| View Results: How do you guys prefer to take care of your chains? | |||
| Lube and clean after every ride.....the bike chain, not the women lol |
14 | 31.11% |
| Lube and clean whenever it gets noisy or I feel guilty |
19 | 42.22% |
| Just clean with WD-40 |
5 | 11.11% |
| Its an o-ring chain, no lubing needed, and only clean when its really dirty/muddy |
8 | 17.78% |
| Hookers for maintainence |
2 | 4.44% |
| Multiple Choice Poll. Voters: 45. You may not vote on this poll | |||
11-16-2012, 08:18 PM
#1 |
Oddometer: 641
On my streetbikes that never see dirt or rain, I clean and lube the chains every 800-1000 miles or so, the chains stay nice and quiet with lube on them during that time. On my dualsport, after one short dry dirt ride the lube is gone...if I want to keep it greasy to the touch, I'd need to lube it continously....which honestly with 4 bikes and a busy schedule I don't really have time for.
So how long do you guys get out of a chain with constant lubing vs less often? If the difference isn't too much I might just lube less and replace chains and sprockets more often as needed
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
11-16-2012, 08:33 PM
#2 | |
Oddometer: 4,141
11-16-2012, 11:10 PM
#3 |
Oddometer: 90
i use motorex degreaser and dirt lube on my chain. if im just riding street i will degrease and lube maybe once a month...for dirt riding i just degrease and lube after the ride is done and my bike is washed (edit: sometimes this means a couple dirt rides and a week or two before degreasing and lube, i get lazy with washing the dirt off and the degreaser and lube dont get used unless ive hosed her down)
davidb21 screwed with this post 11-16-2012 at 11:19 PM |
11-16-2012, 11:27 PM
#4 |
Oddometer: 48
I don't do it often enough, but with that being said my 09 klx 250 has over 5K miles on the stock chain and has only been adjusted once in it's life. I'll probably get nearly 10K miles from a stock o ring chain with very little maintance.
11-16-2012, 11:46 PM
#5 |
Oddometer: 1,380
This is something I have struggled with for a long time. Until now I used to lube it after pulling into the garage while the chain was still warm. The next morning before I took off I'd wipe any excess lube off the chain. Fling would still get all over the bike, but not as much as before I wiped it. I finally broke down and bought the Scott's oiler for my V-Strom 650. This thing is well worth the money. Since it only puts a drop on every minute or so, there is a lot less fling to clean off when I wash the bike. Before as soon as I'd start off, globs of excess lube would just fling off all at once. Now when it does, its very little comparatively speaking. It also puts the lube right where it needs it, and does it while its warm which lets it soak right in. In about 300 miles I'll replace my stock chain and sprockets. The sprockets look pretty decent, but I'm a bit worried about the chain. I'm about to take off on a 3000+ mile trip for 8 days and don't want to have to worry about it. The stock chain now has 23,550 miles on it.
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350 |
11-17-2012, 09:56 AM
#6 |
Oddometer: 4,141
another reason i like the oily chain lubes is because i get a black film build up on my chain and sprockets so it doesnt have much metal to metal contact. my sprockets seem to not wear at all or very little and i can reuse them with a new chain.
11-17-2012, 10:13 AM
#7 |
DualSport Crazy !!
Oddometer: 829
I clean with WD and and electric toothbrush after every dirt ride and use a chain wax. If no dirt I clean weekly or 2-300 miles, whichever comes first.
"Where ever you are, there you go..." |
11-17-2012, 10:43 AM
#8 |
Southern Ontario
Oddometer: 1,990
I picked #2 as it was the closest, but it isn't totally accurate.
