Old 11-18-2012, 10:08 AM   #1
Laconic OP
Anodyne
Laconic's Avatar
Oddometer: 18,075
A Little Chain Advice, Please
Both ends of my master link have given up the ghost; I don't really know why, I was pretty careful putting it together.
Anyway, the rest of the chain is fine and the sprockets have a good bit of life left in them (see photo). I have a new chain and sprocket set on the shelf but it seems wasteful to get rid of what I have just yet.
Is it unheard of to replace the master link with two others? Looks like I would need to take out a link on either side to get rid of any potentially worn components.
Laconic is offline   Reply With Quote
Old 11-18-2012, 10:20 AM   #2
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,566
You might want to measure the stretch to be certain you're still within specs. If not, simple decision.
I added two master links to my Yamaha 250 two smoke back in the day but that engine wasn't exactly a torque monster.
I'd install the new chain and sprocket and store the old chain and sprocket telling myself it could come in handy some day and after I moved it around half a dozen times, toss it out.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 11-18-2012, 10:37 AM   #3
sieg
sieg's Avatar
Oddometer: 2,885
Sure, go for it. Not much to lose by trying it. Although some will tell you that if you don't replace the chain and both sprockets you will surly crash and die. And don’t even think about a clip type master, that’s suicide.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 11-24-2012, 02:49 PM   #4
Laconic OP
Anodyne
Laconic's Avatar
Oddometer: 18,075
This is what I'm doing. Couldn't locate any cutoff links.
Old 11-24-2012, 04:47 PM   #5
Lone Rider
Registered User
Oddometer: 25,130
That sprockect looks crisp.
Did you just loose the master link clip?
Lone Rider is offline   Reply With Quote
Old 11-24-2012, 05:01 PM   #6
Navin
Navin's Avatar
Oddometer: 8,346
What is wrong with the master? Is it loose? If so bin the set. Why risk thrashing the engine cases or wrapping the drive up at speed. What do you hope to gain, another 1000 miles?
Navin is offline   Reply With Quote
Old 11-24-2012, 05:31 PM   #7
Laconic OP
Anodyne
Laconic's Avatar
Oddometer: 18,075
Does that mean good or toasted? Not using a clipped link.
The pins and bushings got dry and wore in the master, not sure why, the o-rings were all good and I greased it all when I put it together. The rest of the chain is good and to me the sprockets look like they have life left.
Anyway, I put on a new setup.
Old 11-24-2012, 05:44 PM   #8
Navin
Navin's Avatar
Oddometer: 8,346
Anytime I have to ask if it is still good I just replace it.
Why take a chance & get hurt or even just stranded.
Times are GMT -7.   It's 11:35 PM.
