Old 11-29-2012, 12:31 PM   #46
kels
Oddometer: 17
couple of other thoughts
Has the antifreeze been checked in the radiator?
Need to have it checked and make sure it is good down to at least 20 below zero.
How old is her battery? Cold and Hot weather is
hard on batteries. If it is more than 36 months old,
you might go ahead and replace it.
How are the tires on her car?
Also a couple of the cheap plastic floor mats
work well to keep windshield clear.
Put the wipers half way up and put the mats under them on the windshield.
That way you can pull them off and have a semi clear windshield
AND LAST BUT NOT LEAST. LEAVE A VEHICLE KEY SOMEWHERE
SHE CAN GO AND GET IT. IF SHE LOCKS THE KEYS IN THE CAR.
It does no good if the spare is at your house.
If she is living in a dorm, hide a set somewhere in her room.
That way, worse comes to worse, she can have staff let her into her room and
then go back for her car.
Cheaper than a 75 dollar locksmith call.
kels is offline   Reply With Quote
Old 11-29-2012, 01:23 PM   #47
568V8
Ontario Vstrommer
568V8's Avatar
Oddometer: 186
BBQ lighter
Canadians are experienced with frozen cars.
Carry a high-powered butane BBQ lighter to thaw the locks. Done it many times on old Volvos, even used propane torches on low. It warms, thaws and dries out the lock. Don't ever use hot water!
Lots of WD-40 in the key hole and silicone spray on the rubber. If the lock won't open, then we use a frozen beaver to smash a window.
568V8 is offline   Reply With Quote
Old 11-29-2012, 01:43 PM   #48
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,636
Obtain a GOOD booster pack for her, as well. If you're unfamiliar, its basically a motorcycle battery with short jumper cable leads. The booster lives in the house on its charger, if she gets into the car to find the battery dead, a fully charged booster will get the engine started.
If you're worried about her mechanical aptitude - i.e. hooking it up backwards - have her bring the car to a shop that installs snowplows. They'll be able to install a high amp connector on the battery, this connector lives somewhere near the grill and is accessed by pulling the cap off and plugging a mating connecter attached to the booster cables. The connectors are keyed, its impossible to plug them in wrong.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 11-29-2012, 05:49 PM   #49
mudgepondexpress
Oddometer: 1,151
I drove a V8 powered Ford Courier from 1981 to 1995. A pickup with no heat, and not designed for cold weather (locks froze, doors stuck, heater doesn't have enough airflow to keep front window clear). I carried a self igniting propane torch to heat the locks and run around the door so it would open.
Yes, armor all/silicone the door seals, use a water displacing lubricant for the locks and door handles (WD40), and a good booster battery is nice to carry. If you have a sunroof keep it unlatched when parked...it makes a handy entrance when things get really bad.
Get a strong plastic scraper and sharpen it on a piece of glass with some wet/dry paper. Most of them are warped and cut 2 grooves, flatten it out and it will cut your scraping time down. When it is cold and moist, lower the drivers window 1/2 inch or so to help vent the hot/moist air...this will keep the front window clear. Don't run the heater on recirulating, it builds up the moisture and then you fight ice on the inside.
Good tires are a must...even with front wheel drive!
Get you windshield fluid at a place that changes stock depending on the temperature. They make stuff for CA and the like that is only good down to 30 degrees or so.
She will be fine...have faith.
Kenny
mudgepondexpress is offline   Reply With Quote
Old 11-29-2012, 08:11 PM   #50
hajime
hajime's Avatar
Oddometer: 196
Some part of our beings longs to join a band of brothers on a daring and intrepid quest. ~Carl Sagan
hajime is offline   Reply With Quote
Old 11-29-2012, 08:45 PM   #51
Jailor8
Jailor8's Avatar
Oddometer: 2,318
Great Except
Originally Posted by FlyingFinn View Post
Such a sob story
A college kid has to drive a 99 Camry. With no power locks!! Where's the justice!!
Silicone on gaskets, good.
Oil in the lock cylinder, good.
De-icer to get a frozen lock (there was no oil) to open, good short term bad long term.
Prevention really is the key here.
Oil the locks and silicone the gaskets, that way the won't be problems with freezing.
Using the de-icer get her out of the pickle at that moment but the de-icers also tend to flush out any trace amounts of lubricant from the lock cylinder.
Then it freezes even worse.
Mikko
Great except for one thing......
Never put oil in a lock tumbler!! In cold weather it gums up and it attracks dirt. Always powdered graphite or at least a dry lube in locks, Silicone spray is ok as it drys out after application.
