Old 11-15-2012, 11:36 AM   #1
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
GMC auto transmission squaks...
2001 GMC Sonoma pickup:
About two years ago I replaced the valve bodies in the tranny. The kit had a bunch of "upgrade" stuff (Corvette bits) and has banged into second gear ever since.
Now, instead of the bang it just sort of squaks/groans going into second, especially when hot or when under load. The fluid is still clean and clear (as was the original stuff), no metal flakes or burnt smell. It doesn't slip or misbehave, it just makes a nasty noise with the 1-2 shift and occasionally on the 3-4 or 4-3 shift.
Could it be the bands are out of adjustment? Something more sinister? The super clean fluid is throwing me off....
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 11-15-2012, 12:17 PM   #2
troidus
Oddometer: 15,727
Sounds like whatever is bypassing/defeating the 1-2 accumulator (assuming a 700R-4/4L60/4L60E has one) has failed.
troidus is offline   Reply With Quote
Old 11-15-2012, 12:26 PM   #3
Camper292000
Oddometer: 23
My truck slammed in gear too
bought a 99 silverado in 2001 used from ripoff Bill heard chevrolet. It would slam from 1 to 2. Went back and this NICE guy there said hold on....plugged some high tech thing into the tranny and put in a different program. Slamming gone.
It still shifts are in towing mode, but that's probably normal.
Camper292000 is offline   Reply With Quote
Old 11-15-2012, 02:26 PM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Band adjustment went the way of contact breaker points. ( a few Mopar trans. excepted) Your transmission has long travel servos, no adjustment. The groan is slippage. It is headed out.
Old 11-15-2012, 03:44 PM   #5
Benesesso
Benesesso's Avatar
Oddometer: 9,898
While we're on the subject of GM auto transes, my 1995 4T60E has a weird problem. It makes a funny noise whenever the shifter is in L. If I move the lever out of L the noise instantly stops, even tho the trans is still in L (like 5 -10 mph).
I think there is a "Low band" that is applied when the lever is in L, but why the noise? It's been doing this for years, not getting any worse. Sometimes in heavy stop and go traffic I like to pull the lever down to L, but I don't want to screw anything up, so I don't.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 11-15-2012, 04:02 PM   #6
troidus
Oddometer: 15,727
It'll be in the valve body, most likely. Different passages are active in manual low than are in drive, even if all the clutch packs and whatnot are in the exact same operating position. Now that you mention it, I think I recall hearing some extra noise from my 700R-4 when I had it in manual low.
Old 11-15-2012, 07:02 PM   #7
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
I went back and looked at the paperwork that came with the kit. This transmission is a 4L60E, so no real band adjustments... but TransGo has a way of shimming the servo pins (or grinding them shorter). Sounds like a bad idea/band aid fix.
Looks like it's time to shop for a manual transmission, ECU and gauge cluster (and pedals and console and.. and .. and... .... Hmmm, maybe I should just shop for a nice Nissan or Toyota.).
Old 11-15-2012, 07:18 PM   #8
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Yep it has a 1-2 accumulator. The one I installed was for a C-4 (6?) Corvette and went in literally upside down from the stock unit. .... I wasn't comfortable with it then and am a little suspicious of it now, even though everything I found verified that I installed it correctly.
Old 02-14-2013, 01:16 PM   #9
Benesesso
Benesesso's Avatar
Oddometer: 9,898
UPDATE
Just checked the trans. fluid, ~2 qts. low. Added 2, noise is GONE!
Old 02-14-2013, 02:49 PM   #10
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
Originally Posted by Benesesso View Post
UPDATE
2 quarts low!
Good God, when was the last check? During the Nixon administration?
Was it even on the stick?
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 02-14-2013, 02:51 PM   #11
groop
So much to ponder
groop's Avatar
Oddometer: 3,305
Originally Posted by Camper292000 View Post
99 silverado in 2001 .... It would slam from 1 to 2. Went back and this NICE guy there said hold on....plugged some high tech thing into the tranny and put in a different program. Slamming gone.
Interesting. I have 2000 Silverado that does that only sometimes and only after driving at least 100 miles. Like yours, it only shifts hard between 1st and 2nd. I've been reluctant to take it in because it's almost impossible to duplicate without taking a tech on a long roadtrip.
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 02-14-2013, 03:33 PM   #12
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Originally Posted by fritzcoinc View Post
2 quarts low!
Not Tricky Dick's, but Slick's. Yes the oil was on the DIPstick, at least until I wiped it off. But since you begged, you're going to hear the rest of the story (repost from a few years ago here).
GM 4T60E Automatic Transmission Problem--Hot Trans. and No TCC/OD (Torque Converter Clutch/Overdrive-4th Gear)
Cheap Fix for TCC/4th Gear Problem
My 1995 Pontiac Transport with the 4T60E trans. developed the rather common problem of losing TCC/OD when the trans. fluid got hot. First I installed a small trans. cooler in front of the rad.&A/C cond. Tried piping it both ways-with and w/o the rad. cooler. It worked much better in series, with the fluid going thru the add-on last.
But the problem remained-it just took longer to lose the TCC/OD. Did a LOT of research into the problem. Seems some moron trans. engineer in GM designed the TCC-apply valve such that the slightest leakage which got past the valve (steel valve sliding in the soft alum. valve body) would cause the TCC to disengage. The "stupid computer" would then sense the RPM mismatch. It had commanded the TCC to apply, and therefore didn't expect any RPM difference in/out. It then decides to prevent 4th gear (OD) from engaging, so you are supposed to drive home in 3rd gear and no TCC.
I live in Phoenix and the trans. temp. sensor never got hot enough to set a code. The problem was the trans. fluid getting thinner as it got hot.
I believe Trans-go or Sonnax makes a kit to replace this valve and add a steel bushing (what the trans. should have had originally), but it appears the trans. has to be removed to install it.
Fortunately there is another answer.
I decided to take a chance and use a thicker trans. fluid. I knew I was going to have to pull the trans. anyway if it didn't work, and then I'd have it rebuilt with the stronger heat-treated stuff etc. that also should have been used originally. I also wanted to re-gear it lower, because even with a good-running 3.8 the trans. was way overgeared, at least for me.
So, after MANY phone calls, etc. I bought a 5 gal. pail of 50 wt. "Powershift" trans./hydraulic clutch fluid from a Caterpillar dealer. This fluid is used in earthmoving equip.that has wet clutch packs, and also comes in 30 and 10 weight. I dropped the pan and refilled the trans.-you can only get ~50-70% of the fluid out. Refilling with the 50 wt. gives about 30 wt. with the fluid that remains in the converter. What all this means is that I gained ~30-40 deg. F on the viscosity of the trans. fluid, and the problem disappeared. It has worked fine for ~9+ years and 50,000 miles so far.
The fluid is not too expensive-I think I paid $85 (2011 price) for the 5 gal. They don't sell it in smaller amounts.
Several cautions besides the "do this at your own risk". Because I live in Phoenix, the lowest temp. is ~30 F. That means the trans. fluid is about like reg. ATF at 0 or -10 F--no big deal. But if I lived where it got colder I'd have used the 30 wt. for ~15-20 F "advantage".
I wonder how many millions of $$$ have been paid to trans. shops and GM dealers because of some moron "engineer's" blunder many years ago.
Times are GMT -7.   It's 12:05 AM.