Every couple weeks, or after riding in wet conditions, I:
I typically do this after a ride, when the chain is hot and dry. Takes 5 minutes on the bike with a center stand, 10 on the one without. I use an old scrap of cardboard to keep the junk off the tire and wheel. If it is raining when I arrive home, I just use a little varsol on a rag to wipe off excess water, and clean/lube it before the next ride. Easy to do, don't mind it at all. |
11-19-2012, 11:45 PM
#9 |
Oddometer: 641
Thanks for all the feedback guys, I picked #2 as well, it looks like I'm in the majority. I tend to wait till I can hear my chain making a little noise, or I look at it and feel quilty
That seems to end being about every 500 miles or so. I'd love to keep it better lubed, but lubing after every ride or during rides isn't going to happen for me. I am going to look into the Belray synthetic lube suggestion, and check out the Scott-Oiler as well tho. I'm also thinking it might be quicker and easier to just spray the chain lube into a rag, and wipe it on the chain good...would save the big hassle of overspray all over everything (a pain to clean off the bike/floor etc), and would be much quicker and easier than putting the bike up on the stand, or rolling and spraying. I might actually lube after every ride that way
11-20-2012, 07:41 AM
#10 |
ride the night
I shoot some sort of oil or wd40 on it to keep it from rusting too bad
11-20-2012, 08:52 AM
#11 |
Oddometer: 3,964
interesting none of you run non oring chains...jejeje
I know Im the minority dont ask me how I maintain it as it will start a can o worms ![]() ![]() I like to think I have less rolling resistance! ajajajajaajajajajajjaaja |
11-20-2012, 09:10 AM
#12 |
Olds Cool Adventurer
Oddometer: 2,673
I rarely clean my X-ring and o-ring chains. For how much trouble it is, I'll just get a new one every 5K or whatever.
I lube the chain while it is still warm, about every 3-4 hours of ride time, using Bel Ray super clean. I spray it only on the sprocket side of the chain, and turn the rear wheel about 30 revolutions to work it in. |
11-20-2012, 10:02 AM
#13 |
Oddometer: 55
I've had the best luck cleaning with kerosene and using a dry lube. I always try to avoid high pressure water on an o-ring chain. I reapply the dry lube every 1 to 4 rides depending on the conditions and clean with kerosene when things look built up. If I'm pressed for time and everything is wet, I'll spray it down with wd40 to prevent rust and do a more complete maintenance before the next ride. I've heard of guys using nothing but wd40 and getting good life out of a chain but I haven't tried that yet.
I don't know how much good quality lube matters in the mud/wet season because after 100 yards of riding, everything is pretty well covered in mud and grit anyway. |
11-20-2012, 10:31 AM
#14 |
Oddometer: 372
Clean the chain thoroughly with compressed air. If needed, rub it down with a rag dipped in kerosene or diesel being careful around the o-rings. When riding or parked, don't let the chain get wet, period, and it if does, dry it out ASAP otherwise it will rust (if you aren't using any wax or lube like me). I don't ride when it's wet out because I hate cleaning mud off anything so avoiding water is easy for me. Even with the occasional creek crossing, I think the chain's heat dries itself out during the ride so as to avoid rusting.
This faux regimen has made my RK EXW chains last at least 15k miles and I don't have to deal with any messy cleaner, wax or lube. I use to do cleaning and lubing, found it to be more messy than anything with negligible positive results, the best being quietness which never really mattered to me. I'd rather just spend $100 for new sprockets and chain every 15k (1-3 years) and never have to deal with the driveline otherwise (except slack adjustments). In my experience, kinks in a chain are better fixed with slight outwards pressure on two small screwdrivers placed inside the kinked link. I prefer to direct my best cleaning efforts towards the air filter. |
11-20-2012, 10:58 AM
#15 |
Dual Sport Addict
Oddometer: 988
I live in the high desert so moisture is not a huge issue for me. I like to keep my chain fairly dry so as to not collect sand and dust. I prefer to just clean my chain when it looks like it needs it using WD-40. After its clean I wipe it with a clean rag with WD-40 on it.I think that prevents rust. I have tried lubes in the past but I find they collect to much dirt and make to much mess for me to handle. I have not so far experianced short chain life useing this method in these conditions. When I lived on the other (wet) side of the mountains I did run lube but it was miserable.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