And if the door is iced over totally, push in with both hands all around the edge this breaks the ice, flexs the seal and usually will let you in if after its unlocked and you still cant get in because the door is froze shut.
Jailor8 who twists keys in locks all day long everyday for 23 and counting years, I get to maintain them too.
Never push a loyal person to the point they don't care anymore.
No Humans, before Coffee!!
RIP my Mother, She should certainly be up for Sainthood!!
RIP my Cousin, Austin City Limits aka Terry Hammond
KTM950A, KLR685, KLR650, KLR250, KLX250, Honda Rebel, Foretrax Foreman 4x4
Jailor8 is offline   Reply With Quote
Old 11-30-2012, 12:54 PM   #52
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,186
Never had a frozen lock. Had plenty of doors that froze shut though. Coat the door seals with a thin film of Vaseline and you won't have any problems.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 11-30-2012, 02:48 PM   #53
urbanXJ
urbanXJ's Avatar
Oddometer: 3,054
this is not a joke, but once in CO on a fieldtrip there was an ice storm and the doors of the cars were frozen shut.
The cars were parked far form the cabin, so we couldn't use a garden hose.
So, we pissed on the door seams. After about 5 or 6 guys the ice was melted.
So, maybe pee on the lock?
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 11-30-2012, 03:38 PM   #54
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,261
I live in the Sierras where heavy snowfall (more then a foot) is rare, but we do get rain followed by a hard freeze a few times a year. Don't believe that stuff about hot liquid not harming windows. They will crack. (even worse than A/C will crack a hot window with a chip in it). Hot water right on the lock would do the trick. Spraying washer fluid probably won't work. I notice it freezes immediately when I spray the washers on the windshield, causing a big blue sheet on the window...worthless.
I really like the idea of covering the lock with a magnet. I'm going to use that one for sure. I have had times where I couldn't even get the key in. I think a magnetic bumper sticker would work nicely on a recessed lock.
The other thing I do it place a large beach towel over the windshield. No frost bitten fingers for me! Make sure the bottom edge of the towel covers the windshield wipers, though. If they get frozen to the window, the wiper motor may have enough power to break them right off the stalks. (ask me how I know ).
The silocone spray is also a good idea. Not because the door won't open, but because when it does, all the seals will be ripped from the door (ask me how I know ).
High Country Herb is offline   Reply With Quote
Old 12-11-2012, 11:56 PM   #55
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,925
Buy a birthday present for yourself and get her Triple-A.
"Son, you can't do both"
Old 12-12-2012, 10:16 AM   #56
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,535
Tell the young lady to "park & turn off" the windshield wipers before switching off the ignition. Otherwise may damage the mechanism when you turn the ignition on and they are frozen on the windshield.
I hate scraping windshields and defrosting cars, used to do that for a living, always fun cleaning the yard after snow/ice storms, we used to have up to 100 cars in the yard, always lots of them frozen shut. Spray bottle with Methyl Hydrate that was our cheap way.Refill from the 45 gallons drum. And always more than a few that wouldn't start, hook them up and bring inside til they thawed out.
Still hate scraping windshields....now I use this to free my recessed wipers and electric windows.Yeah....3/4" or so of ice on my windshield right now, that's why I have the product out.
Hum....whatever is in the pocket flask may also work.
Have tools, will travel!
Old 12-14-2012, 06:08 PM   #57
BigChris99 OP
BigChris99's Avatar
Oddometer: 279
Thank you all for the help and advise. My daughter will be home tomorrow evening here to southern California for the holidays. Can not wait. I will point her towards this thread while she is here. Thank you.
4on3off
IBA#7849
1997 Honda Valkyrie, 1998 Kawasaki KLR 650
BigChris99 is offline   Reply With Quote
Old 12-14-2012, 10:44 PM   #58
erda
erda's Avatar
Oddometer: 212
Another trick is to use compressed air on the locks and mechanisms after you've washed the car. Other wise as others have suggested, lock deicer, or a product called Lock-Eze if it is available.
Current ride: 2009 Bandit 1250SEA
Previous rides: 2009 V-Strom 650SEA; 2004 Kawasaki Ninja 500ex
erda is offline   Reply With Quote
Old 12-15-2012, 10:31 AM   #59
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,646
Frozen Beaver...
or this....
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-15-2012, 10:53 AM   #60
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,535
^^^^Spring loaded center punch, much easier to C/C.
Times are GMT -7.   It's 05:29 AM.
