Old 05-14-2014, 12:35 PM   #316
sarathmenon
Oddometer: 880
Originally Posted by Flyred View Post
I had them reinstalled in Poland for the paved section of my ride.
The Scouts I used were fantastic and will be me tire of choice when I get back home. 7200 miles and the rear was 1/16" from the wear bar. The front had loads of miles left but had picked up a bad head shake.
At Bialystok BMW, They even washed my bike!
Now that's some impressive riding gear
sarathmenon is online now   Reply With Quote
Old 05-14-2014, 04:00 PM   #317
JRWooden
Oddometer: 4,231
Originally Posted by B_C_Ries View Post
This is 2 days late but it was a great ride:
Got any techniques you'd like share on hopping on and off the tracks?
Old 05-14-2014, 04:24 PM   #318
ebrabaek
Oddometer: 4,712
90 deg. angle, and lots of throttle.....
Erling
Old 05-15-2014, 08:32 AM   #319
Flyred
Who is John Galt?
Flyred's Avatar
Oddometer: 686
Went to a WW2 Tank battle monument
In Death Valley
Flyred is offline   Reply With Quote
Old 05-15-2014, 09:09 AM   #320
brakedw
brakedw's Avatar
Oddometer: 67
can-bus adapter install
still deciding how to run the trigger wire
next stop plasti dip windshield and pdm60 install
http://advrider.com/forums/showthread.php?t=978259
brakedw is offline   Reply With Quote
Old 05-15-2014, 01:20 PM   #321
B_C_Ries
Oddometer: 2,622
Look for spots where there is alot of dirt/sand next to the tracks.
A piece of wood pushed into a switch point can be used as a ramp. (remove it after you are done) Pile of rocks also works.(remove them as well).
If you need lift your bike over the rails lift by holding the wheel so the suspension does not work against you. Lifting the wheel while turning it by hand works really well.
There were 2 of us so one person could control the bike while the other lifted a wheel.
B_C_Ries is offline   Reply With Quote
Old 05-16-2014, 01:11 AM   #322
Full Power
Oddometer: 1,464
My evil twin threw a tizzy, made me order up a Leo Vince can.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 05-16-2014, 07:04 AM   #323
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
My evil twin presented me with a lengthy to-do list before it carries me to the RA rally (via the Smoky Mountains) in two weeks. To punish it, I will let it all go to the last minute.
Fred
FredRydr is offline   Reply With Quote
Old 05-17-2014, 12:24 AM   #324
The Maz
Savage
The Maz's Avatar
Oddometer: 48
A few things.
Mounted a Wolfman Ranier tank bag:
Made a set of X straps. (in high-vis orange)
Installed a set of 2" Rox Risers, and made and installed a longer clutch cable to accommodate for the added rise
And installed a Denali power hub2 with the twisted throttle can-bus adapter
The Maz is online now   Reply With Quote
Old 05-17-2014, 05:11 PM   #326
LongWays
Skiing up a hill...
LongWays's Avatar
Location: City of Subdued Excitement.... no really it is!
Oddometer: 5,198
Scrubbed in some rubber (Karoo 3) on the new 18" rear. With the bigger wheel and 45 tooth sprocket all the twitchiness with the throttle and steering has magically disappeared. Fucking brilliant.
If you don't like my sig line - don't read it.
LongWays is offline   Reply With Quote
Old 05-17-2014, 10:48 PM   #327
Stephenmarklay
Stephenmarklay's Avatar
Oddometer: 291
Installed some BMW pannier racks. Good thing I am not paid to do so.
EDIT: Today 5/18 I revived some used aluminum panniers from a 2009 GS to mount. They were not too bad with only a few scrapes here and there. They had a lot tree branch scratches and the like. I used 0000 steel wool and metal polish. Worked great and they look ready to go 5 more years.
2014 BMW F800GS Das Auto
2007 BMW R1200R
2011 Yamaha TW200 The Snowmobile
Stephenmarklay screwed with this post 05-18-2014 at 06:33 PM
Stephenmarklay is offline   Reply With Quote
Old 05-18-2014, 03:00 PM   #328
HMMWV
Makin Dust
Oddometer: 23
With the farkling in swing, I took my new (just past the break-in oil change) F700GS out to knock some dust onto it.
HMMWV is offline   Reply With Quote
Old 05-18-2014, 08:51 PM   #329
JRWooden
Oddometer: 4,231
My problem here is I don't see how to get CLOSE to 90 degrees ... unless he backs up ... maybe one more
Old 05-19-2014, 12:30 PM   #330
B_C_Ries
Oddometer: 2,622
90 degrees and the proper amount of throttle works fine for getting the front wheel in, back wheel is another matter.
Overall just getting the bike parallel and as close as possible to the rail then lifting the wheel onto the rail and rolling it forward into between the tracks is easy enough and is a failsafe method.
Times are GMT -7.   It's 04:18 PM.
