Old 11-17-2012, 07:25 AM   #1
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,492
Laugh GS "Power Controller" Discount Sale- In stock!
Orders: got Paypal? send the coins to HIGHTECHCOONASS (at) Gmail (dot) com
We have a 10 in stock the we can ship out this week at a $10 discount.
$75 plus $5 flat rate to ship in the US.
This is a power boost for all GS, smooths out the throttle response, and has been proven around the world - And as always money back guarantee!
Original vendor link......
http://www.advrider.com/forums/showthread.php?t=777887
Originally developed for the F800gs / F650GS throttle response... but now used on all BMW EFI bikes....
The problem is the bikes run to lean! - why? because of emissions tuning... the fix? give the engine a little more gas... how I do it? Tell the ECU the air temperature is lower than is actually is... Simple!
This smooths out the throttle response for the F800GS and gives the bike more HP.
It has a 2 position switch....
one position to use for 85 deg F and below ( -36 deg F temperature shift) and
another position to use when the air temp is 85 deg F and above (-18 degree F air temperature shift).
The 2 position switch can be mounted where ever the user prefers.
This is basically the same general idea as the Accelerator module and the Booster Plug sold overseas but a with a more refined fuel enrichment control when the temperature rises.
The idea of the switch : The rider may take off in the mountain mornings at 40 deg f and it may be 90 deg F later at noon riding in the desert. A -36 deg F offset to the ECU (the way the Accelerator plug works) is not need when the air temperature gets hot. Only a -18 deg F offset to the ECU is needed when the air temperature is above 85 deg f. Better control for a more precise enrichment.
The switch was a request from riders in some of the development discussions.
Good question to go over again.....
Blue position- this setting it tells the ECU that the air temperature is 36 deg F cooler than it is. The ECU enriches the fuel (on increase throttle movement and decrease throttle movement only)
Red position- this setting it tells the ECU that the air temperature is 18 deg F cooler than it is. The ECU enriches the fuel (on throttle movement only)
Less enrichment is needed when air temperature is above 85 deg F.
Steady state throttle- the O2 sensor controls enrichment!
Orders: got Paypal? send the coins to Hightechcoonass (at) Gmail (dot) com
Cost: $85 plus $5 to ship
5% of the sales to Baldy and the ADVRIDER web site!
WAL-MART guarantee - if you are not happy with the performance of the Power Controller please return for 100% refund!!!!
Step one.....
Step 2.....
Step 3....
Step 4 ....
Use sticky to stick down a base and tyrap the sensor to the "stick base"
5. Mount the switch where ever you prefer...
operations: the "red paint" on the switch is for -10 offset (above 85 deg F) away from the red paint or blue is for -20 deg c) when temperature is below 85 deg F.)
any question PLEASE send me a PM!!!!!! I check a few times a day!!!
Shipping Options
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 03-21-2013 at 06:42 PM
HighTechCoonass is offline   Reply With Quote
Old 11-17-2012, 06:19 PM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
whats the difference between yours and what poolside makes?
Motorfiets is offline   Reply With Quote
Old 11-18-2012, 08:50 AM   #3
FlyingFinn
Oddometer: 1,111
One is available to buy and the other is not
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline   Reply With Quote
Old 11-19-2012, 03:53 PM   #4
HighTechCoonass OP
Oddometer: 2,492
Laugh
My opinion....
1- The thermistor MUST NOT be located under the tank / seat. I proved this by testing with a thermometer while out on the road. They never ran this test. The heat here will negate the effect needed. Its is a less expensive to build a "non" extended thermistor unit... but it does not work as well.
2- No Suitcase jumpers in a plastic case. My unit is bomb proof and switch on the fly.
3- I won't sell you something I don't have in stock. No waiting 4 months.
4- My unit has a money back guarantee! Send it back if you don't like it.
5- Why the high sales for IICE? They can discuss in the GS forum. I can only discuss my unit and how it works in the vendor forum.
6- They have (i think ) a few more temperature offset setting. My testing showed that it was not needed.
HighTechCoonass screwed with this post 11-19-2012 at 05:43 PM
Old 11-19-2012, 04:01 PM   #5
gspdbill
noobie allover again
Oddometer: 404
I can't read the blue text.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 11-24-2012, 07:42 AM   #6
HighTechCoonass OP
Oddometer: 2,492
Laugh
Fixed!!
Old 11-24-2012, 02:46 PM   #7
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,364
So is the price still $75 + $5 or back to $85 + 5? I'd like to try one in my GSA and G650X and if I'm happy I'll get another
Arizona Adventure Riding Group
azgsa is offline   Reply With Quote
Old 11-25-2012, 06:54 AM   #8
HighTechCoonass OP
Oddometer: 2,492
Laugh The discount continues thru Jan 1 2013
still $75 plus $5 flat rate USPS shipping. $80 total
If you want one PM me and send the dinero to wukaking (at) gmail (dot) com.
I can usally get in in the mail by the same or the next day! Thanks!
Old 11-25-2012, 08:08 AM   #9
Hucker
Lost
Oddometer: 690
Had mine before PayPal even took the money from my account.
Thanks HTC!
Hucker is offline   Reply With Quote
Old 12-07-2012, 08:19 PM   #10
HighTechCoonass OP
Oddometer: 2,492
Laugh
PM me if you order please!! That way I can get it out same day!!!! I have all orders to date going out tonight!
HighTechCoonass screwed with this post 12-08-2012 at 08:09 AM
Old 12-15-2012, 06:04 AM   #11
HighTechCoonass OP
Oddometer: 2,492
Laugh
update - I have 4 units left.
Thanks for the support!
Old 12-24-2012, 07:15 AM   #12
HighTechCoonass OP
Oddometer: 2,492
Laugh Power Controller - Advrider Discount
2 units left...
New retail packaging for the BMW dealerships.
Old 12-29-2012, 11:00 AM   #13
homeontherange
Ochlophobiac
homeontherange's Avatar
Oddometer: 207
that was quick...
I ordered Christmas eve (no life!) and the package was delivered Dec 28th.
I totally take back all those times I didn't want to nap when I was younger.
homeontherange is offline   Reply With Quote
Old 12-30-2012, 06:38 PM   #14
HighTechCoonass OP
Oddometer: 2,492
Thanks mate! I try to get them out the same day!
My son is in the process of building 30 "Juice" units!
Old 01-28-2013, 05:02 PM   #15
HighTechCoonass OP
Oddometer: 2,492
Laugh
Here is the latest guys.... I am thinking of retiring the production of the Power Controller... I have been getting lots of feedback that the users are leaving the units in the Blue mode without any noticeable ride ability and performance - or jerkiness.... The New "Juice - Power Controller" is a more simple plug and pay design... no switch to mount...
The plus side for me is the builds are much more simpler and for the user the cost is about $10 less. Please let me know what you think.
As always I will still give you the guarantee that if you don't like it send it back for a full refund.... Here is the linky to the "Juice - Power Controller" unit.
http://advrider.com/forums/showthread.php?t=850321
Times are GMT -7.   It's 08:26 PM.
