Old 11-04-2010, 12:32 AM   #1
pops OP
Oddometer: 1,403
2wheel drive
Any one got some more info or photos of this 2 wheel drive set up For the gs ??? Please.
http://www.bmwmccvic.org.au/componen...g2_itemId=2589
Same thing i am planing to do Been looking at using free wheeling 4x4 hub to easy put the drive in or out for the sidecar wheel?
Cheers Ian.
pops screwed with this post 11-04-2010 at 02:01 AM
pops is offline   Reply With Quote
Old 11-04-2010, 07:03 AM   #2
windmill
windmill's Avatar
Oddometer: 3,377
Mobec,
For folks with unlimited budgets, or who have won the lottery.
http://mobec-international.com/index2.php
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 11-04-2010, 08:36 AM   #3
Evel Knievel
Paredini, Antonio
Evel Knievel's Avatar
Oddometer: 140
Mobec, I believe inmate Richard-NL rides something like that...
Con cordiales saludos,
Antonio.
Evel Knievel is offline   Reply With Quote
Old 11-04-2010, 09:29 AM   #4
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,082
Send a message via Yahoo to BMWzenrider
Originally Posted by windmill
Mobec,
Nope, that is not a Mobec setup....
Mobec DOES make a 2-wheel-drive setup using the BMW paralever final drive,
but it comes out of the opposite side of the unit for sidecars mounted to the right (correct ) side of the bike...
What you are showing looks like a home-grown setup, but nicely done.
Although I would use a splined shaft with a boot rather than a rigid welded shaft to allow for some change in length with suspension movement,
and also to allow the shaft to be moved out of the way more easily for wheel changes.
Unless it is splined where it goes into the CV joints???
I also prefer welded wheels (or cast) vs. multi-part bolted/riveted wheels.
- No joints to maintain an airtight seal on.
- No worries about the fasteners loosening up over time/stress.
- No worries of stress cracking/fractures at all the many small drilled holes.
- Easier to clean (fewer/no sharp corners for dirt/mud to get stuck in).
But again, that is just a personal preference...
The idea of the locking hub is a good one. Mobec is a full-time 2WD, with no differential.
I have been playing around with some ideas/plans for a full-time 2WD sidecar rig based upon a BMW Boxer motorcycle, but chucking the entire stock swingarm and hanging the rear suspension for the bike and sidecar off of the sidecar frame; & using a racing cart limited-slip differential w/reverse built into it to tranfer power. I am still looking for a suitable donor bike for the project.
Karl Kugler
www.theroadscholar.net
2005 BMW R1200RT w/Hannigan-LT sidecar
2002 BMW R1150RA
In Memoriam: Harley, 1993-2010 You will be missed.
BMWzenrider screwed with this post 11-04-2010 at 06:48 PM
BMWzenrider is offline   Reply With Quote
Old 11-04-2010, 11:21 AM   #5
Richard-NL
Sidecar Fan
Richard-NL's Avatar
Oddometer: 1,000
The right answer is ...........
Martin Preston outfit.
Shot these pics at last years Dragon Rally in Wales. They are probably in that thread too.
Same guy that made this:
http://www.advrider.com/forums/showp...postcount=1790
Same principle as the Mobec stuff.
Got some pics of the latest Mobec idea, that are not on the internet yet, if someone is interested.
Richard-NL
Richard-NL is offline   Reply With Quote
Old 11-04-2010, 04:57 PM   #6
pops OP
Oddometer: 1,403
Richard-NL
Thank you Richard-NL Love Martin Prestons work.
Yes please post the pics up.
Cheers Ian.
Old 11-04-2010, 07:09 PM   #7
windmill
windmill's Avatar
Oddometer: 3,377
A Mobec superdrive on A Guzzi.............
http://mobec-international.com/range...rive/index.php
Anybody got $40k they don't need? I promise it would go to good use.
Old 11-05-2010, 01:22 AM   #8
Evel Knievel
Paredini, Antonio
Oddometer: 140
Richard-NL
Cool, new stuff! Let it come..!
Antonio.
Old 11-05-2010, 04:45 PM   #9
TouringDave
Ok Human Let's Ride!
TouringDave's Avatar
Oddometer: 6,392
HOLY MOTHER!!!!
That is amazing!
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 11-05-2010, 11:08 PM   #10
The Mass
Timbuktu or Bust... Both!
Oddometer: 334
What that bloke has done to that GSX1400 is nothing short of amazing!
And I thought I was pretty good at grafting a USD front to mine.
As good as I am sure it may be and I guess a man of that calibre must have worked it all out, I'm not entirely convinced about the transverse action of the rear suspension.
But that's just me
Cheers
Mass
01 640 Adv
06 250 EXC
73 250 Motosport
04 GSX1400 (with USD front end)
The Mass is offline   Reply With Quote
Old 11-06-2010, 03:57 AM   #11
IsAnOzzie
Oddometer: 260
Has anyone looked into or done anything with a hydrostatic drive system?
2 WD should be pretty simple using hydraulic motors?
just something that has been floating around my head for a while now.
The Extinguished gentleman.
Do or do not. There is no try. Yoda
IsAnOzzie is offline   Reply With Quote
Old 11-06-2010, 07:24 AM   #12
gordonscott
gordonscott's Avatar
Oddometer: 158
Here you go... http://www.advrider.com/forums/showthread.php?t=532205
gordonscott is offline   Reply With Quote
Old 11-06-2010, 07:54 AM   #13
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,227
Hydrostatic: http://www.advrider.com/forums/showthread.php?t=558237
2WD, Front: http://www.advrider.com/forums/showthread.php?t=532098
2WD, 3WD sidecars: http://www.advrider.com/forums/showthread.php?t=301274
Going where no Harley has gone before
HogWild is offline   Reply With Quote
Old 11-06-2010, 12:40 PM   #14
Evel Knievel
Paredini, Antonio
Oddometer: 140
The never ending story
Antonio.
Old 11-06-2010, 04:29 PM   #15
Richard-NL
Sidecar Fan
Richard-NL's Avatar
Oddometer: 1,000
Yep, and that weren’t even all posts. Every few months this question “pops” up.
Most of the times I don´t even react on it.
OK, somebody has to post it.
Sidecar (and that’s what we talk about over here. Don’t we?) with hydraulic sidecar drive on an Ural with a Diesel Engine:
And just one picture of a part for the new Mobec twowheeldrive. It’s pretty obvious. Go figure it out.
Richard-NL
Times are GMT -7.   It's 04:20 AM.
