Old 11-13-2012, 05:18 AM   #1
mountaincadre OP
Oddometer: 358
lc4 640 enduro speedo problem
As above display is fine but no speed shown, is there a pick up on the wheel? if aye can you buy/rig another one as the bike shop is quoting 46 for a new one and if it is just a pick up for the sensor then 46 is very steep.
mountaincadre is offline   Reply With Quote
Old 11-13-2012, 06:25 AM   #2
mountaincadre OP
Oddometer: 358
Or doe's anyone have a clear photo?
Old 11-13-2012, 09:51 AM   #3
dhally
Hammerhead
dhally's Avatar
Oddometer: 2,288
Here's the OEM sensor off my 2001 640Adventure. Don't know if the same one is used on the Enduro. The cable and sensor are one piece, hence the high price. I have heard of others using a cheaper sensor and splicing it in. Trailtech sells them I think.
WR250R
Sherco 300i
Tiger 800 - FOR SALE
dhally is offline   Reply With Quote
Old 11-13-2012, 10:37 AM   #4
mountaincadre OP
Oddometer: 358
Must be a different one to yourself, mine is just a black cable with a block connector at the headlight end with a flat pad at the other, thanks anyway hombre.
Old 11-13-2012, 04:11 PM   #5
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,403
you have a "dial" gauge? stock speedo?
if so then you have a cable drive and it is not uncommon (in fact quite common) for those to snap, wear out, break, get caught on something, ......you get the idea. i finally gave up and got rid of all of it. i run my gps which does a much better job x 100. now you could probably find a mount for your phone and it would be better than the stock set-up.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Times are GMT -7.   It's 12:50 PM.
