| View Results: Ride On, Dynabeads, or Static Balancer | |||
| Ride On |
11 | 11.46% |
| Dynabeads |
40 | 41.67% |
| Static Balancer |
45 | 46.88% |
| Voters: 96. You may not vote on this poll | |||
11-17-2012, 03:32 PM
#16 |
Oddometer: 23
I run RideOn in my tube type dirt bike tires, works great. Static balance w/lead weights on my tubeless street bike wheels. IF i was changing a tubeless tire for somone and a bunch of RideOn squirted down my leg they would be served a knuckle sammich
11-18-2012, 07:31 AM
#17 | |
Oddometer: 1,654
11-18-2012, 10:50 AM
#18 | |
Oddometer: 130
"Underneath this bucket of rust and bolts beats a heart of pure arthritis" 2006 Yamaha FZ6 1992 Suzuki Gs500e (in progress) |
11-18-2012, 01:03 PM
#19 |
Unwounding
Oddometer: 4,326
I've been kicking myself for ordering the $30 beads before trying something as simple as a few oz of sand. Couldn't hurt it and I have a clear view of my front axel throbbing fore and aft at +80 MPH. I tried dropping BBs in the stem but they don't quite fit thru the seal. Maybe I'll run over to the beach at the lake tomorrow for "supplies" and give it a try.
11-18-2012, 04:56 PM
#20 |
Oddometer: 1,654
Sand is not ceramic thus will turn into dust in the tire.
11-18-2012, 05:03 PM
#21 |
Oddometer: 130
Let me know how that goes. I was considering trying to use some metal bb's to see how that works, but I'm not exactly sure if they would heat up too much in the tire.
11-19-2012, 06:51 AM
#22 |
Rides slow bike slow
Oddometer: 9,509
I would be very concerned about metal BBs (.177 size) causing damage to the inside of the wheel and/or tire.
Airsoft BBs are supposed to work pretty well.
You couldn't hear a dump truck driving through a nitro glycerin plant!Cobbie Award Winner |
11-19-2012, 02:50 PM
#23 |
Oddometer: 130
Would they fit through the valve stem, and wouldn't they melt from the heat of the inside of the tire?
Anyone run into any problems with airsoft bb's
11-19-2012, 05:31 PM
#24 |
Unwounding
Oddometer: 4,326
And with enough dust, it would also balance the tire, no? I'm not seeing why any media wouldn't do the same thing. You don't want rust or clumping or ice so a water mix is out. No lubricants so the tire slips or degrades the rubber. Both of those rule out antifreeze, maybe the non glycol stuff is OK? Sand is harmless as far as I can guess. It is abrasive but so are the beads. How would it matter if the sand grains got smaller, assuming they even could. They would only be rubbing against rubber and themselves. I'd think they would cause less rubber damage than heavier ceramis beads. |
11-19-2012, 05:44 PM
#25 | |
Disgruntled Student
Oddometer: 1,561
11-19-2012, 06:37 PM
#26 |
Unwounding
Oddometer: 4,326
My brand new bike with unbalanced tires feels great, or I think it does, till over 75 MPH where it throbs thru the top clamp. I have a feeling that tiny vibrations have crept in at every speed cause I now feel tingles that just weren't there before I put on the new tires and pulled the weights off as they were way out then. If not for the throb, I doubt I'd have noticed the vibes. I've done alot of tires on alot of bikes from ZZR1200s to Ninja 500 to 950 KTMs and supermoto race bikes. Never balanced any and never noticed what i'm getting now.
I should have the dyna beads in a few days and will know for sure as that thrumming at least is clear as a bell. |
11-20-2012, 06:26 AM
#27 |
Oddometer: 1,654
FWIW, the tiny round ceramic beads are not abrasive-they just roll around in there & leave no sign on the paint inside the rim.
For discussion, lets agree that it's possible to mount a tire properly that is in balance based on good construction & having positioned it in the optimum position on the rim,etc.. So when you start to use that tire it is in perfect balance lets say. It's a fact that tires don't wear evenly. How do you propose to maintain balance over the life of that tire w/o adding weights? The beads do that for you from the get/go. What could be easier? |
11-20-2012, 10:15 AM
#28 |
Unwounding
Oddometer: 4,326
Any abrasiveness would show on the tire by my estimation due to the forces pushing the media out to that surface. Would a few oz of sand wear on the wheel? Would it be enough to matter? It might make some light contact when stopping. I've read some users get black dust from the rubber wearing due to beads. Haven't read of any wheel wear or paint damage, which I'd think a ceramic ball could cause if it can even hit the rim.
11-20-2012, 10:44 AM
#29 | |
Oddometer: 9,509
I don't think you can install them through the valve stem. They are 3 or 4mm in diamter IIRC. At least one bead of the tire will need to be broken from the rim so you can dump them in. Nobody has had problems with them melting.
11-20-2012, 01:37 PM
#30 |
Oddometer: 130
I think I might be giving that a shot on my next tire install. I think I'm gonna put some Ride On in them for now, since I dont want to break the bead of the tire.
Have used Ride On on my old Shadow. Not sure if it worked or not, because the tire was already balanced before I put it on, but damn, it sealed some punctures
