago stumps were removed, slowly,
with stump pullers, and a powder wedge was sometimes used to split up the
really big ones:
http://www.youtube.com/watch?v=pYQbMMCe0tU
http://gasengine.farmcollector.com/g...z12aszbea.aspx
CycleDoc59 is offline   Reply With Quote
Old 11-12-2012, 05:23 PM   #11
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,553
My buddy used a bulldozer to rip em out and then skidded them on a trailer. We started with a big stump grinder from a rental place, that lasted 20 min lol
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 11-12-2012, 05:40 PM   #12
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Burn them then beat the dirt off with a sledge hammer. Repeat until theyre small enough to handle.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 11-12-2012, 06:24 PM   #13
adam_c_eckhardt
done with Chemistry!
adam_c_eckhardt's Avatar
Oddometer: 5,176
A local waste company takes a dump truck load of stumps for $100. He runs them through a shredder and sells the chips. Knowing what I know about shredders, that $100 barely covers operation and maintenance costs, not to mention paying off the actual machine.
Then your problem is getting them in the truck. You may find someone can make quick work of this, and probably won't charge too much- especially if you offer cash.
Whatever you do, please don't bury them. They can become quite dangerous. A family friend lost a toddler years ago. The kid was wondering around, fell in a sink hole caused by buried stumps, and suffocated. Turns out the developer buried stumps instead of having them hauled off.
It's also been suggested that you hire a pro with a stump grinder. Not a bad way to go- their machines are top notch and will make quick work of it.
adam_c_eckhardt is offline   Reply With Quote
Old 11-12-2012, 07:13 PM   #14
Beezer
Oddometer: 5,653
if the trees are still in the dirt, leave the stump long. the extra height gives leverage to pull/push the stump out. it's not easy work even with a blade. anyway, no matter how you do it, it's never as easy as you think it should be.
grinding.... maybe. it doesn't remove all the roots & such. if you want all of it gone, you have to pull it.
Beezer is offline   Reply With Quote
Old 11-13-2012, 07:22 AM   #15
Tiz OP
Tiz's Avatar
Oddometer: 623
Thanks all. I do like the powder wedge.....
The trees are on their side with root ball in the air, so I think a stump grinder won't work. Best idea is probably to get someone with machines to haul them away. I had considered burying them but will not given the info provided.
--Kevin
FJR1300-2008
ex-2005R1200GS
ex-DL650K5
ex-2001 XR400
ex-2002KLR650
Times are GMT -7.   It's 04:18 PM.
