Old 11-20-2012, 03:38 PM   #76
EetsOK
EetsOK's Avatar
Oddometer: 596
OK thanks, now I have to add Norway on list of places to ride. This is gonna cost me.....
Here's the machine needed (minus the tiny 2 gallon tank):
l never really thought of myself as a freak. But l'd love to freak.
EetsOK is offline   Reply With Quote
Old 11-20-2012, 04:47 PM   #77
JerryH
Oddometer: 5,069
I work for a city fleet services department, so I don't sell anything. The '60s, '70s, and '80s small block Chevy is my favorite car engine. They only had 2 weaknesses. One was in the rocker arm design, which caused them to throw a pushrod throug the valve cover once in a while. That was fixed by redesign a long time ago. The other problem was the cam drive, and that never got fixed by GM. The aftermarket came up with gear drives which fit under the stock timing cover with no modification, and seem to work very well. I have a lot of use on one with no problems, and being the mechanical type, I love the noise. Your other option for long life from one of these motors is to replace the timing chain at regular intervals, which is not difficult depending on how much room, you have to work in.
While I work on all American vehicles, up to 2012, plus large trucks, construction equipment, graders, backhoes, etc. down to push mowers and weed whackers, I do not work on foreign vehicles. My employer is not allowed to buy them. The city council mandated that we buy only American vehicles. And as for personal vehicles, the only non American cars I have any interest in are the air cooled VWs. I did own a Suzuki Samurai for a few years, never had any problems with it, I finally wore it out at over 200,000 miles, and sold it to a guy that was going to put a V6 in it.
Technology actually has very little to do with how long something lasts, and in some cases makes it fall apart faster. Quality is what it is all about. Part of the problem with American engines was a lack of build quality. If you want to start with an aftermarket Chevy block (I like Dart) and hand build the engine from the block up using only high quality aftermarket parts, Get it perfectly balanced, and every clearance spot on (not just within "tolerances") and properly maintain it, that engine will last a million miles in normal service.
The same thing applies to Harley engines, which use the same basic technology as older American V8s, other than liquid cooling. If they are built RIGHT, out of high quality parts, they will last a long time. Harley engines do have one design issue you don't have to deal with in American V8s, and it is part of their basic design. They have a single crankpin and a 45 degree cylinder layout. So there is no way you can properly balance one. Harley engines use a considerable amount of the power they make trying to tear themselves apart. You could easily fix that problem by using offset crankpins, but then it wouldn't be a Harley anymore. It wouldn't have that Harley sound and feel that is their main selling point. So all you can do is build them as well as possible, then rebuild them every so often. At least Harley engines, like older American V8s are designed to be easily rebuilt without replacing most of the engine, and parts will be available forever.
The new Twin Cam IS a better engine, other than, well, the twin cams. Harley made a huge number of improvements to this engine and transmission, it is way stronger than an EVO. But then they go and put that chain driven cam drive in it, which cancels out all the other improvements they made. Had they done everything else except using twin cams, they would have one of the most reliable and long lasting motorcycle engines ever made. And I still see no reason for twin cams. Even the newest American V8s still only have one cam, and look at the power they get out of them. Look at the new Corvette, Camaro, Mustang, and Challenger. By far the most powerful American V8s ever made, and the most reliable. And yet their basic design still uses ancient technology.
JerryH is offline   Reply With Quote
Old 11-20-2012, 05:19 PM   #78
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
Originally Posted by JerryH View Post
The same thing applies to Harley engines, which use the same basic technology as older American V8s, other than liquid cooling. If they are built RIGHT, out of high quality parts, they will last a long time. .
Yes, almost exactly the same. Except for the aforementioned liquid cooling, 45 degree V, and single crankpin with forked con rod.
And roller bearings instead of plain bearings.
And roller hydraulic lifters instead of flat bottom hydraulic tappets.
And a crank driven trochoid oil pump instead of a distributor driven gear oil pump.
And a splittable case with removable cylinders, instead of a cast block with integral cylinders.
And I could go on...
A Harley-Davidson V-Twin has more in common with a radial engine than it does a small block Chevy. They are only compared to small block Chevys in their proximate redlines, power curves, and significant increases in power with bolt on performance parts, which in both cases works so well only because both engines were historically choked in stock form from the factory.
No offense intended, but many of your posts are not mechanically accurate.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 11-20-2012, 05:54 PM   #79
JerryH
Oddometer: 5,069
Roller lifters are available for all American V8s, and have been stock for a long time. I mentioned the single crankpin 45 degree layout as being different, and one of the reasons Harley engines did not last as long. I mentioned the liquid cooling. The roller bearings vs plain bearings, the way the oil pump is driven, and the splittable cases are minor differences that do not affect the overall design. Yamaha's Roadstar uses plain bearings. Plain bearings require higher oil pressure. I would think that the Harley engine being a dry sump design, which I forgot to mention, would be considered a much bigger difference than bearings or oil pump. As for the cases, an air cooled VW has splittable cases, and horizontal cylinders, and is air cooled. Maybe it is more closely related to the Harley engine, other than it is fan cooled, and can be balanced. When you get right down to it, the Harley engine is unique. But it does share many things in common with other types of engines. I picked the SBC because I am so familiar with it. I still don't see why the Harley engine needs two cams, which was my main point. The EVO only had one cam, and all the EVO clones still being made only have one cam, and they run just fine. Most of the other changes Harley made improved the durability of the engine, EXCEPT the twin cams, and I can't figure out what they did.
