Old 07-23-2009, 07:53 PM   #1
skierd OP
Wannabe Far-Rider
Oddometer: 2,971
How to (almost) kill yourself with brake cleaner
http://www.brewracingframes.com/id75.htm
Be careful out there guys, especially those of you welding or other high heat type jobs on the bike.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 07-23-2009, 08:04 PM   #2
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Cant remember which, either r12 or r134 but when it burns it makes mustard gas.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 07-23-2009, 08:34 PM   #3
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,154
I think its r22
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 07-23-2009, 08:36 PM   #4
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,081
Good warning. I used to only worry about zinc fume sickness, but since I do use carb cleaner and brake cleaners to degrease stuff that I may later weld on, this is an eye opener.
Thanks for posting.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 07-23-2009, 09:05 PM   #5
showkey
Oddometer: 1,974
Mustard gas is bad but:
Quote from and A/C training manual FAQ:
They could also test for leaks before evacuating it by using an electronic "sniffer". In the past, a propane heated halide detector with an attached hose was used. Refrigerant would be sucked into the hose and cause the flame to turn bright green. This is mentioned for historical purposes only. Burning R-12 produces toxic phosgene gas and this old technique and equipment should no longer be used.
Phosgene is bad too mustard is worse if it matters............
showkey screwed with this post 07-23-2009 at 09:10 PM
showkey is offline   Reply With Quote
Old 07-23-2009, 09:58 PM   #6
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,349
Any chlorinated solvent is going to cause grief if combusted. Any chlorofluorocarbon or even hydrofluorocarbon. Any of the halogens deserve plenty of respect. Fluorine is the most reactive element on the periodic table. Anyhow, thanks for the article, I've got a few different chlorinated cleaners around and I have been fairly casual in their use.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 07-23-2009, 10:27 PM   #7
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,795
Chemistry can be fun too.
But yes, vapor decomposition is definately something to watch out for. Even those cans of compressed "air" will react with other gases and mix into rather dangerous substances.
Always always always always be careful when welding... know your surroundings, know who/what's around you (dogs, kids), know what you're welding and what's on the other side of the weld....
SnowMule is offline   Reply With Quote
Old 07-24-2009, 12:33 PM   #8
Commuter Boy
Oddometer: 2,939
Thanks for posting.
Acetone is what we used when I did my aerospace welding apprenticeship. Put it in little squeeze bottles with a needle point so you can get it right where you want it.
Commuter Boy is offline   Reply With Quote
Old 07-24-2009, 07:20 PM   #9
mark1305
mark1305's Avatar
Oddometer: 6,081
Yep, I use that too. And denatured alcohol for some stuff.
My liver should glow in the dark by now from all the solvent stuff I used to expose my skin to back in the 70s in factories that never saw OSHA inspectors. Not to mention all the tax-paid ethanol it has metabolized
Maybe it's true that what doesn't kill you only makes you stronger. Hopefully...
Mark J
Merritt Island, FL
Old 07-25-2009, 11:30 AM   #10
Jonex
zipper suited sun god
Jonex's Avatar
Oddometer: 1,357
Holy crap this freaks me out. I expected to see some kind of ho hum yawn fire deal.
Good info thanks.
Jonex is offline   Reply With Quote
Old 07-25-2009, 06:50 PM   #11
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Good info to pass along.
This might merit being a sticky. At least a sticky saying "don't eat the toxic chemicals and here's why" or something.
Safety's a tough thing to stay diligent on.
Thank you for linking to it.
datchew is offline   Reply With Quote
Old 07-25-2009, 07:20 PM   #12
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,820
I use this stuff a lot, but had no idea it could be this dangerous or how small of an amount could kill you.
katbeanz is offline   Reply With Quote
Old 07-25-2009, 07:30 PM   #13
Jonex
Jonex's Avatar
Oddometer: 1,357
I used to work in the chemical industry, and I got to run preps with warnings from the chemists saying stuff like mutagen, teratogen, extra-head-ogen, stuff like that. One night a few of us started puking after work, no warning, just instant projectile vomitous. Another time all of us guys got a bad burning down there after a spill clean up.
Honestly, the stuff that really spooked me wasn't the really nasty stuff I dealt with occasionally like silanes and cyanides and stuff, but the day in and day out exposures to MTBE, acetone, THF, and other solvents that I sprayed around with wild abandon. I figure the MTBE (ether) is pretty much permanently stuck in my fatty tissues and I'll die of cancer someday. Kinda sucks.
I should have known about this whole brake cleaner deal, or at least have a higher awareness level.
This is a good reminder to be careful out there, wear your PPE and use a mask.
Acetone is a big rip off. It costs about 70 cents a gallon in bulk, so when you buy some, bend over. Oh, and it will kill you too so wear gloves.
Have fun...
Old 07-25-2009, 09:44 PM   #14
daltonzach
Oddometer: 265
i'm freaking out man.... good info to think about.
daltonzach is offline   Reply With Quote
Old 07-26-2009, 03:06 AM   #15
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Scary stuff, and in part an inevitable outcome of our profusion of warning labels. They sit there on everything you buy... "Wolf!" - Don't ride this bicycle without a light. "Wolf!" - Licking the inside of this light socket could really hurt you. "Wolf!" - The state of California has decided that you'd better know there is a bit of lead in this wire's insulation. "Wolf!" - Sharp edges can hurt your wittle finger. "Wolf!" - Inhaling smoke may lead to long term health effects. "Wolf!" - If you apply a little heat to just a tiny bit of this stuff you will be killed. Whoops, that one SHOULD have a warning label, but I ignored it as I am now wont to do.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Times are GMT -7.   It's 01:56 AM.
