Old 11-15-2012, 06:34 PM   #1
Bigbugberg OP
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 320
2009 ktm 400xcw
My little one is drinking oil...
Looking to do the top end but the microfiche has two part numbers 78330007000I Piston size 1 and 78330007000II Piston size 2.
WTF? They're both 95mm so what is the difference?
The odds are good that the goods are odd
2010 KTM 690 Enduro
2009 KTM 400XCW Plated
Bigbugberg is online now   Reply With Quote
Old 11-15-2012, 06:41 PM   #2
JTucker
JTucker's Avatar
Oddometer: 2,270
One ring or two.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 11-15-2012, 06:44 PM   #3
Bigbugberg OP
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 320
Is the second an oil sweep or another compression ring?
2010 KTM 690 Enduro
Old 11-15-2012, 06:56 PM   #4
JTucker
JTucker's Avatar
Oddometer: 2,270
Compression ring, most of the XC bikes had two ring and the SX bikes were one. You can use either. BTW, Vertex makes most of their pistons.
Old 11-15-2012, 07:05 PM   #5
Bigbugberg OP
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 320
Both piston numbers have two rings, and the second is an oil sweep (pn 78030032200).
So what is the difference in the pistons?
2010 KTM 690 Enduro
Old 11-15-2012, 07:08 PM   #6
Bigbugberg OP
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 320
...plus, Vertex only makes gasket sets for this bike...
2010 KTM 690 Enduro
Old 11-15-2012, 09:15 PM   #7
LukasM
Oddometer: 5,384
Originally Posted by JTucker View Post
One ring or two.
Size one and two refers to size and not rings.
OP,
Pretty sure that one is meant for a fresh cylinder, the other for one that's been used and then diamond honed. Tiny size difference, about 0.01 mm if I remember correctly.
Old 11-17-2012, 11:18 AM   #8
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,818
KTM has done updates with newer style piston/rings I believe,talk to someone in the know and make sure your getting the best kit,measure the bore carefully. Check the valve seals,make sure they're not leaking and sucking oil.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 11-17-2012, 02:09 PM   #9
gatorgrizz27
Oddometer: 133
There are very slight, as in less than 0.001" variances in machining the cylinders and pistons when they come from the factory. Basically KTM sorts the cylinders and pistons by slightly under or over specified size, and matches them. You will have to mic your bore to be sure which size it takes, the service manual should tell you the limit. Last one I did I asked a very reputable KTM mechanic that is a buddy of mine if I could just buy the larger size piston since the bore would have worn enough that either one would fit. He said no, the Nikasil really doesn't wear at all, and it is important to mic it before you order the piston. It sucks to have to tear it down and leave it apart for parts.
gatorgrizz27 is offline   Reply With Quote
Old 11-17-2012, 09:39 PM   #10
WetSideRider
Oddometer: 1,151
On my Husaberg 390 (same piston) the size was stamped on the piston. As stated above, you don't bore the cylinder, you replace like rings or ring and piston kit.
WetSideRider is offline   Reply With Quote
Old 11-18-2012, 08:44 PM   #11
neumie
neumie's Avatar
Oddometer: 129
Lots of info on ktm talk.com
Definitely look there for info and experts.
2009 KTM 400 XC-W
neumie is offline   Reply With Quote
Old 11-30-2012, 06:14 AM   #12
dyno_dave
Oddometer: 6
Piston size
I have the same bike. There is a stamp on your cylinder, a I or II, indicating its size. On my bike the stamp is near the area which houses the timing chain tensioner.
The original pistons are manufactured by Mahle not Vertex.
Let me know how much you paid and where you bought your kit. Mine has over 10k miles on it now and is due for a replacement. When I originally put rings in it at 3k miles the piston was near the high limit for clearance.
Dyno_Dave
dyno_dave is offline   Reply With Quote
Times are GMT -7.   It's 09:39 AM.