Old 11-20-2012, 06:40 PM   #80
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
It's official.
You're hopeless.
Old 11-20-2012, 06:54 PM   #81
EetsOK
EetsOK's Avatar
Oddometer: 596
....The new Twin Cam IS a better engine, other than, well, the twin cams. Harley made a huge number of improvements to this engine and transmission, it is way stronger than an EVO. But then they go and put that chain driven cam drive in it, which cancels out all the other improvements they made. Had they done everything else except using twin cams, they would have one of the most reliable and long lasting motorcycle engines ever made. And I still see no reason for twin cams. Even the newest American V8s still only have one cam, and look at the power they get out of them. Look at the new Corvette, Camaro, Mustang, and Challenger. By far the most powerful American V8s ever made, and the most reliable. And yet their basic design still uses ancient technology.
Cam drive is one of its biggest issues.
There is nothign wrong with push rods as you noted. But as I said, the S&S X Wedge is the American V twin done right.
Push rods: still used in top fuel dragsters, the fastest accelrating race vehicle in the world, to this day.
Old 11-20-2012, 07:48 PM   #82
Av8rPaul
Av8rPaul's Avatar
Oddometer: 405
Originally Posted by EetsOK View Post
Sport rubber (17 inchers) on sporty suspensions is going to out corner a stock Sportster. I've ridden many MANY Norton Commandos that corner very well too but they still won't compete with 17 inch rubber and modern suspension and frames. The GS is NOT a good comparison. When you can hang with even a Triumph Sprint RS, let me know.
it is not a slam against you or your bike eithr. Just pointing out a mix of 19 inch and 16 inche tires with 1950's suspension becasue that is what it is, just like new Triumph Bonnie's) is going to be outclassed by modern stuff.
BTW I live in BC, it's all mountain passes and corners for me too. ;)
I believe the official/unofficial speed record on the Dragon was set by a rider on a GS.
Paul
2012 Triumph Scrambler
IBA #33
KTM 950 Adventure, Buell 1125R, Ducati ST4S, BMW R100/7 (x2), Triumph T140E, Suzuki GS1100G, Yamaha SR500, Honda CB750K, and a bunch of dirt bikes...
Av8rPaul is offline   Reply With Quote
Old 11-20-2012, 07:48 PM   #83
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,496
Originally Posted by Bueller View Post
It's official.
You're hopeless.
Is this the same guy that was spouting off about 90 degree drive angles over in the Motus thread?
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 11-20-2012, 10:03 PM   #84
DAKEZ
DAKEZ's Avatar
Oddometer: 19,714
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 11-21-2012, 05:44 AM   #85
nskitts
nskitts's Avatar
Oddometer: 3,197
If he can beat that dude on the yellow GoldWing I want to see it!
"I never regretted any vacation that I took."
--Dad, a few months before he passed.
nskitts is offline   Reply With Quote
Old 11-21-2012, 07:54 AM   #86
AZbiker
Crunkin' with crackers
AZbiker's Avatar
Oddometer: 6,949
I don't see any reason for TCs either. Gear-driven quad-cams put out a much higher specific output.
Quality is what it's about. The heat-treating used, the spread of the tolerances. Everything has tolerances. It has to. Absolutes only exist in arithmetic, not in measurement. If something measures 1.0" in diameter, is that a guarantee it is going to measure 1.00"? How about 1.0000"? Or 1.00000"?
For being a mechanic, you are woefully ignorant about the way the machines you work on are made.
rubber side down,
derek
http://azbiker.smugmug.com
Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q
AZbiker is offline   Reply With Quote
Old 11-21-2012, 08:15 AM   #87
Gas Hog
Two Wheel Fanatic
Gas Hog's Avatar
Oddometer: 1,015
What he is referring to is automotive tolerances..which compared to machine shop tolerances..are measured with a yard stick.
A engine can be built within tolerance, and be darn near worn out from the jump.
Gary
Gas Hog is offline   Reply With Quote
Old 11-21-2012, 08:29 AM   #88
TxRoadDog
Shut up and ride
TxRoadDog's Avatar
Oddometer: 418
And this is why shovelheads are the best, most reliable motors in the world!
1996 shitbox noise pump. It's still purple.
TxRoadDog is offline   Reply With Quote
Old 11-21-2012, 08:37 AM   #89
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,518
Same guy that was run off the XT225 forum.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 11-21-2012, 09:16 AM   #90
XT_Driftwood
XT_Driftwood's Avatar
Oddometer: 560
And Moped Army, though I don't think it stuck.
BTW, I love my '01 FXDXT... cam chains and all.
'83 XT550 - once the bane of my existence, now considered to be the pinnacle of reliability and engineering excellence
'85 GPz 750 Turbo
'01 Harley T-Sport
'99 Cagiva Gran Canyon - the bane of my existence
XT_Driftwood is offline   Reply With Quote
Times are GMT -7.   It's 05:39 AM.
