Old 12-02-2012, 02:47 AM   #61
England-Kev OP
Oddometer: 3,574
I wonder if someone will save this one....
http://www.ebay.com/itm/1970-Moto-Gu...ac89d9&vxp=mtr
I like the rear pillion footplates, very cool, why did Guzzi make so many styling changes for the same year?
England-Kev is offline   Reply With Quote
Old 12-02-2012, 05:47 AM   #62
photomd
photomd's Avatar
Oddometer: 724
Do you have Guzziology? It's a great read and filled with all kinda facts on that help maintain Guzzi's.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is offline   Reply With Quote
Old 12-02-2012, 08:16 PM   #63
MZRider
Neo-Luddite
Oddometer: 704
Originally Posted by England-Kev View Post
I have a plastic cover, I wonder does it serve a usefull purpose, or is it just a vanity cover to hide the generator? is it worth fitting full stop?
Thanks for the tip on the fork oil, I will go for a heavier weight when I do them, it won't be today though, as it is -6 here this morning, with a heavy frost, s it is a morning for hot coffee, and a little computer motorcycling
Are there any tips on setting up the clutch side of things, as I find it hard to select first gear, and all gear changes are at best very clunky I hope I don't have to pull the back end apart just yet.
The generator cover is really just hiding the ugly bits from view. Mine has been without for most of the last 15 years.
Greg Bender has a section on clutch adjustment that may prove helpful: http://thisoldtractor.com/gtbender/m...tch_adjustment
The 4 spd. is known for clunky changes, but with time and practice you'll get better.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 12-03-2012, 02:15 PM   #64
England-Kev OP
Oddometer: 3,574
What are the two mounting holes for on the handlebar clamps?
Old 12-03-2012, 04:28 PM   #65
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,607
I believe the 2 in the center are for a faring brace.
no idea what the one by the clutch perch is,
mine didn't have that
edit: actually think the 2 on the perch are for the original "snuff box" headlight switch
Bloodweiser screwed with this post 12-03-2012 at 04:33 PM
Bloodweiser is offline   Reply With Quote
Old 12-03-2012, 05:08 PM   #66
danedg
Horizontally Opposed
Oddometer: 6,610
What year is that thang?
danedg is offline   Reply With Quote
Old 12-03-2012, 11:59 PM   #67
England-Kev OP
Oddometer: 3,574
It says 1970 on the headstock Vin plate, I think it is a euro model though, as it has KM/H clocks
Old 12-04-2012, 04:01 PM   #68
nick949eldo
Oddometer: 955
Fairing braces.........
Nick
nick949eldo is offline   Reply With Quote
Old 12-27-2012, 02:34 PM   #69
England-Kev OP
Oddometer: 3,574
Well I shall try to get the clutch adjusted tomorrow, I have bought a new cable, but I think I need to adjust the plunger at the gearbox end (there seems to be a lot of play at that point) any advice on this will be gladly accepted...
Old 12-27-2012, 03:46 PM   #70
danedg
Oddometer: 6,610
The Manual states...
Guzziology cautions to not over adjust the free play. Make sure the lever doesn't come in contact with the back cover before he's done pushin' it in....
Old 12-28-2012, 05:58 AM   #71
England-Kev OP
Oddometer: 3,574
Spent the morning playing with the Guzzi, gave it some Ambo decals on the battery box sides, and I fitted the christmas present I bought it, in the shape of a new correct fuel cap. I then fitted the new clutch cable and adjusted it up, but it is no better than the old one in action, so I may jhave to dig deeper
Old 12-28-2012, 07:21 AM   #72
JonnyCash
turd polisher
Oddometer: 1,571
Kevin, that bike is just absolutely beautiful. To me, it's just the right mix of shiny, and patina. It's good for me to see this, as I'm in the middle of a rebuild, and I'm having a lot of trouble, letting what I originally intended to be a get-it-running-and-just-ride-it job drift into a fix-everything-that-is-showing-any-wear job. Your photography is beautiful too. Thanks for the updates!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 12-28-2012, 07:27 AM   #73
FJ_Kevin
Oddometer: 365
The white ones polish up easy, just needs a little elbow grease . Same year (1970) as above.
My '81 YZ465 Factory Race Replica
http://www.advrider.com/forums/showthread.php?t=772033
My Vintage Husqvarna/Motocross Restoration Extravaganza Thread
http://www.advrider.com/forums/showthread.php?t=964670
FJ_Kevin is offline   Reply With Quote
Old 12-28-2012, 09:18 AM   #74
England-Kev OP
Oddometer: 3,574
Originally Posted by JonnyCash View Post
Kevin, that bike is just absolutely beautiful. To me, it's just the right mix of shiny, and patina. Thanks for the updates!
Thank you, I will never be able to restore a bike, as I don't have the time, inclination, or facilities to do so, I would much rather be riding a tatty bike, than not riding a restored one, buy hey, that's just me. Do you like how I fitted red HT wires to match the pinstripe on the tank I have done fitting new parts now, maybe a whitewall tyre on the front sometime, right now I just want to get it changing gear sweetly and I will be happy.
Old 12-28-2012, 09:33 AM   #75
England-Kev OP
Oddometer: 3,574
If I have the clutch cable adjusted correctly, could my gear selection problems be down to the gear change linkage?
Times are GMT -7.   It's 02:07 AM.
