Old 12-30-2012, 08:39 PM   #91
MZRider
Neo-Luddite
Oddometer: 704
IMO, there's little value in messing about with the eccentric screw on the preselector cover. I doubt it will help with your first gear issues. Some info. here: http://thisoldtractor.com/gtbender/m...e_on_a_4_speed
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 12-31-2012, 05:11 AM   #92
England-Kev OP
Oddometer: 3,572
Ok, Thanks.
I noticed that my Guzzi already has the ball joint and threaded bar conversion, so someone in its past has played in this direction, I shall set too and remove all the play, and see where that leads me.
They have us booked in for a sunny day tomorrow, Jan the 1st, 2013. So maybe I can get out for a ride without the need for water wings.
England-Kev is offline   Reply With Quote
Old 01-02-2013, 11:16 AM   #93
England-Kev OP
Oddometer: 3,572
Is there anything I need to be aware of when pulling the cylinder heads? special tools etc?
Old 01-02-2013, 01:29 PM   #94
nick949eldo
Oddometer: 955
Just don't forget the engine bolt that resides in a deep hole beneath the large nut! The head won't come off unless you remember that one (don't ask.....).
Nick
nick949eldo is offline   Reply With Quote
Old 01-02-2013, 03:04 PM   #95
danedg
Horizontally Opposed
Oddometer: 6,595
The six head bolts are only accessed after the rockers come off.
No. 6 is under the sparker..
After that, you're on the slippery slope!
danedg screwed with this post 01-02-2013 at 03:10 PM
danedg is offline   Reply With Quote
Old 01-02-2013, 03:22 PM   #96
England-Kev OP
Oddometer: 3,572
Thanks, well I have to cure this oil leak, so I have to get my hands dirty, what is the score with the recessed nut?
Old 01-02-2013, 04:40 PM   #97
nick949eldo
Oddometer: 955
Nothing special. You just need a long socket. It should come off as easily as all the others.
N
Old 01-02-2013, 04:46 PM   #98
danedg
Oddometer: 6,595
Shiny and Fresh
The big nut on top [22mm?] is a cover. Underneath is the 6th headbolt...
SSSSHHHHHHHhhhhhhhh...
It's a secret!
Old 01-03-2013, 05:35 AM   #99
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 344
That recessed bolt-hole cover plug is 26mm for the old ones.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 01-03-2013, 10:22 AM   #100
MZRider
Neo-Luddite
Oddometer: 704
+1
Under it you should find a socket-head nut - I use a 10mm hex bit on a short extension to reach it.
Charlie
Old 01-05-2013, 10:40 AM   #101
England-Kev OP
Oddometer: 3,572
Do any of you guys have a parts diagram for the early v7 forks, my forks don't have an external drain screw? just trying to find out what I need to replace, as I have a fork oil leak...
Old 01-05-2013, 07:48 PM   #102
MZRider
Neo-Luddite
Oddometer: 704
All Loop forks have a drain screw (unless someone has plugged the hole for some stupid reason). It's located on the lug where the rear brace of the front fender attaches to the fork lower/slider.
Places for leaks and what to do about them:
- drain screw - replace fiber sealing washer
- big o-ring at the top of the slider, where the chrome seal holder threads on - replace o-ring
- around the crimped area of the seal holder - apply JB Weld to the inside
http://thisoldtractor.com/gtbender/m...t_crimped_area
- fork seal - replace
- top plug o-ring - replace
Parts diagram: http://thisoldtractor.com/gtbender/m...g_750_1aed.pdf
Fork rebuilding:
http://thisoldtractor.com/gtbender/m...ork_rebuilding
Charlie
Old 01-06-2013, 04:34 AM   #103
England-Kev OP
Oddometer: 3,572
All Loop forks have a drain screw. It's located on the lug where the rear brace of the front fender attaches to the fork lower/slider.
Aha! found the little sucker, it was hiding just where you said it was, and it was loose! I couldn't see it before because ...
A. I am stupid
B. I am an old git
C. I don't have a bench so it is hard getting down that low to look
D. all of the above.
Old 01-06-2013, 06:30 AM   #104
England-Kev OP
Oddometer: 3,572
I bought my Guzzi some late model inlet stubs, the ones with the raised section, so yesterday I drilled and tapped these for use with carb balancer fittings. All finished off with nice polished 5mm dome head allen screws and copper washers.
I shall swap these over in a week or two, when I do the head gaskets.
Old 01-06-2013, 07:13 AM   #105
Bongolia
stop acting
Bongolia's Avatar
Oddometer: 17,170
great thread.
Kev, you know Joe Caruso in Loughborough? Not sure what he is like on ambos but he has a line on most things Guzzi.
Also Gutsibits in Huddersfield.
Former Farmer.
G 850 LM Mk II
http://advrider.com/forums/showpost....ostcount=53377
Bongolia is offline   Reply With Quote
Times are GMT -7.   It's 11:53 PM.
