Old 11-14-2012, 12:38 PM   #1
b3nji OP
Oddometer: 7
Dead battery in the middle of nowhere
So I got all geared up for a ride this morning and my bike wouldn't start. Luckily enough, I was was able to bump start it going downhill on my street. My question is this: What if you're camping in the middle of nowhere (miles to nearest paved road) and can't bump start your motorcycle? Are there portable jump starters out there that are decently sized (small) that can be carried on a road trip?
b3nji is offline   Reply With Quote
Old 11-14-2012, 12:45 PM   #2
Offcamber
Offcamber's Avatar
Oddometer: 1,756
What about a small solar panel to charge the dead battery?? Won't do any good if the battery won't take a charge but an added benefit is it could be used to charge small electronics like phone while your camping.
Something like this... Solar Charger
"Beer cans explode with a nice loud pop when they are hit by a Heidenau K60 at 40 miles an hour. Now my bike smells like last call..." Me
Offcamber is online now   Reply With Quote
Old 11-14-2012, 12:47 PM   #3
Nytelyte
Somewhere about
Nytelyte's Avatar
Oddometer: 678
I've not had a bike that I wasn't able to bump start on a flat road. Lots of running, lubricate the starter with lots of swearing, and it'll go. Sometimes takes more than one try.
But I'm a reasonably fit younger dude, & the biggest bike I've dealt with in this manner is a I4 600cc. Not sure if its harder with some of the high comp. singles, or if you have something that is very cold blooded to start with. I'll have to ponder this.
Nytelyte is offline   Reply With Quote
Old 11-14-2012, 01:46 PM   #4
JohnBoy777
Pseudo-Adventurist
JohnBoy777's Avatar
Oddometer: 888
Those are really maintainers, more than chargers - you'd need a panel 3' X 4' to charge it. i imagine they'll charge it if you have a full day or two in the sun.
JohnBoy777 is offline   Reply With Quote
Old 11-14-2012, 02:16 PM   #5
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,367
Easy...kick start it!
Yeah, I've done my share of push starting. On gravel with knobbies, I'll shift straight to 2nd gear, to give the wheel a bit more leverage on the motor, then drop all my weight on the rear tire as I let out the clutch.
It can be pretty tough on a 400-600 lb bike with dual sport tires. I haven't had to do it on the 410 lb Dorsoduro yet (the Aprilias are known to have occasional starter relay trouble), but my plan would be to use the same technique but shift straight to 3rd gear. The bike also has drive-by-wire throttle, fuel injection, and electric fuel pump. I'm not sure how it will work in the event of a dead battery. I have the feeling I would be screwed...
That's why I think all bikes should have back-up kick starters, but nobody listens to me...
High Country Herb is offline   Reply With Quote
Old 11-14-2012, 07:54 PM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,556
If you have two bikes, tire to tire on the center stands...
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 11-14-2012, 08:06 PM   #7
yatman
yatman's Avatar
Oddometer: 243
Dead Battery?
http://advrider.com/forums/showthread.php?t=832207
Great question having no juice to start your bike out in the "bush" and no big hill (that you're on the top of) to jump start
and gravel is hard enough to bump a loaded bike. I came close to that situation once and it really rattled my confidence.
I included a dual battery thread link....this is something that should be considered I feel....each of us has his own fears or demons though....being where I am it's pretty easy to get out of cell and/or radio range and a small "power pack" or a kick start option would be nice to have.
Great question
Be Safe and happy riding
yatman
yatman is offline   Reply With Quote
Old 11-14-2012, 08:14 PM   #8
ABHooligan
The Flying Mythos
ABHooligan's Avatar
Oddometer: 1,124
I've had to push a couple of bikes a little ways to roll them off down a hill. I can push my KLR or Tiger up a small hill to get this done. I'd hate to do it with a GS though. When I've had a low battery I unplugged the headlight to give it a bit of extra juice to the starter. I wouldn't rank this as one of my bigger worries.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHooligan is offline   Reply With Quote
Old 11-14-2012, 08:22 PM   #9
hhkiwi
hhkiwi's Avatar
Oddometer: 115
What's the deal with push starting a fuel injected bike? I heard that when the battery is completely drained, you could be out of luck.
hhkiwi is offline   Reply With Quote
Old 11-14-2012, 09:01 PM   #10
Renegade_Azzy
Kamen Rider
Renegade_Azzy's Avatar
Oddometer: 726
Just takes a hair longer. Ive bumped the vstrom plenty of times, because I tend to forget the key when going into work.
It takes a few more revs, some to get juice going to the fuel pumo, and then enough for spark. Would thate to do it on the flat... not enough room for me to run and jump on the thing with the bags and all (but they could come off).
___
AzzysDesignWorks.com Need laser cut acrylic for a project? Engraved metal? No problem. Shoot me a PM
Current bikes; '99 R1100GS ABS, '80 CM400A Hondamatic
Renegade_Azzy is offline   Reply With Quote
Old 11-14-2012, 09:12 PM   #11
Wargasm
Wargasm's Avatar
Oddometer: 191
I once had to push my GS1100 up hill to get a good run to bump start it. I think I could scare the CRF250L into starting if I farted. EFI or carbed they can all be bumped, EFI just needs more of a run/roll.
Wargasm is offline   Reply With Quote
Old 11-15-2012, 04:43 AM   #12
bikerfish
flyfishandride
Oddometer: 1,554
I think proper preventive maintenance is in order here, don't go out into the middle of nowhere if your stuff isn't up to snuff. sure, sometimes a battery will just give up the ghost, but for the most part, they are pretty reliable, when in doubt, put a new one in.
bikerfish is offline   Reply With Quote
Old 11-15-2012, 04:58 AM   #13
mrpete64
Oddometer: 577
three years...shot!
Most batterys are shot after three years. I put a date on mine so that I can remember when I purchased the battery. Better buy a new battery once-in-a-while than be stuck in the middle of nowhere.
Mr. Pete---->
aging hippie
mrpete64 is offline   Reply With Quote
Old 11-15-2012, 05:17 AM   #14
mark1150
mark1150's Avatar
Oddometer: 187
Good advise,however I still tend to be reliant on my optimate doing it's thing.
It's supposed to flash different sequences if there is something wrong, and I hope that I pick up on the problem if there is one.
One thing if you really are stuck in booniesville and have to push it out to a road or civilization,it's a lot easier to push if you drop the chain off of the rear sprocket, zip ty the chain to the swing arm and you have total free wheel.
A few minuets job to save a bit of grief.
mark1150 is offline   Reply With Quote
Old 11-15-2012, 06:58 AM   #15
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,476
Never heard of this one. I like this kind of party.
swimmer is online now   Reply With Quote
Times are GMT -7.   It's 10:56 AM.
