Old 11-19-2012, 04:51 AM   #1
TheRadBaron OP
Oddometer: 324
How much tolerance for wheel bearing press fit?
I have a rear hub from a Yamaha XT500 that I'm preparing to have some machining done. I need to machine the 40mm wheel bearing bores out to 42mm. What is the recommended interference fit for a wheel bearing? I'd like to have a definite diameter to tell the machinist.
I know that I could get an idea by measuring the the hub that I have, but I'd rather hear the official number. I tried looking it up using machinist literature, but not being a machinist myself, it was like a foreign language.
The desire for safety stands against every great and noble enterprise. -Tacitus
TheRadBaron is offline   Reply With Quote
Old 11-19-2012, 05:12 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 4,357
.001". Fit bearing with anti-seize.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 11-19-2012, 05:21 AM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,774
That's way too heavy for a bearing and will likely to damage it. Try .0003-.0005" smaller than the bearing OD on the bore.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 11-19-2012, 05:43 AM   #4
OldPete
Be aware
OldPete's Avatar
Oddometer: 2,472
.0005" to .0008" per inch of bearing diameter.
Make sure the bore is clean before pre-heating it. Chill bearing in freezer.
Install w/o hitting the inner race as this is a prime cause of short bearing life.
I like drawing bearings in with a bit of all-thread.
SKF and New Departure have specs.
OldPete is offline   Reply With Quote
Old 11-19-2012, 08:23 AM   #5
machinebuilder
Oddometer: 713
This link has all the info you need (and more)
http://www.nsk.com/services/basickno...03fitting.html
But I can save you a little time and say 42 +0.0 -0.012
2009 BMW F800GS NON ABS
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table.......seen on a T Shirt
machinebuilder is offline   Reply With Quote
Old 11-19-2012, 08:42 AM   #6
TheRadBaron OP
Oddometer: 324
Man, I opened that document and it's pretty esoteric stuff (to a non-machinist). I know that I could spend the time and get sufficient reference data that I could understand it, but I'd really rather not .
As far as the measurement that you gave me, am I correct in taking that as meaning that I should have 0.012" (12 thousandths) of interference? This seems excessive to me. Did you mean 0.0012"?
Old 11-19-2012, 08:51 AM   #7
Tosh Togo
Oddometer: 1,594
Your "machinist" should already know about things like interference fits.... mine does.
You might want to look until you find one (or a shop) that does. Whoever does machining work for your area's racers would be a good place to start.
If that's not an option, call your local bearing supplier.
Tosh Togo is offline   Reply With Quote
Old 11-19-2012, 08:57 AM   #8
TheRadBaron OP
Oddometer: 324
I agree, but I'm not really taking the hub to a machinist in the conventional sense. My dad works in a machine shop that manufactures high-tech parts for the steel industry and he's going to have one of the machinists there turn it for me. I'm sure that the machinist that will do it is a skilled guy, but steel mill components and motorcycle wheels probably have enough differences in machining tolerances that I'd like to be able to ask for a specific clearance rather than leave it up to the machinist's judgement.
Old 11-19-2012, 09:01 AM   #9
machinebuilder
Oddometer: 713
Dimensions are in millimeters, 0.012mm = 0.00047"
I work in mm all the time, and REALLY dislike mixed measuring systems
There's a couple charts in the midst off all that info that give the tolerances
machinebuilder screwed with this post 11-19-2012 at 09:03 AM Reason: fix typo
Old 11-19-2012, 09:03 AM   #10
_cy_
Oddometer: 2,712
let the machine shop determine clearance. take actual bearing in along with hub. any reputable machine shop has done this before.
_cy_ is online now   Reply With Quote
Old 11-19-2012, 09:24 AM   #11
TheRadBaron OP
Oddometer: 324
Duh, I should have been able to figure that out. I was fixated on the "inch" system of measurement since that's the way it usually gets discussed. Thanks for the good info.
Old 11-19-2012, 04:52 PM   #12
machinebuilder
Oddometer: 713
Any time, I deal with similar stuff on machine tools daily, so to me what is common sense is more like rocket science to many.
Besides the only really stupid question is the one not asked.
Times are GMT -7.   It's 12:34 AM.
