Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 07-08-2013, 07:32 AM   #76
archipelagos
farvertex
Oddometer: 23
Originally Posted by fixerdave View Post
latest:
with the sun-screen (yeah, cheap android tablet):
and, with my custom orux maps:
those thick black-on-white lines make all the difference in being able to see the screen while riding on a sunny day. Almost don't need the sun-screen.
I just picked up another tablet, a 10.2" unit. This winter's plan is to rejig the windscreen and mount that. Bigger is better, after all
wish me luck
David...
any more pictures of your setup?
archipelagos is offline   Reply With Quote
Old 07-08-2013, 10:53 AM   #77
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,511
Last ride with the 60CSx. Sold on Ebay, will be getting a 78 on order tonight.
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 07-15-2013, 10:26 AM   #78
silisevic
silisevic's Avatar
Oddometer: 2
Originally Posted by broken paddle View Post
Did you connect the wires at the switch? With solder?
Actually, the wires coming out of zumo's RAM mount are not connected directly to the ignition. They are connected between the ignition and the main fuse box, that being the easiest place to do it without removing too much of the fairing in the process.
I've cut the wires at that point, spliced them with insulated terminals (*) and made a separate fuse just for the zumo as mentioned previously. I could've soldered them, but then I'd run the risk of engine+ambient heat unsoldering them (it's a longshot I know, but I am playing it as safe as I can.)
Wish I could attach some photos of the install, but alas it didn't occur to me to take any since it was a fairly straightforward job.
(*) not sure if this is the correct name - I am neither English/American, nor am I a professional electrician :)
Sasa
silisevic is offline   Reply With Quote
Old 09-10-2013, 05:26 PM   #79
LexLeroy
Aging Gracelessly
LexLeroy's Avatar
Oddometer: 2,084
Mounted on a RAM mount on my XR650L.
Here it is from a distance -
"That's MISTER Crash to you, sonny...."
LexLeroy is offline   Reply With Quote
Old 01-22-2014, 11:42 AM   #80
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,748
76csx, top clamp ball mount on all my bikes. it aint the starship Enterprise, but it works just fine:
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 01-26-2014, 08:08 PM   #81
GS eh!
Oddometer: 170
Here is my Montana on the 500 EXC
AMPS powered Cradle in TT mount. all attached to HDB rally lite set up. I kept the mount when I sold the GSA.
And on the bike, a bit hard to see but it is there!
GS eh! is offline   Reply With Quote
Old 01-26-2014, 08:15 PM   #82
GS eh!
Oddometer: 170
One More
Garmin 276 on my old GSA
TT mount attached by RAM arm.
Old 01-30-2014, 01:21 PM   #83
GeeK_InsiDe
Moore Gas!!!
GeeK_InsiDe's Avatar
Oddometer: 339
Oregon 200 and Zumo 220 on my 700GS windscreen, both with RAM mounts:
USB powered Oregon 200 (you can see the dual USB power socket on the left of the speedo):
I just bought a Montana 650 to replace both of them. It'll be a little big for hiking compared to the Oregon...
GeeK_InsiDe is offline   Reply With Quote
Old 02-03-2014, 09:09 PM   #84
jasonmt
Oddometer: 522
I am a touch more "minimalist" than a lot of you it looks like:
jasonmt is offline   Reply With Quote
Old 02-17-2014, 09:20 PM   #85
jonyg
jonyg's Avatar
Oddometer: 18
F800gsa
Garmin Oregon 450. Works great
jonyg is offline   Reply With Quote
Old 02-17-2014, 10:48 PM   #86
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,511
76Cx, RAM-mount. External powered while the sled's running (greatly improves battery life; cold is hell on the AA's).
Old 02-19-2014, 06:22 PM   #87
Lee R
Oddometer: 29
I quit using Garmin's after I had two units break on me in a row. I used a Delorme PN 60 for a bit with topo maps but it's kinda on the small side.
I'm now using a Nexus 7 with RAM setup and made a video of my previous 10" Samsung Galaxy Tab 10.1 (first gen) that I've used. I find the tablet's far superior except for hitting rain. You can get a waterproof case/ziplock bag or just buy something like the Sony Experia Z that's waterproof. ALL of them cost hundreds less than a zumo and I can still use mine with gloves.
Here's the quick demo from this past summer covering some apps. For you dirt only guys Backcountry Navigator is amazing. It has all the topo's, satellite imagery offline for a about 30 bucks.
It's easy to generate a route on google maps of bing and export that into the device via dropbox as well, much better than basecamp. (GPX)
I also use these for flying in aircraft, zero issue with vibration in 3 years of use.
If you've been eyeing this option heres the video:
http://youtu.be/lPrctiPwads
Lee R screwed with this post 02-19-2014 at 06:34 PM
Lee R is offline   Reply With Quote
Old 02-19-2014, 07:36 PM   #88
EmmEff
Oddometer: 1,724
Nice video review, thanks.
EmmEff is offline   Reply With Quote
Old 02-28-2014, 04:18 AM   #89
ohgood
ohgood's Avatar
Oddometer: 2,724
crappy android phone screen capture, from my gopro video, of my crappy android phone getting roosted, it's Velcro'd to the 4$ trashcan wind shield... and tracking the whole ride with oruxmaps.
(screen off so it won't distract me from the roost)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 03-01-2014, 10:56 AM   #90
Tails_KTM
Tails_KTM's Avatar
Oddometer: 63
Tails_KTM is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 10:04 AM.
