Old 05-29-2014, 09:18 AM   #1
EricV OP
EricV's Avatar
Oddometer: 206
What is this part/thingie?
Hi Gang. This isn't bike related, but figured I'd throw this out to this gang as there are folks here from all walks of life/occupations. This is along the lines of "for sh*ts and giggles."
I found this thinga-ma-jiggy laying on the road outside of my office. I picked it up and it's sat on my desk for two years. No one seems to know what the he*l it is- I sure don't. It's 2.25" long and 0.5" in diameter. Of significance: 1.) inside the hole at the "top" there's a bore there that runs deep, and lining that is a beefy spring- if I stick a nail in there I can depress the spring, so it's not threads. 2.) the part w/ the hole in the end, and it's lower "shaft" are independent of the "base"- i.e. it spins loosely inside that larger piece (w/out the hole) and has about 2mm of play. The two pieces will not separate though and can't feel any spring tension. It's kind of beefy/weighty. I suspect (based on nothing) that it has to do w/ construction equipment, or perhaps a weird fastener of some type.
I'm a man of little means, so I'm afraid there's no prize for the winner except for the huge satisfaction that comes with knowing you've put my mind at ease and I can quit staring at this thing. :) Here it is:
Thanks gang!
EricV is offline   Reply With Quote
Old 05-29-2014, 10:03 AM   #2
74C5
74C5's Avatar
Oddometer: 974
Fuck you very much for completely sucking in my OCD to try to figure out what that is as well. I'll have to spend the next hours at work thinking about that until my ADHD kicks in...........YOGA PANTS GOING BY MY CUBE!
Maybe a franjit nut for a muffler bearing?
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 05-29-2014, 10:15 AM   #3
EricV OP
EricV's Avatar
Oddometer: 206
Ha! At least now I no longer suffer alone. :)
If it helps the inscription/stamping that is barely visible says, I think (as it's fairly beat), "Brooks U.P." I googled around that a year or so ago to no avail.
Old 05-29-2014, 10:27 AM   #4
joexr
Oddometer: 3,773
Brooks Utility Products . It's a lock.
Old 05-29-2014, 10:29 AM   #5
Navin
Navin's Avatar
Oddometer: 7,985
Magnetic shit masher from a sewage treatment plant. Spring loaded to increase oscillations exponentially, really works the feces into a froth.
Is that actually ON your desk???
Navin is online now   Reply With Quote
Old 05-29-2014, 10:34 AM   #6
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,225
+1
I've seen them used to lockout gas service valves. Not sure what other purposed they have.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 05-29-2014, 10:35 AM   #7
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,758
Plunger from a solenoid valve. Or a muffler bearing. Not sure which.
Laconic is offline   Reply With Quote
Old 05-29-2014, 10:37 AM   #8
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
Bingo!
http://www.brooksutility.com/products/59
Navy Chief is offline   Reply With Quote
Old 05-29-2014, 12:32 PM   #9
EricV OP
EricV's Avatar
Oddometer: 206
Navin- I gotta admit you had me a little freaked. :)
Huge thanks guys...I'm impressed with the speed at which this useless little mystery was solved- should have thought to post here long ago!
Old 05-29-2014, 04:59 PM   #10
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Yep,it's a lock. I see em every few weeks or so.
Danjal is offline   Reply With Quote
Old 05-29-2014, 05:06 PM   #11
trailer Rails
trailer Rails's Avatar
Oddometer: 4,065
You should try and pay your bills more often.
trailer Rails is offline   Reply With Quote
Old 05-29-2014, 05:32 PM   #12
GP640
GP640's Avatar
Oddometer: 3,351
Looks like a tool used to install the grapple grommet on a Mk 5 Turbo Encabulator.
GP640 is online now   Reply With Quote
Old 05-29-2014, 05:47 PM   #13
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
They use em as lockout devices at a few plants I go to. Not LOTO, but to shut off gas and secure it. The LOTO tag is normally attached to it somewhere or locks the key on the whole device.
Old 05-30-2014, 10:47 PM   #14
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,297
So how do they work, and what exactly do they lock?
GreaseMonkey is offline   Reply With Quote
Old 05-31-2014, 05:00 AM   #15
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,688
Looks like a two part grommet installer or some sheet metal dimple die. I know it's not, as described correctly above, but might have life as something else.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Times are GMT -7.   It's 10:55 AM.
