Old 11-15-2012, 05:04 PM   #16
ragtoplvr
Oddometer: 6,150
I am another that is no longer a Monroe fan, I fear they may be living off the reputation. Gabriel another old brand was worse. Bilstein did good for me the last time. For GM, actually AC delco is pretty decent. But brands change all the time, depending on who bought who. so it is kind of a crap shoot. Ask the counter people.
A cheap strut spring compressor is not a good idea. Many auto parts stores rent professional quality compressors if you buy the parts there, a deposit refunded when the tool is returned.
Rod
ragtoplvr is offline   Reply With Quote
Old 11-15-2012, 07:39 PM   #17
Ducky 149
Oddometer: 326
Yes you are in the ballpark for 550.00. I am a Volvo tech and know that our strut jobs are ALOT more than that. I also sell them all the time. I also take out crappy parts that other shops have put in. Really sad to see the custy get the news that their new parts are the problem.... Ohwell...just another day at the office.
Ducky
"I can't believe I threw up in front of Dean Wormer!!!! Kent, You threw up on Dean Wormer"
Ducky 149 is offline   Reply With Quote
Old 11-16-2012, 08:53 AM   #18
tvpierce
tvpierce's Avatar
Oddometer: 373
Originally Posted by troidus View Post
Thanks. I've been hearing and feeling a thump on low-speed bumps, so I know I've got some slop somewhere. Cradle bolts are tight, as is the exhaust, and I can feel some wander like my old Chevelles would get when the steering linkage was worn.
The low speed thump is likely the sway bar mount bushings. VERY common on Toyotas. I just replaced them on the aforementioned Sienna, and my BIL's Rav4. While you're in there, try to squirt some grease inside the rubber boots of the sway bar link ends and work it around in there. They get dry and the ball joints in them fail... and they're $90 EACH to replace.
Good luck.
The laws of the road are superseded by the laws of physics.
"But I had the right of way!" makes a pretty crappy epitaph.
tvpierce is offline   Reply With Quote
Old 11-16-2012, 10:49 AM   #19
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,408
Probably need to add this to this thread too...
I put some KYB's on the back of my Element a few months ago. Borrowed spring compressors, no alignment needed. Probably took me a good 4 hours total time, I have previous auto repair experience.
FYI on parts purchase. I shop online a lot at Advance Auto parts website. Log in/create an account for email specials. I typically get a 20% off email, and see a 20% off web bought parts banner when shopping. Research and buy online, pick up at your local store. Saves me quite a bit of cash.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 11-16-2012, 10:53 AM   #20
fast4d
Oddometer: 2,339
fair price.
FWIW, if they are using strut cartridges instead of a complete replacement strut w/body then it requires even more labor to install.
4 wheel alignment is $140 around here
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is online now   Reply With Quote
Old 11-16-2012, 11:16 AM   #21
troidus OP
Oddometer: 14,278
With the need to replace the upper strut mount, I'll probably buy everything, including new springs, and preassemble the new struts so that the strut swap becomes a simple six-bolt R&R.
When I had it aligned (5600 miles ago), the shop replaced the upper of the two strut-to-knuckle bolts with an eccentric, so I'll definitely have to have it aligned after reassembly. What I don't get is how the leaking strut was missed. It's wet clear down to the spindle, so it seems likely that it was already at least weeping when they were in there. No one said a thing.
troidus is online now   Reply With Quote
Old 11-16-2012, 11:19 AM   #22
troidus OP
Oddometer: 14,278
I did some shopping around. Rockauto seems to have the best prices for my parts.
Old 11-16-2012, 11:49 AM   #23
tvpierce
tvpierce's Avatar
Oddometer: 373
Watch out for Rock Auto's "shipping and handling" charges. They're rediculous!
Old 11-16-2012, 02:59 PM   #24
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,408
You do have to watch for those shipping charges, some are worse than others.
That's why I buy online with the discount, and pick up at my local store.
Mike
Old 11-16-2012, 03:08 PM   #25
troidus OP
Oddometer: 14,278
Good point on S&H. I'll keep my eyes open.
Old 11-17-2012, 12:18 AM   #26
Desert Scoundrel
Oddometer: 131
$550 sounds right inline. By the time you buythe struts, buy the spring compressor, buy a jack, buy a set of stands, buy all the hand tools needed to do the job and then do all the work, THEN have it aligned........
$550 is cheap the way I see it
Desert Scoundrel is offline   Reply With Quote
Old 11-17-2012, 12:24 AM   #27
troidus OP
Oddometer: 14,278
I already own everything except the spring compressor. I even have a couple of pickle forks sitting around here somewhere.
Old 11-17-2012, 10:49 AM   #28
Desert Scoundrel
Oddometer: 131
Just an fyi, pickle forks are not the proper was to remove tie rod ends or ball joints. Use one of these instead. These will not damage the boot or the ball/socket:
Old 11-17-2012, 11:11 AM   #29
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,493
That's fucking cool. Thanks - the next time I'll look for one.
I"ve got to imagine they are like pickle forks in that they come in sizes for different rod ends?
Mambo Dave is offline   Reply With Quote
Times are GMT -7.   It's 10:23 PM.
