Old 11-13-2012, 09:00 PM   #1
corndog67 OP
Oddometer: 1,281
Cold Starting
OK, I get off of work this morning, 1 am, the Katoom cranks slow, maybe 5 or 6 cranks, and then the battery dies.
My question is, are these bikes temperature sensitive? When it's fairly cold (it was about 35 degrees F.), are there any common starting issues?
Started up easy enough off a truck with some jumpers. Got home and put it on the charger, showed less than 25% charge (smart charger). Charged it until the charger went off, and it seems OK now, but is this something common on really cold starts?
Thanks, Robert
corndog67 is offline   Reply With Quote
Old 11-14-2012, 04:26 AM   #2
wildehond
wildehond
wildehond's Avatar
Oddometer: 334
Cold also depletes your battery's power quite a bit. So I think it was a few things working against you. The cold, under performing battery, the cold, tight engine. How old is the battery? Mine last about 12 to 18 months and then they do not start the bike porperly in cold weather any more.
Wussy Namibia solo ride
wildehond is offline   Reply With Quote
Old 11-14-2012, 06:37 AM   #3
666
Agnostic and Orange
666's Avatar
Oddometer: 1,320
My stock yausa started doing the same few weeks ago. It takes a day to fully charge and battery was dead overnight. I replaced it. 6 years is not that bad.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 11-14-2012, 01:46 PM   #4
corndog67 OP
Oddometer: 1,281
Thanks guys. I'll get the battery load tested.
Old 11-16-2012, 10:00 AM   #5
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,514
The better solution is to just give in and get a new battery.
I had similar problems on occasion with my 990 Adv. After the third time I had to jump start it to get home I bought a new battery. The old one was "still good", so I saved it for a while, but finally gave up on that and recycled it too.
My philosophy is that if I have battery problems twice within a 30-day period get a new battery instead of trying to coax a little more life out of the old one.
Old 11-16-2012, 11:51 AM   #6
Qwik
Adrenaline Addict
Oddometer: 6,947
New battery is cheap. But Make sure your connections are good as well.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 11-16-2012, 01:20 PM   #7
Douf
Limey Bitch
Douf's Avatar
Oddometer: 772
Some rough figures relating battery performance to temperature
http://www.aa1car.com/library/2003/us20310.htm
Douf is offline   Reply With Quote
Old 11-16-2012, 01:24 PM   #8
Rinty
Rinty's Avatar
Oddometer: 559
And don't lead acid batteries, especially bike batteries, sulphate up if they're left sitting for a time, off charge?
Rinty is offline   Reply With Quote
Old 11-16-2012, 01:59 PM   #9
Dan950ser
NW Shredder
Oddometer: 521
I went to go start my bike and it barely started and just dies after 30 seconds. Do the 950s not run when the battery is too low or can it run without a battery. Kind of scared me lol.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR Sale Pending, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 11-18-2012, 09:56 AM   #10
Dustodust
Dustodust's Avatar
Oddometer: 1,075
I installed a headlight off switch , I turn headlight off before cold starting and parking for the night. Saves a lot of battery power
I have a plug out the side to painlessly hook up the Deltran tender and it also connects to the HID helmet lights , also works as a jumper
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 11-18-2012, 10:18 AM   #11
Dan950ser
NW Shredder
Oddometer: 521
I usually have mine on a tender. Battery is a couple years old now. Just never had a running issue before. Hope it's just a battery.
Old 11-18-2012, 11:49 AM   #12
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 272
My stock Yausa lasted 6 years. It was put on a trickle charger every night. I replaced it with a Ballistic Evo2 LiFePO battery 430 cca. Much lighter and smaller.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 11-18-2012, 02:23 PM   #13
Doorguy1979
Dreamridin'
Doorguy1979's Avatar
Oddometer: 627
Mine liquid acid battery does get weak when it gets cold. I can get two years out of one, even parked outside. I'll have to jump it the first 30 degree day, and charge the battery overnight, then as long as I ride it once every couple days, and keep the tender on it, it'll be fine for the winter. Second year, second winter on this battery, I know it's getting weak. I'll replace it come spring.
The older I get the more I realize how few people I actually need in my life.
08 KLR 650
82 Suzuki GS850
7? Sachs Moped Basket Case
Doorguy1979 is offline   Reply With Quote
Old 11-18-2012, 06:37 PM   #14
bdefen
bdefen's Avatar
Location: Boise, Idaho - In the heart of Dual-Sport Paradise
Oddometer: 326
Keep it on a tender...
My 950 wouldn't start in cold (30 F or below overnight) temps. I put in on a tender 24/7. No problems since.
Byron
'13 BMW R1200 GSW
bdefen is offline   Reply With Quote
Times are GMT -7.   It's 02:39 AM.
