11-17-2012, 01:16 PM
#1 |
Shred
Oddometer: 179
Mineral Oil for Clutches
Hey all.
Today I bled out my clutch on my Gas Gas with the dregs from a bottle of Magura blood oil I have had around, but I would like to flush it more thoroughly, and the blood oil comes in small bottles. A few searches for alternative turned up some surprising options. Many people said they used 2.5 or 5 weight fork oil and or ATF in their clutches. Anyone have anything to relate on the Gassers related to clutch oil? Thanks
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly. |
11-17-2012, 01:53 PM
#2 |
Oddometer: 774
Find a cheap baby oil, 99% mineral oil less than 1% fragrance. Fork oil could be 60/40.
11-17-2012, 01:57 PM
#3 |
Shred
Oddometer: 179
I've tried baby oil in the past, and found it far to viscous, clutch action was very stiff. Did I just get the wrong baby oil?
11-17-2012, 02:45 PM
#4 |
Oddometer: 402
Try using silicone dot 5.0 brake fluid.Use same fluid in brakes and clutch.Does not absorb moisture like other brake fluid so you need to flush more often so the internal parts do not get corroded.I flush rear brake every 3-4 months front every 6 months. Regular brake fluid absorbs moisture so there is less problem in the short term with internal corrosion.
11-17-2012, 02:50 PM
#5 |
Oddometer: 245
http://www.competitivecyclist.com/pr...paign=Datafeed
Thinner than drug store mineral oil. I used to convert my OEM dot 4 fluids to dot 5. worked well. The above mineral oil seems very good too, so started using this on my OEM mineral oil hydro's. (green cap on GG's) |
11-19-2012, 06:32 AM
#6 | |
Trails Evangelist
Oddometer: 967
Then in the Hydraulic levers, I remove the mineral oil, replace with easier to find DOT 5, I cant say there is much difference other than easy to get DOT5 comparatively, most cycle places carry 5. |
11-25-2012, 03:22 PM
#7 |
Shred
Oddometer: 179
Yes, ATF for the Tranny. Just got my bike back from the shop, put in one 20 minute ride, then changed the oil. No idea what they put in, but it was not ATF.
You more or less answer my question as to Dot 5 in the clutch. I know it will work, in terms of viscosity etc. You can use water in a pinch, or the special yellow fluid as my friend Buck put it, and my old KTM came home with water in the system several times. (very leaky slave) But how will the Dot 5 treat the seals and lines? If you have been running it for years with no issues, that is good enough for me.
11-25-2012, 07:13 PM
#8 |
Oddometer: 402
Been running Dot 5 in all the hydraulics since 95.Never had any probs.The big advantage of Dot 5 is that it is made of silicone.Silicone is inert so it will not eat things like regular brake fluid will.Your paint and polished parts will thank you if you ever spill on paint or polished surfaces.It also happens to work very well in these applications.
11-26-2012, 06:37 AM
#9 | |
Trails Evangelist
Oddometer: 967
The thing about ATF, it is cheap, also that it makes the clutch (IMHO at least) very "quick". I like my clutch to have a little less instant bite, that is why I went with the yamalube |
11-26-2012, 11:24 AM
#10 |
Oddometer: 760
Spectro mineral oil
Saw this at my local bike store a few weeks ago and bought it. http://www.spectro-oils.com/mineral-...-clutch-fluid/
Has anyone here used this? |
