07-31-2012, 10:06 AM
#1 |
Whereabouts unknown
Oddometer: 256
Zumo 550 tracks for UTBDR needed
Leaving next Monday to ride sections 4, 5 and 6 of the Utah Backcountry Discovery Trail. I have the map but would like to have tracks for my Zumo 550. Any help would be appreciated.
Thanks, Steve Graniteone screwed with this post 07-31-2012 at 11:04 AM |
08-01-2012, 12:14 PM
#2 | |
Oddometer: 139
Go to www.utbdr.com They have a tab on their homepage where you can download the tracks................Have a great trip.....and looking forward to reading your ride report |
08-01-2012, 04:08 PM
#3 | |
Whereabouts unknown
Oddometer: 256
Thanks! |
08-01-2012, 09:22 PM
#4 |
Oddometer: 4,100
I think on that Zumo you must download tracks then it will convert them to Routes. If you really want to use tracks, get a Montana or Zumo 665.
Jerry Counts |
08-02-2012, 04:30 PM
#5 | |
Long Haul Adventurer
Oddometer: 3,258
Have fun in Utah. Cheers,
Cheers, Dan |
08-11-2012, 07:28 PM
#6 |
Oddometer: 167
Loading tracks another way
Too bad I didn't see this post earlier. If your Zumo stores its map(s) in it's internal memory and takes an SD card, then you could've converted the gpx track into a transparent map onto the SD card. The map overlays any map you have on your zumo. Very inexpensive software to do this. http://www.gpx2img.com/ It works with Mapsource.
If you're familiar with loading maps to your gps via mapsource, then the converted gpx track can be loaded with other maps to internal memory of your gps. Remember to back up your original map first. It is the gmapprom file in your unit, or gmapsupp on the sd card within a folder named "garmin". Also back up any gmapsupp.unl files and gmapprom.unl files you see. They are crucial to unlocking original maps. If you don't iknow what you're doing here, don't mess with it. Use the first option above. Cheers
07 klr650 08 exc530 |
08-11-2012, 09:32 PM
#7 |
Whereabouts unknown
Oddometer: 256
Thanks for the above info. I ll look into it next time. We had no problems following the map and using another GPS unit my buddy had. We just finished routes 6,5 and 4 of the UTBDR. A lot of it was on my Zumo 550.
We will finish the rest once the weather cools in the desert. The terrain is super fun and big bike friendly. I would classify the sections we rode as moderate at the most extreme. The scenery as spectacular. Look forward to more of the same. S~ |
08-12-2012, 01:29 PM
#8 |
Oddometer: 1,236
If you have Mapsource or BaseCamp and City Navigator, you could load in the tracks and then create routes that overlay the tracks and then use those. Might be a little tedious, but I bet it would go pretty fast. Actually I think BaseCamp, which is free, has an option that will directly create a route from a track.
And there might be a few instances where the UTBDR uses roads not on CN. But from what I understand they nearly always stuck to major dirt roads. This would be a lot cheaper than buying a new GPS and learning how to use it. Seems like if you own a GPS that it is not unreasonable to have access to some kind of software that will create routes for it. |
08-12-2012, 03:11 PM
#9 |
Oddometer: 1,100
If the dirt roads are on CN you should be able to make most of the tracks work for you on a Zumo 550. I have converted large track files to a route IF IF they are in the CN steet db.
While not a "track" machine, the Zumo 550 does convert tracks to a route but in my experience one can experience problems when moving from pure dirt to mapped streets, especially if tracks are very close to a mapped street. Best to check the results on MS too...indeed MS is needed for some of these machinations so this is an exercise in trip planning prep not for the sticks. Loaned my Zumo to somebody so can not test UTBDR tracks now. For pure dirt (unmapped) sections you may have to break some of the tracks in two as there is a limit of about 250 via points in a converted route. Based on how the internal Z550 Algorithm "magic" works on the filtered track file may be cut down even more in the conversion to a route. One of these days I will get a Montana but until then I guess I am in to work arounds. |
08-18-2012, 06:07 PM
#10 |
DetourJournal.com
Oddometer: 75
UTBDR GPS tracks with side attractions
I know the Zumo 550 has it's issues, and Doesn't like to convert tracks into routes. But, if you do end up going with another GPS, Maybe this will help. I'm doing the UTBDR on Aug 31, and I've modified the GPS Tracks provided by Butler Maps. This version includes, of course the main route, plus all of the additional Sites along the way:
Let me know if this helps! Download it here: www.DetourJournal.com/ride/gps/UTBDR-With_Extra_Attractions.zip
Start your own Adventure Travel Blog
08-19-2012, 08:34 AM
#11 |
Whereabouts unknown
Oddometer: 256
Thanks for the tracks. I ll give them a shot.
We are going to finish the UTBDR in Sept when it is a tad cooler in the desert. The northern section was great and easy to navigate. |
01-27-2013, 07:44 PM
#12 |
Oddometer: 21
Hi Folks,
If you download the recent version of Garmin's "Base Camp", you can click on "file" then "import", then select the ".GDB" file from the UTBDR zip file you unpacked. It will import into base camp. Then, connect your SD card, or preferrably your 550 to your computer. Then, highlight the "UTBDR All Routes 500" file for example, right click, then select "send to", then select your SD card or 550, and the files will transfer to your device, or SD card which you can plug into your device. I just did it, and didn't need to convert any files to the ".GPX" format, which is another way to do it. If you want to convert to GPX, just highlight the track, and "save as", then select the GPX format with whatever name you want to save it as. Unfortunately, that takes more time, and doesn't seem to be any better. Good Luck!! PM me if you need a little more detail. Duhfactor Duhfactor screwed with this post 01-27-2013 at 08:09 PM |
