11-17-2012, 04:11 PM
#1 |
Mr. Tourguide
Oddometer: 2,632
Rear Shock for KLR250?
I'm looking for an upgrade to my rear shock, KLR250. The stocker is now like a pogo stick.
My Google-fu is probably not working because I can't find anything except replacing it with a KLR650 stock shock. Thanks
My motorcycle projects blog My Goodreads Profile This is what I do when I'm not here! |
11-18-2012, 04:10 AM
#2 |
Be aware
Oddometer: 2,472
i found the thread in thumpers forum...read it or search it yourself.
![]() http://www.advrider.com/forums/showt...ghlight=klr250 |
11-18-2012, 03:19 PM
#3 |
Oddometer: 160
The KLR 650 shock is the cheapest solution, I tried a used 250 shock from ebay and got screwed. The 650 shock fits ok, need to enlarge one hole, and fiddle withe carb boot/airbox fitting. emti
11-18-2012, 06:53 PM
#4 | ||
Mr. Tourguide
Oddometer: 2,632
I love the little KLR for woods riding, I just don't want to bounce around too much
11-19-2012, 07:49 AM
#5 |
Thumper
Oddometer: 378
Call Rick at Cogent Dynamics.
11-19-2012, 08:37 PM
#6 |
Mr. Tourguide
Oddometer: 2,632
Are his shocks better than the Hagon? Asking because there is about $200 price difference.
11-21-2012, 03:10 AM
#7 |
Oddometer: 160
It lowers the rear of the bike about an inch or so I just raised the forks an inch to match .Still have the stock front springs. I dont have a better dirt bike to compare it to but it seems ok within the expectations of a KLR 250. For some reason afternarket shocks are expensive. My only issue is/was getting a good seal withe carb to airbox boot. emti
11-21-2012, 12:46 PM
#8 |
Mr. Tourguide
Oddometer: 2,632
Thanks.
I started looking at the Hagon shock, but yeah, it's expensive. Maybe it would be easier and cheaper to find a proper dirtbike shock in the same length and then have a machine shop modify what needs to be done. KLX250 shocks seems much cheaper on fleebay and the bike weight/power is just about the same.
11-21-2012, 01:47 PM
#9 |
Feral Chia tamer
Oddometer: 2,607
This
I am not familiar with the quality of Hagon, but Ricks stuff is top shelf. I can tell you for sure that Cogent Dynamics shocks are 10X better than a progressive. I won't use anyone else.
Mutt'n the custard. On the outside with my back turned. |
04-22-2013, 04:11 PM
#10 |
seekerhiker
Oddometer: 28
Put in the 650 shock
I have instructions on installing a KLR650 shock in the KLR250 here - http://youtu.be/k6xwxYsuIOQ
The man who can make the pin replacement/sleeve/adapter is Ian Smith at MotorSmith: 8 Wicket Street Unit 8 Pine Meadow, CT 860-751-9026 fellesh@yahoo.com |
