Old 11-16-2012, 08:25 PM   #1
villageidiot OP
Oddometer: 1,772
pannier mount kit 1/2 inch?
im mounting some seahorse cases onto my triumph bonneville.
the racks im modifying for use are 1/2 tubing. i have not been able to find a "puck kit" or mount set available for 1/2 inch tubing.
ive seen some crafty shit done with a cutting board, but i don't care for that look.
anyone have suggestions for a mount set for me?
thanks in advance.
villageidiot is offline   Reply With Quote
Old 11-17-2012, 05:02 AM   #2
Grinnin
Forever N00b
Oddometer: 2,769
I used 1/2 by 3/4 black polyethylene from McMaster-Carr with steel on the wheel side of the rack. After the first year it loosened up enough to rattle so I took it apart and shaved the 1/2 down a bit with a regular woodworking plane which works great on poly.
If any of the puck kits are polyethylene you may be able to shave them if you have good plane skills -- it will be more difficult than the 3/4-inch face I was working on.
If you could be more specific about what part of the "crafty-shit" look you don't care for . . .
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is online now   Reply With Quote
Old 11-18-2012, 10:36 AM   #3
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,531
Happy Trails has mounting pucks in three different widths.
http://www.happy-trail.com/Happy-Tra...Mount-Kit.aspx
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 11-19-2012, 06:14 AM   #4
villageidiot OP
Oddometer: 1,772
I ended up not using a "puck" at all. I welded 2 pieces of 1" x 3/16 thick flat stock on each side rack with holes drilled in them to simply bolt on the cases. On my last 3 bikes, I've used happy trails mount kits. But I never took the cases off any of them, so this time I figured to Just bolt em on.
Will post pics later tonite.
Bike is a triumph bonneville. I'm mounting seahorse se720 cases to.
Old 11-19-2012, 08:18 AM   #5
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,074
I've used hockey pucks to machine into mounting pucks . . . . . cheap, black, and don't mind cold.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
bomber60015 screwed with this post 11-21-2012 at 09:47 AM
bomber60015 is online now   Reply With Quote
Old 11-21-2012, 09:32 AM   #6
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,919
P clamps or u bolts. Unless you want a quick release.
u channel steel square\rectangular tubing for the bottom rail works nicely too.
HaChayalBoded is offline   Reply With Quote
Old 11-21-2012, 07:45 PM   #7
villageidiot OP
Oddometer: 1,772
i welded "straps" of metal to the vertical plane of my racks, with holes in them to bolt the cases to (seahorse se720)
ive got a total of 105 bucks into my racks including hardware and powdercoat, i started with the saddle bag supports from seller losi3030 (on ebay) for my bonneville, they were 60 bucks uncoated.
the seahorse se720 cases with locking latches, were 135 to my door for the pair.
so for 240 bucks, ive got waterproof, dustproof, hard lockable luggage, all made in the USA, gotta love that.
Times are GMT -7.   It's 10:31 AM.
